Memory Card Reader help - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 03-03-2019, 05:29 AM - Thread Starter
Gilgamesh9's Avatar
Rep: 1 (Unique: 1)
I Need a Memory card reader for my Desktop computer
I have some photos on SDcard from my camera and a microsd also
I will only use Microsd and SD card transfer it to my PC
My Pc is Windows 7 Pro without Sp1 (no upgrade i want to do right now)
Can i use this Memory card reader Kingston FCR-HS4
https://www.kingston.com/en/flash/re...S1vgxHTqw2DMxM
This is what worry me it say under compatbility
windows 7 but with Sp1, and i dont have Sp1 (click specs on the link above)
Will the card reader still work on Windows 7 without Sp1?
Also can i conect it to USB2 ports (it come only with Usb3 cable)
will it work on Usb2 i know is slower but will it work
I have not purchased it yet so can someone check it out for me
So 2 questions
1. Will it work on My Pc windows 7 profesional without Sp1
2. can i conect it to Usb2 with the suplied usb3 cable and it will work (slower is ok) ?
Gilgamesh9 is offline
post #2 of 3 (permalink) Old 03-04-2019, 02:31 AM - Thread Starter
Gilgamesh9's Avatar
Rep: 1 (Unique: 1)
I talked with Kingston but Not even Kingston can give me an answer
Kingston say card reader have not been tested on Windows 7 without Sp1
so they cannot guarantee it work.
That answer from Kingston is not not good company not know
post #3 of 3 (permalink) Old 03-04-2019, 06:06 AM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 533 (Unique: 335)
If you have been keeping up with Win 7 updates from Microsoft for at least up to April of 2010, your copy of Win 7 will be the equivalent of SP1. SP1 just has updates prior to its release in March of 2010 rolled into the installation.
The card reader you linked should work just fine. What I don't like about it is you have to set down on a desk surface and connect it to the USB port on the computer with a cable. If you don't like that either, the MobileLite G4 listed above in your link should work as well and can be plugged directly into a USB port. Kingston makes pretty good products. I haven't had one fail on me yet and I have a couple of dozen of their flash drives, several camera cards, and eight sticks of RAM in my old desktop (I gave that RAM away after the old desktop died). Their only downside is their budget flash memory tends to be a bit on the slow side (you get what you pay for).
Note my use of the word should. I haven't actually used them so I can't honestly recommend them with 100% certainly though I've had enough experience with card readers in general to judge if something should work for a particular application. Most companies will not recommend their products for certain applications unless they have actually tested them on those applications. The ones that will recommend products on untested applications are the ones I wouldn't trust. Kingston was being completely honest with you and their recommendations can be trusted. If you're ever in doubt about a product, buy it from a company that has a generous return for refund policy.
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
