Electrical issue causing input de-synchronization or input loss - Page 3 - Overclock.net - An Overclocking Community
post #21 of 437 (permalink) Old 03-29-2020, 02:48 PM - Thread Starter
Timecard's Avatar
Rep: 32 (Unique: 20)
Quote: Originally Posted by Diffident View Post
Did you take the panel cover off and place a clamp meter around the wire at the breaker to check for load?
What's the voltage, neutral to hot under load? Is there a voltage drop compared to no load?
What happens when you don't use the UPS?
How many times did you power down and test again? Could it have been a one time fluke?
And my other question, if every thing is fine in your office, what possessed you to plug your system into an outlet in the hallway?
1. Haven't investigated in the circuit breaker itself, I'm wondering if there's a loose connection either there or path to for both.
2. Voltage as per my original thread post is currently 117v, usually 115v-120v during the week/time of day which is acceptable as per code.
3. This happened before the UPS, without UPS and using other decent ($80-100) power bars.
4. Never powered down, UPS kept it online. Repeated 3 times now, back and forth, always better on this office circuit.
5. I've been trying to diagnose this for a while. I do get spikes of lag on this good circuit too but it seems about 70 good / 30 bad, nothing in Windows has given clues and I have no electrical engineering background so trying to isolate cause by trying different things.
I just noticed something really interesting that I've been exploring today but I don't fully understand it, if I use my multimeter and set it to Hz (frequency) I get notably high numbers probing ground to neutral.
In my office if I get around 200hz as indicated above (ground to neutral) then I get occasional hitching on display and delay ingames, desktop. If it's around 100-150 then it feels fast and responsive, I tested this when lag increased and that was my observations.
Interestingly my hallway without my UPS on it has 0.002v load ground to neutral, and 60hz frequency ground to neutral but with UPS it's getting 2.2Khz (2200hz) which sounds crazy, to me this screams loose neutral connection or possibly the opposite office has loose and the hallway doesn't.
Timecard is offline
post #22 of 437 (permalink) Old 03-29-2020, 02:50 PM
LTSC for life crew
speed_demon's Avatar
Rep: 156 (Unique: 107)
Quote: Originally Posted by looniam View Post
great minds and all . .
I am very humbled you would say that. You made my day in the best way possible.
Ryzen 1600 AF
MSI X470 Gaming Plus
MSI R9 390 8GB
16GB DDR4-3000
120GB HP M700 SSD
Samsung Spintpoint M9T 2TB
Seagate Barracuda 500GB
Corsair HX1200 (2017)
Thermalright True Spirit 140
Fractal Define S
Operating System
Windows 10 LTSC
Keyboard
Alienware W/Cherry MX Switches
Mouse
Logitech G5
speed_demon is offline
post #23 of 437 (permalink) Old 03-29-2020, 03:03 PM
BOINC Cruncher
Diffident's Avatar
Rep: 110 (Unique: 72)
5. I've been trying to diagnose this for a while I get spikes of lag on this circuit, but it seems about 70 good / 30 bad, nothing in Windows has given clues and I have no electrical engineering background so trying to isolate cause by trying different things.
Interestingly my hallway without my UPS on it has 0.002v load ground to neutral, and 60hz frequency ground to neutral but with UPS it's getting 2.2Khz (2200hz) which sounds crazy, to me this screams loose neutral connection.
If you didn't take off the panel cover, then you didn't properly check for load on the circuit. Load is checked at the source with a clamp meter. For voltage, you said 117v ground to hot. What is it hot to neutral, under load and without load?
If you pull out the outlet, did they wrap the wire around the screw (preferred method) or did they stab it in the back like lazy "shackers".
Team Boinc! - Forum Folding War Team
Gentoo Linux - Telemetry Free Since 1999!
Washington Capitals 2018 Stanley Cup Champions
Boinc Desktop
(15 items)
CrunchAholic
(10 items)
NAS
(7 items)
AMD Ryzen 7 1700X
ASRock X370 Taichi
AMD Radeon VII
HyperX Predator
Samsung 970 EVOPlus
EVGA 850 G2
Watercool Heatkiller IV PRO AM4 CPU Block
EKWB Coolstream XE 240 Radiator
EKWB Coolstream PE 360 Radiator
Watercool Heatkiller 150mm Tube Res
Thermaltake View 31 Tempered Glass RGB Edition
Operating System
Gentoo Linux
Alienware AW3418DW
Keyboard
Coolermaster Masterkeys Pro S
Mouse
Roccat Kone EMP
Intel Xeon E5-2670
Intel Xeon E5-2670
Asrock Rack EP2C602
EVGA 1070ti FTW
EVGA 1070ti FTW
64 GBs Samsung M939B1K70CHD-CH9 PC3-10600R
Samsung HD322HJ
Corsair AX1200
Rosewill RSV-L4000
Operating System
Gentoo Linux
i3-4130T
GIGABYTE GA-H97N-WIFI
CORSAIR CMX16GX3M2A1600C11
Western Digital Red 10 TB x3
Western Digital Red 8 TB
Fractal Design Node 804
Operating System
Gentoo Linux
Diffident is offline
post #24 of 437 (permalink) Old 03-29-2020, 03:20 PM - Thread Starter
Timecard's Avatar
Thanks
1. I don't own a clamp meter but I can look into that.
2. I have tested the plugs with plug tester and they pass that test.
3.
