Need help on UPS selection - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 04-12-2019, 09:13 PM - Thread Starter
SneezyPepper's Avatar
Rep: 9 (Unique: 9)
Hi guys, need your help. I need a UPS just to properly shutdown the computer during power outages.
How many watts and VA of UPS do I need for this pc:
Amd Ryzen 7 2700x
Gigabyte GA-X470-Aorus-Ultra Gaming
G.Skill Trident Z RGB 64GB
Zotac GTX 1070 Ti Mini 8GB GDDR5 256bit
samsung 970 evo m.2 nvme 250gb
2pcs Samsung 250gb SSD
Seagate 2TB HDD
Seasonic Focus+ 750PX 750watts 80+ Platinum full modular
6pcs 120mm fans
23" Asus ProArt 238Q Monitor
Thanks in advance.
SneezyPepper is offline
post #2 of 7 (permalink) Old 04-13-2019, 12:10 AM
rdr09's Avatar
Rep: 891 (Unique: 643)
Im using a 220V version of this ups on one of my Ryzen systems and works well even when the system is fully loaded gaming. Power loss is quite frequent in the area where i live. Been serving for more than three years now.
https://www.newegg.com/Product/Produ...82E16842111461
I recommend it.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #3 of 7 (permalink) Old 04-13-2019, 10:47 AM
Rep: 0
I have a old ups backup and wanted to replace it maybe they go on sale and had longer warranty.
windsurf is offline
post #4 of 7 (permalink) Old 04-14-2019, 06:40 PM - Thread Starter
Rep: 9 (Unique: 9)
Will this be able to handle my PC specs:
Product details of APC BX1100LI-MS 1100VA UPS:
Output Power Capacity: 550 Watts/1100 VA
Max Configurable Power: 550 Watts/1100 VA
Nominal Output Voltage: 230V
Output Connections2) IEC 320 C13 (Battery Backup) (4) Universal Receptacle (Battery Backup)
Nominal Input Voltage: 230V
post #5 of 7 (permalink) Old 04-16-2019, 02:34 AM - Thread Starter
Rep: 9 (Unique: 9)
post #6 of 7 (permalink) Old 04-16-2019, 02:46 AM
21Dante's Avatar
Rep: 1 (Unique: 1)
It will.However not for very long,especially under load.
If you are always there however and need 3-4 minutes to just save your work and shut it down,it will be okay.
21Dante is offline
post #7 of 7 (permalink) Old 04-16-2019, 11:39 PM
rdr09's Avatar
^this. That should work. I also have an APC UPS. A 650VA that allows a system to shutdown properly even at full load. It has an intel i7 2700K stock and a GTX 1050 in it. So, with your system spec that APC should hold up. The battery on mine did not last though. Thankfully it was easy to find and replace.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
