Air compressor to clean PC? - Page 4 - Overclock.net - An Overclocking Community
post #31 of 36 (permalink) Old 07-11-2019, 07:25 PM
Vandelay Industries
maltamonk's Avatar
Rep: 85 (Unique: 63)
Quote: Originally Posted by burning_ac1d View Post
buying an air compressor will be cheaper than buying can after can after can.
Im not sure how strong it should be.
how much capacity (l/m) and how much max pressure (bar) should be fine ?
im thinking in getting this: (sorry its in swedish, just look at the details and numbers)
http://biltema.se/sv/Verktyg/Trycklu...pressor-15195/ Batteridriven kompressor
or this:
http://www.clasohlson.com/se/Kompres...24/Pr408310000 Kompressor Cocraft 24
will buy a filter too to be safe from condensation.
anyone using one of this?
Idk it's at least 6 yr old necro.....lol. Your basic run of the mill garage air compressor will be just fine as long as you periodically drain the tank/s. If you're extra worried you can get a moisture trap....all for the price of a data vac or whatever and have all the extra uses of a real tool.
maltamonk is offline
post #32 of 36 (permalink) Old 07-11-2019, 07:32 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1453 (Unique: 733)
ignoring the necro, you should drain your tank regularly and have an oil/water inline filter on your line. they sell disposable ones for ~$2 at Harbor Freight if you wanna cheap out on it and they work fine.
no matter how much you drain the tank, try and use a paint gun without an oil/water filter
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #33 of 36 (permalink) Old 07-11-2019, 07:36 PM
Vandelay Industries
maltamonk's Avatar
Yeah I don't paint using them, but recognize the importance. I just think datavacs are overpriced and marketed to suckers.
post #34 of 36 (permalink) Old 07-11-2019, 08:07 PM
nlitworld's Avatar
Rep: 0
I use my compressor all the time for cleaning out components. The only time you would need to worry is if you have a large oil-lube compressor and you're running it super hard in a humid environment without training the tank. Other than that, most smaller (>40gallon) compressors will be oil-free and all you need to do is not run it super hard before hand and drain your tank regularly. No big deal about moisture separator for that small of usage.
On a side note about those harbor freight orange ball filters; as someone who sells auto paint and body shop materials, those filters do about as much to clean your air as a cigarette filter does to keep you from getting cancer. Buyer beware.
My other car is your mom.
Work in progress
(17 items)
I7-6700K
ASRock Z170 Extreme 7+
EVGA GTX 1070 FTW
EVGA GTX 1070 FTW
G Skill Ripjaw V 3200
Samsung 960 Evo
Samsung 850 Evo
WD Blue
Optical Drive
Samsung DVD/CD Writer
EVGA G1+ 1000W
Corsair H100I v2
Corsair ML120 case fan
BeQuiet Silent Wings 3 PWM High Speed
NZXT Phantom 410
Operating System
Microsoft Windows 10
Other
EVGA Power Link
Other
EVGA Power Link
nlitworld is offline
post #35 of 36 (permalink) Old 07-14-2019, 02:55 PM
Leopardi's Avatar
Rep: 21 (Unique: 21)
Just get one of these in 2019 They're around 50€ a piece in sales for the xpert unit, which will be even more powerful than canned air.
Leopardi is offline
post #36 of 36 (permalink) Old 07-14-2019, 02:59 PM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
Air compressors often throw water out not a good thing to use on electronics
Electric blower of any sort is better.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
