RGB Connectors are Loose? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 03-02-2019, 04:00 PM - Thread Starter
Rep: 0
I'm trying to use an RGB splitter to connect all my RGB to my one four pin RGB header on my mobo (c'mon Asus!, just one?!?) and when I use the splitter it slides very easily off the four pin connectors on the header and at the cable connections to other RGB devices. IS there a way to tighten up the contact points on these connectors? They almost seem too thin for the conductors. maybe I should just use four small conductors of a different copper wire size instead?
BuildOne
(8 items)
Core i9-7900X
Thermaltake Core P5 - Tempered Glass - Black
Asus Prime X299-Deluxe
EVGA GTX 1080 FTW
G. Skill Trident Z RGB 3200
Samsung 970 Pro M.2
Corsair HX 1200i
EKWB
Bighouse is offline
post #2 of 3 (permalink) Old 03-02-2019, 04:27 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Is the issue with the splitter or the header? If it's just the splitter that won't hold on I'd say you just need a different splitter.
You can't really tighten a pin unless you disassemble the plug and crimp the pin a little tighter. Or just splice everything into a connector that does hold up.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 3 (permalink) Old 03-02-2019, 04:29 PM
jonkrmr's Avatar
Rep: 4 (Unique: 4)
Had the same problem with the RGB header pins on my mother board also.
I just slightly bent one of the outer pins on the header so it gave an interference fit on the cable I am using to connect to the header.
jonkrmr is offline
