Is Higher DPI with low sensitivity better? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 58 (permalink) Old 04-05-2020, 01:34 AM - Thread Starter
Shaded War's Avatar
Rep: 180 (Unique: 154)
I'm actually having a hard time with understanding this. Maybe I'm missing something and not understanding. You mean it's normal to lift your mouse off your desk 2-3 times while swiping in order to turn around in a 360? This sounds terribly slow and doesn't make sense. You would be losing control of your mouse several times while you pick up your mouse.
My friend and his wife both use Razer Naga mice (2014 and molten edition) and they both play games at higher DPI than I do.
I tried to play with 800DPI in squad and it felt sluggish. The first firefight I got into at 15 meters got me killed because it was too slow. I even had the drop on them, started shooting and lost because I could track them walking to the side.
I tested Borderlands 3 just to see how it compared to squad. Without ADS, its 3.5cm and while ADS it was 7cm. These are rough measurements with a ruler on my desk. The mouse movement feels way better in this game so I think it might be game Squad itself. It's the only time I get the mouse is skipping pixels. It doesn't even do it on desktop.
Command Center 2.0
(14 items)
Intel i7-6800K
Asus Strix x99
Zotac GTX 1080 AMP
32GB Corsair Vengeance 3000Mhz
Samsung 970 Pro 1TB
Seagate 4TB HDD
Corsair AX850
Corsair H100i (original, not v1 / v2)
Corsair 600T
Operating System
Windows 10 Pro x64
3x Asus VE248Q
Samsung 55" 4K HDR Quantom Dot
Audio
Creative Titanium HD
Audio
Sennheiser HD700
Shaded War is offline
post #22 of 58 (permalink) Old 04-05-2020, 03:13 AM
mfw
ToTheSun!'s Avatar
Rep: 503 (Unique: 234)
It might be the case that something else entirely is creating the issue you're experiencing in Squad, especially considering you say other games are fine with roughly similar settings. What we're saying is that, regardless, we think your sensitivity range is limiting you in other ways.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #23 of 58 (permalink) Old 04-05-2020, 03:36 AM
Rep: 0
I think the game has ****ed up engine, nothing should be skipping because every old mouse has around 1800DPI
Aniela is offline
post #24 of 58 (permalink) Old 04-05-2020, 04:44 AM
numberfive's Avatar
Rep: 21 (Unique: 11)
as of today, in most games and with most mice you will be fine using 400-1600 and whatever sensitivity you select in-game.
there is no advantage or disadvantage to any configuration within this range, it is not better or worse.
while going above say 3200 cpi is a bit dumb.
Roach's declowning guide to the galaxy https://i.imgur.com/iz6WDUl.jpg
numberfive is offline
post #25 of 58 (permalink) Old 04-05-2020, 11:13 AM
Eikou's Avatar
Rep: 2 (Unique: 2)
So with your current extremely high sensitivity you'll be use to planting the wrist and making very tiny movements. So naturally if you lower that sens even to something most would consider high like 20cm/360 it will feel unusable. What most people that use moderate sensitivities do is use a combination of arm, wrist and some finger for different movements.
You'll need a reasonable mouse mat space like a qck+ if you wish to even try medium sensitivities. Some are gifted with high sensitivity but 3.5cm/360 is beyond that. I don't doubt you can hold your own, I used to play CS at 5cm/360 when I started and wasn't totally crap....but the change in my ability when going lower was night and day. Its worth exploring med to low sensitivities. You don't have to go nuts and switch to 50cm/360 but should certainly try something moderate down to like 30cm/360. And in order to test you'll need to do it for a few weeks. Move your arm and don't plant the wrist. It may be that its too low for you long term but you need real experience with a decent range to know what suits you.
Eikou is offline
post #26 of 58 (permalink) Old 04-05-2020, 01:06 PM
OCN is bad civilization
Melan's Avatar
Rep: 116 (Unique: 87)
Not really an engine's fault for razer forcing sensor damping on their PTE mice.
Melan is offline
post #27 of 58 (permalink) Old 04-06-2020, 02:38 PM
vf-
vf-'s Avatar
Rep: 5 (Unique: 5)
It's muscle memory. I don't have that issue at 400dpi both on desktop and game. You pick it up and place it so fast and you're hardly picking it up. Maybe 2 CDs at most. Even in Division 2 with 400dpi I use aim sens of 0.1.
vf- is offline
post #28 of 58 (permalink) Old 04-09-2020, 07:50 PM
senileoldman's Avatar
Rep: 13 (Unique: 13)
The problem is at 1800 and 1.0 is that it skips pixels, making it so when I move the mouse it's not possible to aim at a certain point. My mouse will skip 5 pixels at a time at distance. When I went to 16000 and .1, it made pixel by pixel moment possible where it didn't skip. Had nothing to do with my physical input.
It heavily depends on the game engine, as most games will skip pixels when the sensitivity is set to a value too high.
Set your dpi to 3600 and cut your sensitivity in half and see if it gets better. It doesn't have anything to do with your mouse sensor being x o y but your cm/360 being way too high and more sensible to input artifacts/granularity, as you cover more space in-game with less mouse movement; 3.2cm/360 is an incredibly high sens.
Every game engine skip pixels, but it's not as noticeable with low sens as it's with high sens, like yours. This gets more noticeable as your enter higher sensitivity values. Some game engines handle this much better than others, of course.
And don't listen to other people telling you it's way too high and you should change it, like they some kind of wannabe pros. If it's comfortable for you, keep using it.
senileoldman is offline
post #29 of 58 (permalink) Old 04-10-2020, 02:54 AM
Melan's Avatar
Actually it does. Since OP is using hella high sensitivity, any small movement would be horribly gimped by sensor damping forced on PTE sensors.
Pretty weird people here forgot the whole Phillips Twin-Eye vs opticals discussion thread.
Melan is offline
post #30 of 58 (permalink) Old 04-10-2020, 03:57 AM
mfw
ToTheSun!'s Avatar
If that kind of sensitivity were actually viable, you'd see professional players and streamers using it. Why move your arm and wrist any more than you absolutely have to?
It's perfectly legitimate to say his sensitivity is holding him back.
Intel 6700K
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Operating System
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
