Can't determine why PC won't turn on - Overclock.net - An Overclocking Community
post #1 of 28 (permalink) Old 05-27-2020, 05:20 AM - Thread Starter
LetterofTheDay's Avatar
Rep: 0
Sorry if I posted this on the wrong subforum,
I am a super beginner with PC building and back in march I built my own rig using these parts I regrettably got off of Newegg:
MOTHERBOARD//
GIGABYTE X570 UD AMD Ryzen 3000 PCIe 4.0 SATA 6Gb/s USB 3.2 AMD X570 ATX Motherboard
https://www.newegg.com/gigabyte-x570...82E16813145168
PROCESSOR//
AMD RYZEN 7 3700X 8-Core 3.6 GHz (4.4 GHz Max Boost) Socket AM4 65W 100-100000071BOX Desktop Processor
https://www.newegg.com/amd-ryzen-7-3...82E16819113567
CPU//
CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model CMK16GX4M2B3200C16
https://www.newegg.com/corsair-16gb-...82E16820233859
GPU//
MSI GeForce GTX 1660 Ti DirectX 12 GTX 1660 TI VENTUS XS 6G OC 6GB 192-Bit GDDR6 PCI Express 3.0 x16 HDCP Ready Video Card
https://www.newegg.com/msi-geforce-g...82E16814137392
1st POWER SUPPLY (replaced because I thought this was causing the pc to not turn on)//
CORSAIR CX Series CX550 550W ATX12V / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
https://www.newegg.com/corsair-cx-se...82E16817139202
Current POWER SUPPLY (The shape of the connectors for the pins don't have the same shape as shown on the mobo but it fits in anyway. I dunno if this is a big deal)//
Thermaltake Smart 600W 80 PLUS ATX12V 2.3 Power Supply
https://www.amazon.com/Thermaltake-C.../dp/B014W3EMAO
PHOTOS//
https://cdn.discordapp.com/attachmen...525/image0.jpg
https://cdn.discordapp.com/attachmen...248/image1.jpg
https://cdn.discordapp.com/attachmen...638/image2.jpg
https://cdn.discordapp.com/attachmen...077/image3.jpg
https://cdn.discordapp.com/attachmen...562/image4.jpg
I do not know what is causing this thing to not turn on but I have tried removing parts little by little and trying to power this thing on so I am not sure if it is anything but the motherboard at this point. Whether I plug this thing into a wall socket or a conductor it just won't turn on. I also tried taking out and re-inserting the silver circle thing on the motherboard.
LetterofTheDay is offline
post #2 of 28 (permalink) Old 05-27-2020, 05:41 AM
rdr09's Avatar
Rep: 892 (Unique: 643)
The power cable (big one ATX) is foolproof. It won't go in if orientation is wrong. For the CPU cooler fan, both fan risers will work i know but to make sure use the one on top.
Now, the PWR Switch in the front panel header, i am not sure if it is plugged the right way. I know the label should be showing. Check it out. For that riser, i only use the power switch. Less messy.
EDIT: The power for the graphics card seems not aligned properly. Line them up before inserting. They will look like one piece.
By Built-in Benchmark Queen:
My 2.5 years old delidded 7980xe @ 4600mhz all core with 49ns memorylatency (4000c16 twekaed) is faster than 3950x max overclocked on water in every scenario. Pretty good for a ancient cpu
In gaming it has no chance vs my new 10900k @ 5400mhz and 4600c16 tweaked memory. ~35ns memorylatency.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #3 of 28 (permalink) Old 05-27-2020, 05:51 AM - Thread Starter
Rep: 0
Thanks for checking! The plug that you showed, I tried it both ways top and bottom and it won't turn on, but I left it switched to show the letters like you mentioned. As far as the Fan Risers go, I'm sorry but I don't know what that is.... :[
post #4 of 28 (permalink) Old 05-27-2020, 05:54 AM
rdr09's Avatar
Here is the manual. In page 4 you will see Fan 3. Just want to make sure. See page 16 for the pwr switch. You should see the label when plugged.
https://download.gigabyte.com/FileLi..._x570-ud_e.pdf
Also, are you sure you turned on the power for the PSU?
EDIT: Seeing other things wrong now. The GPU it seems is not properly installed. It should plug in straight just like the rams, then bolt it down. Keep those wires away from the fans.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #5 of 28 (permalink) Old 05-27-2020, 05:59 AM
newls1's Avatar
Rep: 46 (Unique: 34)
jumper the damn header with a screw driver, see if it turns on... really simple
**Intel System** Asus Z390E Strix / 8700k @ 4.85Ghz / 32GB BDie @ 3200 CL14 / PowerColor 5700XT / eVGA 850w PSU / Sammy 960 EVO m.2 / MX500 250gb games SSD / 49" Samsung UltraWide 144Hz
**Games Only** Asus Maximus Formula XII / i9 10900k @ 5.3GHz / 32gb 4x8GB Patriot Viper DDR4 4400 @ 4133 / 2080Ti / Everything watercooled using Dual Loops and many 420mm rads
newls1 is offline
post #6 of 28 (permalink) Old 05-27-2020, 06:23 AM - Thread Starter
Rep: 0
I just unscrewed it to take it out recently and see if it was part of the problem. Screwed in or not the compooper won't turn on. There's actually this cord from my power supply I have no clue where it goes but the manual says it's a Floppy Connector.
Also rdr09, I didn't notice a Fan3 on the manual or the motherboard, I'm squinting, I'm breathing slowly, I'm concentrating all my chakra to my eyes and I'm not noticing it.
post #7 of 28 (permalink) Old 05-27-2020, 06:29 AM
newls1's Avatar
i never at any point said to "unscrew" the board from the case... i said jump the header pins with a screw driver
newls1 is offline
post #8 of 28 (permalink) Old 05-27-2020, 06:34 AM
Bench, Dead, Squat
Bad5ector's Avatar
Rep: 25 (Unique: 17)
Quick question, you installed the stand offs before mounting the motherboard right? You aren't screwing that straight to the case? If so, there is your problem.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #9 of 28 (permalink) Old 05-27-2020, 06:36 AM
rdr09's Avatar
My bad. It's on Page 12. Don't worry about the Floppy Connector.
2nd AMD Build
(10 items)
2700
470
5700
3466/14
1000
700
Operating System
10/64
55/2160
Keyboard
M100
rdr09 is offline
post #10 of 28 (permalink) Old 05-27-2020, 06:37 AM - Thread Starter
Rep: 0
Oh sorry, I was confused at first. Which header? https://download.gigabyte.com/FileLi..._x570-ud_e.pdf Page4 just say which one and I'll tell ya what happened
Tags
Build In Progress , Motherboard , Power Supply
