140mm Loud Noctua Fan? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 01-15-2019, 02:47 PM - Thread Starter
kaivorth's Avatar
Rep: 435 (Unique: 364)
Did I make a mistake? Installed a U12SE cooler. Great quiet cooler.
Figured why not get a 140mm Noctua Chassis fan for improved airflow and silence.
https://www.amazon.com/gp/aw/d/B00CP...?ie=UTF8&psc=1
According to my BIOS, the CPU Cooler 120mm fan runs at 800-1000rpm and I can't hear it.
140mm fan running about the same and it's loud. Installed the low noise adapter and set the BIOS to silent mode to finally tame it. Is this normal? I thought these were supposed to be quiet.
My System
(12 items)
Ryzen 5 1600
Asrock B350 Fatal1ty ITX
Asus GTX1060
G.Skill 8gb 3000mhz
250gb Samsung 850 Pro
Optical Drive
SATA LG DVD Burner
EVGA 500w Gold
EVGA Hadron Air
Operating System
Windows 10 Pro X64
23" Asus 144hz
Keyboard
Microsoft Ergonomic 4000
Mouse
Logitech G Pro
kaivorth is offline
post #2 of 3 (permalink) Old 01-15-2019, 04:01 PM
deepor's Avatar
Rep: 484 (Unique: 329)
Yeah, in my opinion those 140mm fans are getting loud at around 800 rpm when in a quiet room. I try to keep things below 800-900rpm for them.
Those 800-900rpm 140mm speeds I'm thinking about are for the worst case situation at full load. I try to set up the fan curves so that I get 400rpm when idle, and perhaps 600rpm for tasks that are making things a bit hot but where I'm not wearing headphones, then 800rpm for full load with a game with stressful graphics card use where I'm wearing headphones.
Meanwhile, I have 120mm fans that can be a good bit faster without being noticeable over the 140mm fans in the case. For example 1100rpm on "quiet" 120mm fan seems to compare well to 800rpm on a "quiet" 140mm fan.
When I was listing those speed settings I like for 140mm size, those were for the following fans that all use a similar shape for the fan blades: Thermalright TY-147, Noctua NF-A14, BeQuiet Silent Wings 3, Corsair ML-140. I've tried 3/4 of those and they all seem to get annoying for me personally at 800-900rpm. They do all work well with regards to performance, they are strong for the noise they make and seem to indeed be the best "quiet" fans you can get for getting fresh air into the case.
A thing that can sometimes happen if you are unlucky, there can be strange effects with air turbulence because of metal parts being in the way somewhere in front of the fan, or the dust filter interacting weirdly, or there can be vibrations getting amplified by the metal. You could try to experiment a bit, like check out the fan alone sitting on your mouse pad while connected to motherboard in the open PC case.
deepor is online now
post #3 of 3 (permalink) Old 01-16-2019, 10:42 AM - Thread Starter
kaivorth's Avatar
Yeah I'm still playing with it. Might try zip tying some wires away from airflow path.
My System
(12 items)
Ryzen 5 1600
Asus GTX1060
G.Skill 8gb 3000mhz
Optical Drive
SATA LG DVD Burner
EVGA 500w Gold
EVGA Hadron Air
Operating System
Windows 10 Pro X64
23" Asus 144hz
Keyboard
Mouse
Logitech G Pro
kaivorth is offline