Office: Hot to neutral is slightly less (118.2) than ground to neutral (118.6) under current load (pc, monitor, router)
Hallway: Hot to neutral is slightly less (117.0) than ground to neutral (117.5) under current load (pc, monitor, router) * similar difference between both, slight variation in V between tests but that should change with other load in the house?
4. I can take apart the outlets to confirm, from what I've seen in this house in the past 10 years is they have used screw caps if anything is joined but not sure about the outlet screw itself that holds the 3 wires.
Timecard is offline
post #25 of 437 (permalink) Old 03-29-2020, 03:39 PM
BOINC Cruncher
Diffident's Avatar
Thanks
3.
The difference in voltage between the 2 outlets could be because they are on different phases with different incoming voltages from the power company or the hallway circuit has a longer wire run creating voltage drop. But so far there isn't anything out of the ordinary.
The screw caps are called wirenuts, which are standard.
Boinc Desktop
(15 items)
CrunchAholic
(10 items)
NAS
(7 items)
AMD Ryzen 7 1700X
ASRock X370 Taichi
AMD Radeon VII
HyperX Predator
Samsung 970 EVOPlus
EVGA 850 G2
Operating System
Gentoo Linux
Alienware AW3418DW
Keyboard
Mouse
Roccat Kone EMP
Intel Xeon E5-2670
Intel Xeon E5-2670
Asrock Rack EP2C602
EVGA 1070ti FTW
EVGA 1070ti FTW
Samsung HD322HJ
Corsair AX1200
Rosewill RSV-L4000
Operating System
Gentoo Linux
i3-4130T
Operating System
Gentoo Linux
post #26 of 437 (permalink) Old 03-29-2020, 03:44 PM
mfw
ToTheSun!'s Avatar
Rep: 521 (Unique: 240)
Ok, I've watched both videos as attentively as I can at 0.12x speed 30 FPS, and I think I am seeing a slight added delay on the 2nd video. I'd like more people to check and confirm what I am seeing because I can be wrong. But it does look like it to me.
Now, in relation to the issues other users are experiencing: if you could find a solution so easily, when others couldn't after various attempts, it still could be the case, just as easily, that it is placebo. OP has the data and footage to prove it, but we haven't seen the same from others.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Model O- Glossy
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #27 of 437 (permalink) Old 03-29-2020, 03:54 PM - Thread Starter
Timecard's Avatar
Thanks everyone so far who has taken the time for good criticism and support. I can try and provide other video evidence if you think it will be more conclusive, I don't have 1000fps camera so currently limited there. I can get 1000fps in this game if that may benefit.
Timecard is offline
post #28 of 437 (permalink) Old 03-29-2020, 05:18 PM
OCN is bad civilization
Melan's Avatar
Rep: 122 (Unique: 91)
Quote: Originally Posted by ToTheSun! View Post
"Accuracy and timing feels significantly de-synchronized."
How is this any different from the other thread? I'm looking at the OP, but I'm not finding links to the 240 FPS videos. Though 500+ FPS videos would be ideal.
If a bunch of words is now "good documentation," I guess science won't save us in the end.
Imagine if people spent that effort into playing the game instead of looking for crutches.
Melan is online now
post #29 of 437 (permalink) Old 03-29-2020, 06:07 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
these are the hard hitting facts we need!
I'm pretty sure they've always been wirethings up until now, so I appreciate this. I've finally found something beneficial to self in one of these threads.
though, i never did get around to testing my mouse input curve. been meaning to do that for at least 10 years now.
Add me on Steam, same name
skupples is offline
post #30 of 437 (permalink) Old 03-29-2020, 06:38 PM - Thread Starter
Timecard's Avatar
I assume this is directed towards me, hello. I've been playing fps for roughly 15 years, 6 of which were competitive in multiple leagues both at medium and higher levels, and played about 12 lans in those 6 years my teams usually placing top 3. I've had this issue off and on throughout that time, I don't play competitively now but I'm trying to better understand what causes this.
When you have this problem your muscle memory isn't as sharp and depending 'when' you practice you're either practicing with the latency or without so when you cross that boundary and actually join a game you won't be as consistent. Although you can still get decent results through practice as you said and I completely agree, practice is a key component of consistency in anything you do. When the issue isn't present, the game becomes almost effortless because you don't have to spend the mental effort for compensating for varying timings of your input and instead focus on your surroundings and team play.
Not sure if you've played a lan or gone to your friends place and your sensitivity and game feels different than your home other variables aside (desk/chair etc), that's just the kind of the thing we're talking about here subtle or significant changes in your experience that impact your gameplay and prior preparation.
Feel free to give further constructive criticism.
Timecard is offline
