Air compressor to clean PC? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 36 (permalink) Old 04-03-2011, 12:38 AM
Rep: 117 (Unique: 57)
[ame="http://www.amazon.com/Metro-Vacuum-ED500-500-Watt-Electric/dp/B001J4ZOAW/ref=sr_1_2?ie=UTF8&qid=1301814989&sr=8-2"]Amazon.com: Metro Vacuum ED500 DataVac 500-Watt, 0.75-HP Electric Duster: Home Improvement[/ame]
Had this for 6 months, it is awesome!! You will not be dispointed!!
H969 is offline
post #12 of 36 (permalink) Old 04-03-2011, 12:40 AM
DV9
DV9's Avatar
Rep: 19 (Unique: 19)
Dude I just use my large shop compressor and the appropriate attachment, blows all the dust to the next dimension. Just make sure to test the air on yourself first, make sure it isn't moist.
Currently scraping together funds for an E350 HTPC build, FT03 (Garbage Bin wink.gif) here I come!
DV9 is offline
post #13 of 36 (permalink) Old 04-03-2011, 12:46 AM
Rep: 61 (Unique: 60)
If you use a compressor make sure you keep the line pressure set below 10psi to avoid moisture from the tank migrating through the line.
I do this on mine and never worry about moisture touching my components.
vspec is offline
post #14 of 36 (permalink) Old 04-03-2011, 12:52 AM
Rep: 9 (Unique: 9)
As I live in a pretty dry area, moist isn't a problem. If some creates inside the compressor's tank, just discharge it from the bottom valve a couple of times and let it refill.
I have cleaned my pc with an air compressor since years, even blasting at 120 psi (8atm), never had a problem, dust went off perfectly.
camera.gifNikon D90 | 18-105 VR | 50mm F/1.8 AF
Andrea87 is offline
post #15 of 36 (permalink) Old 04-03-2011, 12:55 AM
Rep: 231 (Unique: 209)
I just use my Dads compressor. Not sure how powerful it is in numbers but it gets dust out.. that's for sure. ^^
~GMX
Steam - gotmaxpower (I play Counter Strike and Killing Floor a lot)
GoTMaXPoWeR is offline
post #16 of 36 (permalink) Old 04-03-2011, 03:47 AM
Compressor users be carefull!!
Where I live in the north east the compressor tanks get water from condenstate!!!
If you do notice the water and let it dry before starting your rig, it most likly will be rusty water, that will make some bad stains!!
H969 is offline
post #17 of 36 (permalink) Old 04-03-2011, 03:55 AM
Rep: 83 (Unique: 68)
+1 for air compressers I hate stupid a55 cans of compressed air , if you dont do it right it can blow water. My friend has used his air compresser for yrs ! ( no problems) I take my rigs over to clean em when i can!
Ps i just bought a stupid can the other day for $7 and got it home ( no straw ) arggggggggg
MIKEVALL is offline
post #18 of 36 (permalink) Old 04-03-2011, 04:21 AM
fabrizziop's Avatar
Rep: 12 (Unique: 11)
I use a cheap air blower, costed me aprox 20$. It's cheap and chinese, blows hot air and it's very loud, but for removing the dust from your pc it's very nice.
fabrizziop is offline
post #19 of 36 (permalink) Old 04-03-2011, 08:20 AM
vspec is offline
post #20 of 36 (permalink) Old 05-06-2011, 09:52 AM
Bellagiofan's Avatar
Rep: 2 (Unique: 2)
Originally Posted by fabrizziop;12981834
It's cheap and chinese, blows hot air and it's very loud.
Bellagiofan is offline
