Fried Logitech Trackman Wheel Optical - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 02-13-2020, 10:51 PM - Thread Starter
Rep: 0
Recently snagged a Logitech from a thrift shop for $5. After cleaning a decent hairball of dog fur out of it, it worked well for about three weeks, then began to have issues. The mouse would disconnect randomly and only work if I held the wire at a certain angle. I opened it to check if the cable was the issue, and sure enough, the end was frayed under the heat shrink, which I had missed when first cleaning it. I had a second mouse (by a brand called "Genius") which had a broken scroll wheel, so I decided to see if the cables might be interchangeable. The connectors were the same, so I crossed my fingers and swapped them over. my computer made the USB connect sound, but then said it was unable to recognize the device. When I switched back to the original cable, the same happened. Is the mouse salvageable? I can solder decently, so if the only problem is a fried SMD component I should be able to fix it, but I didn't see any visible signs of failure on the PCB. Thanks in advance.
dooms is offline
post #2 of 2 (permalink) Old 02-13-2020, 11:07 PM
Rep: 0
Check the USB connector. I have a USB drive and a wireless mouse receiver that died because the USB pins are cracked and not longer making good contact.
Use hydrogen peroxide to clean your trackball. It works great.
Small Brick
(7 items)
AMD 3600 3.80Ghz 1.00V
MSI B450I
RX480 1300
2x8GB 3000
EVGA NEX 750B
Stock
SST SG13
tc20 is offline
