WIFI routers & Wireless mice - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 06-01-2020, 11:09 AM - Thread Starter
killeraxemannic's Avatar
Rep: 225 (Unique: 199)
So I've got the Roccat Kain 200 sitting on my desk for testing and straight out of the box its a stuttery laggy mess. In the driver it has a place to show you the signal strength of the wireless and it kept bouncing between good and excellent. I could never get it to stay at excellent even with the receiver right on top of the mouse. My wifi router is only a few feet away so for experimentation purposes I disabled the wifi radios and the mouse started working flawlessly. Now I've been using the GPro wireless and the Viper Ultimate for quite a while in the same situation so it got me wondering how much being too close to a wifi router will actually impact the performance of a wireless gaming mouse. It's pretty obvious that Logi and Razer have the interference issues figured out a little better than Roccat but I would think if the interference is enough to stop the Kain 200 from responding sometimes it's gotta be impacting the performance of the other mice in some way. The mouse tester app charts look pretty good with either mouse and they don't have a signal strength indicator so it's hard to tell if they are seeing any interference or not. It may or may not be placebo but the Viper Ultimate seems more responsive with the wifi off.
AMD R9 3900x
Gigabyte X570 Arous Elite
MSI Gaming X GTX 1080
Gskill Ripjaws V 3600
Samsung 970 Evo Plus 1TB
Seasonic Prime 650w
Corsair H110i W/Phanteks F140MP Fans
Fractal Design Define R5
Dell SD2716DG 27" 144hz
Keyboard
Corsair K70 Rapidfire Mk2
Mouse
Glorious Model O
Mousepad
Logitech G640
Audio
Audio Technica ATH-AD900X
killeraxemannic is offline
post #2 of 24 (permalink) Old 06-01-2020, 11:33 AM
senileoldman's Avatar
Rep: 13 (Unique: 13)
That shouldn't never happen as there will always be wireless signals overlapping. Try setting your Wifi signal on a different channel and see if it works better, probably that mouse or design is faulty.
senileoldman is offline
post #3 of 24 (permalink) Old 06-01-2020, 11:34 AM
That should never happen as there will always be wireless signals overlapping. Try setting your Wifi signal on a different channel and see if it works better, probably that mouse or design is faulty.
post #4 of 24 (permalink) Old 06-01-2020, 12:11 PM
littledonny's Avatar
Rep: 77 (Unique: 69)
Move the router farther away. Even a few feet may clear it up.
littledonny is offline
post #5 of 24 (permalink) Old 06-01-2020, 01:53 PM
fourthavenue's Avatar
Rep: 5 (Unique: 5)
It happened to my wireless mice too. I have G305 G703 GPW G903. When it happens the cursor skips just like the battery is running out. But the battery is clearly almost full.
I can't turn off the 2.4GHz radio at my router, as my printer supports only 2.4GHz.
I changed the 2.4GHz channel to Channel 1 and it worked. They never skipped again by far.
Manage to run your games at 300+fps before you talk about mouse precision.
If you are still struggling to reach 100fps or if you are using some IPS/VA monitor, don' buy mice anymore. Save money and upgrade your whole rig.
If you don't know how to upgrade, just throw away your Ryzen 1st and 2nd gen, get latest Intel i7 i9 with "K", get 4000+MHz memory.
fourthavenue is offline
post #6 of 24 (permalink) Old 06-01-2020, 02:01 PM
r/wallstreetbets degen
elucid087's Avatar
Rep: 11 (Unique: 9)
No dual band? Honestly, just go back to wired.
Convenience comes as a compromise with wi-fi for gaming. You have a gpro wireless, which leads me to believe you're playing competitively (or at least you take it seriously enough to drop that kind of cash on two high-end mice). Using wifi pretty much negates having the "competitive edge" since latency will always be worse.
Enthoo Evolv TG :: Maximus X Hero :: i7-8700K :: H115i PRO RGB :: Trident Z RGB 32GB :: AORUS GTX 1080 Ti :: Samsung 960 EVO M.2 1TB :: Dell AW3418DW :: Sennheiser HD800S :: RME-ADI 2 FS
elucid087 is offline
post #7 of 24 (permalink) Old 06-01-2020, 04:51 PM
Mouse lover
ncck's Avatar
Rep: 110 (Unique: 77)
I'm right next to my router using the viper ultimate, not having any issues so far. However my logitech G703 would sometimes 'lose tracking' and then 'come back' which I believe was from interference from the router
I believe the same would sometimes happen with my GPW as well. I'm about 1-2 FT from my gateway/router. Unfortunately not much I can do besides grab some longer Ethernet cables and a power extender and just move it somewhere else in my room
I think these mice are just better at handling EMI/RFI - most likely due to using a certain channel or collision avoidance
ncck is offline
post #8 of 24 (permalink) Old 06-01-2020, 07:44 PM - Thread Starter
Not sure what you interpreted from my post but I always play hard wired on my desktop. The wireless router just happens to be near my desk in my office because I have the cable modem in my office. I shut off the wifi radios in the router to make it basically a wired router for testing.
AMD R9 3900x
Seasonic Prime 650w
Keyboard
Mouse
Glorious Model O
Mousepad
Logitech G640
Audio
post #9 of 24 (permalink) Old 06-01-2020, 09:50 PM
elucid087's Avatar
Rep: 11 (Unique: 9)
I realized that afterwards and felt like an idiot. Classic sleep deprivation taking its toll.
post #10 of 24 (permalink) Old 06-02-2020, 02:00 AM
Rep: 5 (Unique: 4)
All Razer mice since Mamba Wireless (2018) can frequency-hop upto 1000 times a second to always stay on a "clean" channel, which should allow for a much more reliable connection and shouldn't be affected by routers all that much. The most important factor in home setups to NEVER plug in wireless dongles directly into a USB 3 port of your PC (or any USB3 hubs in general). The USB 3 / 2.4G interference absolutely murders wireless performance.
While WiFi routers can also channel-hop, but they don't do it nearly as fast, and are generally less of an issue for wireless mice than USB3 hubs.
Razer_TheFiend is offline
