Air compressor to clean PC? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 05-07-2011, 05:27 PM
dmbjohn's Avatar
Rep: 41 (Unique: 40)
you can always get a pressure regulator and water trap for an air compressor.....which if you spray paint ever you'd probably already own anyway.
works great for me.
Peace!
John
"I only know a snowflake cannot exist in a storm of fire."
MICHIGAN OVERCLOCKERS
dmbjohn is offline
post #22 of 36 (permalink) Old 05-07-2011, 05:32 PM
saiyanzzrage's Avatar
Rep: 56 (Unique: 44)
Originally Posted by Bellagiofan;13404776
ROFLMAO, this my friend, is the definition of sig-worthy
“I am what was, what is, what will be — the black angel, Chaos-Bringer! I AM POWER!” Dark Phoenix, Uncanny X-Men #136
saiyanzzrage is offline
post #23 of 36 (permalink) Old 05-07-2011, 05:33 PM
Rep: 159 (Unique: 147)
Yes it's fine. Just run the thing for like 2 minutes to make sure theres no moisture droplets in the tank.
SpeedNuggeT is offline
post #24 of 36 (permalink) Old 05-07-2011, 05:38 PM
Senior Moderators
pioneerisloud's Avatar
Another vote on the Metro Vac. One of the better investments for cleaning you'll ever make. thumb.gif
Big Air Compressor Users:
Be careful using those things. Make sure you drain the tank before you use it on a machine (to make sure there's no water). There's a drain plug on every air compressor I've ever used. And then, you should also be able to limit the pressure output. I personally use around 60-75 PSI at most for computer hardware. Any more, and it runs the risk of blowing parts off the board. eek.gif
DisposalAreav4.0
(15 items)
BayMax
(10 items)
FanzGoBrrr
(10 items)
Intel Core i7 2600k @ 4.65GHz, 1.45v (105.68x44)
Gigabyte Z68MA-D2H-B3
Asus RX580 8GB @ 1425 / 2150
Kingston HyperX (4x4GB) @ DDR3-1690, 9-9-9-24-1T, 1.66v
Crucial MX100 256GB + Sandisk Ultra 240GB RAID0 (400GB)
Toshiba 3TB 3.5"
Seasonic M12II Evo 520w
CoolerMaster 240mm
DIY PC Cuboid Blue mATX
Operating System
Windows 10 Pro x64
Hanns G 23" 1080p / 60Hz
Keyboard
Redragon 10 keyless
Mouse
Logitech Optical Mouse USB
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
Intel Xeon E5-2608L v3 x2
SuperMicro X10DRL-I
Onboard
16GB (4x4GB) DDR4 ECC / Registered
Crucial BX500 120GB
40TB FreeNAS Array
CoolerMaster MasterWatt 750w
Arctic Cooling 92mm Tower x2
P Link USA 20 Hotswap Bay 4u Chassis
Operating System
FreeNAS
Intel Xeon E5-2683 v4 16 core x2
SuperMicro X10DRL-I
120GB Crucial BX500
1TB Crucial BX500
Toshiba 3TB 7200RPM x2 (RAID 1)
CoolerMaster Masterwatt 750w
P Link USA EATX Locking Front 4u Chassis
Operating System
Windows 10 + VMWare
pioneerisloud is offline
post #25 of 36 (permalink) Old 05-07-2011, 05:41 PM
fishhawk's Avatar
Rep: 57 (Unique: 52)
Yes the regulators work to apoint-but if you do own one and have painted cars-harleys and trucks for 30 years you now there is always a chance of moisture coming through. Yes you can use one-but it is never %100 safe-a burst my come through at any time. Ya i do know for a fact-brother owns harley shop other bro owns auto motive shop-, plus cutom painting.
fishhawk is offline
post #26 of 36 (permalink) Old 05-08-2011, 07:57 PM
TowelieTowel's Avatar
Rep: 2 (Unique: 2)
I just open my case and stick a vvacuum cleaner in there to suck up all the dust.
TowelieTowel is offline
post #27 of 36 (permalink) Old 02-10-2013, 11:16 PM
hayabura's Avatar
Rep: 0
thank you
air compressor
hayabura is offline
post #28 of 36 (permalink) Old 02-27-2013, 01:19 PM
burdebc's Avatar
Rep: 0
I've often used a pancake compressor (like contractors often use) to clean out my computer and it did work. However, I would recommend limiting the pressure because I have had fan blades break off before. I can't be certain if it was due specifically to using too much pressure or the fans were just old and cheap. The last time I cleaned my computer I just used an old toothbrush, a qtip, and my own breath. Pulling fans and cleaning them manually is the best way to ensure you don't damage anything.
burdebc is offline
post #29 of 36 (permalink) Old 02-28-2013, 10:23 AM
attca2k's Avatar
Rep: 0
attca2k is offline
post #30 of 36 (permalink) Old 07-11-2019, 06:40 PM
Hardware veteran
burning_ac1d's Avatar
Rep: 0
buying an air compressor will be cheaper than buying can after can after can.
Im not sure how strong it should be.
how much capacity (l/m) and how much max pressure (bar) should be fine ?
im thinking in getting this: (sorry its in swedish, just look at the details and numbers)
http://biltema.se/sv/Verktyg/Trycklu...pressor-15195/ Batteridriven kompressor
or this:
http://www.clasohlson.com/se/Kompres...24/Pr408310000 Kompressor Cocraft 24
will buy a filter too to be safe from condensation.
anyone using one of this?
burning_ac1d is offline
