Is there a wireless usb hub in a existence? - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 10-20-2018, 06:22 PM - Thread Starter
AMD Fanboy Using Nvidia
vmatt1203's Avatar
Rep: 18 (Unique: 17)
I want a wireless usb hub that transfers usb device connection wirelessly back to the pc. i.e. plug in a wired keboard or headset to the hub then over bluetooth/ir/wifi transmitit back the the pc across the room. Google only gives me usb Wi-Fi adapters. Same with Amazon. The only product I can find even remotley close is a product from china on eBay. Please dont lecture me on latency. I know it would be high.
vmatt1203 is offline
post #2 of 4 (permalink) Old 10-20-2018, 06:46 PM
Overclocking Enthusiast
ozlay's Avatar
Rep: 288 (Unique: 227)
You might be able to use a powerline adapter? I know you can convert usb to Ethernet. But iv never tried it over a powerline adapter.
However you use to be able to get a wireless usb hub. However I don't think they make them anymore.
https://www.amazon.co.uk/Belkin-F5U3.../dp/B000LP9RQC
https://www.amazon.co.uk/IOGear-Wire.../dp/B0026M9Y2K
Rikka
(9 items)
Intel I5-7600k
Asrock Z270M Extreme 4
Titan X
Gskill Royal
970 Evo
Optane 900p
Seasonic Prime Snow
enthoo evolv matx tempered glass
Operating System
windows 10 pro
ozlay is offline
post #3 of 4 (permalink) Old 10-20-2018, 08:24 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1430 (Unique: 725)
Because bluetooth does the same thing with less latency.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
The Pook is offline
post #4 of 4 (permalink) Old 10-20-2018, 08:54 PM
Canada Goose Puncher
CynicalUnicorn's Avatar
They exist but they're difficult to find. Try searching for "USB transmitter" and you'll get some results for discontinued products that seem to have worked. Reviews are mixed, but for certain USB device types it's fine. You could also use a software solution over WiFi and use a basic single-board computer (e.g. a Raspberry Pi) as the hub. It's rather expensive but the USB2BT is an option for USB HIDs; I do not know if a hub or headset would work however.
There are options out there, but hardware is expensive and tricky to find. Ebay isn't very helpful because it's flooded with so many Chinese wireless adapters or short-range transmitters for cars that contain a USB port for charging.
Powerline is evil in my experience and I would advise avoiding it if possible. Plus, it doesn't do a great job eliminating all cable clutter.
I think a lot of USB to Ethernet adapters just use standard CAT5e cables since they're designed for such long distances. Other connections like HDMI can also be crammed down Ethernet, though judging by the single RJ45 jack there I think those devices are a bit more complicated than a dumb adapter that uses better twisted pairs.
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
