[sisoft] Possible GM200 specs leak - Overclock.net - An Overclocking Community
post #1 of 55 (permalink) Old 11-09-2014, 11:58 PM - Thread Starter
Alatar's Avatar
Rep: 249 (Unique: 218)
Graphics Device (3072SP 24C 1.1GHz/1.39GHz, 3MB L2, 12GB 6GHz 384-bit) (OpenCL)
1100MHz
24CU
Source
Will update the thread when I see an actual article with this. Seems like GM200 will be GM204 + 50% + DP. Will be interesting to see how the final cards clock. The one being tested here is probably an ES for a pro card.
Alatar is offline
post #2 of 55 (permalink) Old 11-10-2014, 12:03 AM
Clocknut's Avatar
Rep: 101 (Unique: 60)
600-650Mm2 size confirmed. lol
Gaming Rig
(10 items)
Work/Web Rig
(12 items)
i5-2500K @4.1GHz stock volt OC
Asus P8Z77-V LK
Zotac GTX 1660Ti AMP
Corsair Vengence 1600MHz_CL8 4GBx4
Kingston UV500 480GB SSD
Maxtor 250GB 7200rpm
Xigmatek Dark Knight
Silverstone Ps06
Operating System
Windows 10 Pro
BenQ XL2720z @ 1920x1080 144Hz
Core 2 Quad Q9650
Gigabyte EP41-UD3L
Asus 1GB Radeon 7790 DirectCU OC
Corsair Gaming Ram 2GBx2 DDR2-800
Seagate Barracuda 250GB SSD
Samsung 80GB 7200rpm
Western Digital 200GB 7200rpm
FSP Hyper K 600w 80+
Cooler Master Hyper TX3
LianLi PS05
Operating System
Windows 10 pro
Samsung 226bw 1680x1050
Clocknut is offline
post #3 of 55 (permalink) Old 11-10-2014, 12:13 AM
raghu78's Avatar
Rep: 1084 (Unique: 711)
yeah most likely closer to 650 sq mm. must be a beast of a performer. thumb.gif
Originally Posted by Alatar View Post
Source
GM200 will be most likely GM204 + 35% perf . Nothing scales perfectly. Also clocks will be lower on GM200 vs GM204. The Quadro/Tesla specific features and double precision will add die size too. So expect this chip to be >50% increase over GTX 980. most likely closer to 650 sqmm.
raghu78 is offline
post #4 of 55 (permalink) Old 11-10-2014, 12:15 AM
nyxagamemnon's Avatar
Rep: 80 (Unique: 61)
3072SP 1400Boost 12GB Ram lol. This would decimate whatever currently out. Although I wonder why 6GHZ vs 7?
nyxagamemnon is offline
post #5 of 55 (permalink) Old 11-10-2014, 12:20 AM
Clocknut's Avatar
Gaming Rig
(10 items)
Work/Web Rig
(12 items)
Asus P8Z77-V LK
Silverstone Ps06
Operating System
Windows 10 Pro
Core 2 Quad Q9650
Gigabyte EP41-UD3L
LianLi PS05
Operating System
Windows 10 pro
Clocknut is offline
post #6 of 55 (permalink) Old 11-10-2014, 12:22 AM - Thread Starter
Alatar's Avatar
Specs, not perf. Thought it would have been relatively clear since I included DP in there.
That said with 50% more memory bandwidth, 50% more SMMs and 50% more ROPs I actually do expect to see more than 35% higher perf when OC'd. Probably not at stock. I'd imagine NV is going to go air cooling and reference GM200 will probably have quite bad throttling.
Alatar is offline
post #7 of 55 (permalink) Old 11-10-2014, 12:30 AM
Hitoseijuro's Avatar
Rep: 2 (Unique: 2)
The price tag on this beast is going to be nuts if those numbers are even close to being correct spec-wise. 1500-2000 probably? Core for Core Maxwell is already 40% stronger than Keplar is not to mention this is coming in with 3072 vs 2800s on the GK110, on top of stock clock being 1100 with a boost of 1400 just out of the box. However, this is just speculation we dont really know anything outside of the numbers they are showing.
█▓▒█▓♦ [Official] NVIDIA GTX 980 Owner's Club ♦█▓▒█▓
ASUS SABERTOOTH CLUB
Hitoseijuro is offline
post #8 of 55 (permalink) Old 11-10-2014, 12:31 AM
raghu78's Avatar
Can you confirm the source for 50% more ROPs. btw your OP says 384 bit 6 Ghz memory. so it remains to be seen how much bandwidth increase is, though I doubt Nvidia would increase shaders by 50% while increasing memory bandwidth by just 30%. This would mean GM200 has less bandwidth per shader than GM204. I can see Nvidia running the Quadro/Tesla models at 6 Ghz while running the Geforce models at 7 Ghz as it does with GK110.
raghu78 is offline
post #9 of 55 (permalink) Old 11-10-2014, 12:38 AM
Clocknut's Avatar
usually the big daddy chip are around 50% bigger spec & I dont think Nvidia would go for anything less than 7Ghz GDDR5.
flagship Geforce hasnt been revert back to 6GHz b4.
Gaming Rig
(10 items)
Work/Web Rig
(12 items)
Asus P8Z77-V LK
Silverstone Ps06
Operating System
Windows 10 Pro
Core 2 Quad Q9650
Gigabyte EP41-UD3L
LianLi PS05
Operating System
Windows 10 pro
Clocknut is offline
post #10 of 55 (permalink) Old 11-10-2014, 12:38 AM - Thread Starter
Alatar's Avatar
There's no source but it's somewhat obvious. They're going to keep the same ration of MCs and ROPs. I really don't see nvidia going and pulling a tahiti with ROPs, it's going to be exactly like it was with GK104 to GK110 as far as MCs and ROPs go, same ratio. Meaning that GM200 will have 96.
btw your OP says 384 bit 6 Ghz memory. so it remains to be seen how much bandwidth increase is, though I doubt Nvidia would increase shaders by 50% while increasing memory bandwidth by just 30%. This would mean GM200 has less bandwidth per shader than GM204. I can see Nvidia running the Quadro/Tesla models at 6 Ghz while running the Geforce models at 7 Ghz .
The OP specs are probably for an ES of some pro card. 6ghz mem will usually result in better efficiency so it's understandable. But I don't see any reason for 6ghz on the consumer model (at least the top one) when they've already done 7ghz with the 780Ti and Titan Black.
My guess is that GTC 2015 is the latest when we're going to see a release.
Alatar is offline
