Best Wireless Mouse at the moment? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 27 (permalink) Old 02-06-2020, 03:41 PM - Thread Starter
Hannes969's Avatar
Rep: 0
How do i update the mouse software/firmware and also on the usb dongle without the logitech g hub **** ?
Hannes969 is offline
post #22 of 27 (permalink) Old 02-06-2020, 08:19 PM
Falkentyne's Avatar
Rep: 420 (Unique: 294)
There is a "Logitech connection utility", a standalone program to update the receiver. You can find that on their software downloads page.
None of the Hero lightspeed wireless mice work with LGS. The last version of LGS was 9.02.
The G903 SE (3366/best buy exclusive), which MAY have improved lever tensioning and less lever play (mine is flawless) works on LGS 9.00 and 9.02 still as its still a G903.
If you buy a 903, you should mod the L/R clickers immediately with Omron D2F-01 or Omron D2F-01F or ZF DG2 T85 (Cherry) switches or Panasonic AH1480619 or AH1460619 microswitches.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Falkentyne is offline
post #23 of 27 (permalink) Old 02-06-2020, 09:59 PM
Synoxia's Avatar
Rep: 9 (Unique: 7)
My GPW indeed works with LGS...
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #24 of 27 (permalink) Old 02-07-2020, 08:42 AM
Not a Linux Lobbyist
the1freeMan's Avatar
Rep: 43 (Unique: 33)
https://www.overclock.net/forum/375-...ical-info.html
TL ; DU (yes U lol)
Wired is still better.
Logitech has less latency but is less stable.
Razer is more stable but has higher latency.
As for hero vs 3366, the hero has a fully dynamic frame-rate resulting in a stiffer feeling when changing axis of movement. Not as noticeable as in the mercury but still a little different.
But yeah you're used to a 130g mouse so I'm not sure you'd notice.
"a bad joint can't be that bad right?" -q
the1freeMan is offline
post #25 of 27 (permalink) Old 02-16-2020, 09:46 AM - Thread Starter
Hannes969's Avatar
Rep: 0
Heyy
So i cant update the mouse firmware without using the g hub?
post #26 of 27 (permalink) Old 02-16-2020, 11:06 AM
LTSC Consiglieri
skupples's Avatar
Rep: 647 (Unique: 349)
only thing updating the firmware does is extend battery life
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #27 of 27 (permalink) Old 02-16-2020, 08:21 PM - Thread Starter
Hannes969's Avatar
Rep: 0
Andy only over the g hub?
