[TPU] AMD Zen 2 Offers a 13% IPC Gain over Zen+, 16% over Zen 1 - Page 3 - Overclock.net - An Overclocking Community
Old 10-17-2018, 10:37 AM
DivineLight
10 % is realistic and would be a good increase. As well I would expect 4.5 GHz at least, its not a far jump from the 2700X. 4.8 would be even better, because it would then probably match a 9900K @5 GHz while consuming less power.
DivineLight is offline
Old 10-17-2018, 10:39 AM
bucdan is an unknown quantity at this point bucdan is an unknown quantity at this point bucdan is an unknown quantity at this point
bucdan's Avatar
Quote: Originally Posted by DzillaXx View Post
Ryzen's 4 Core CCX limit hurts when the multicore performance. This count should to be improved. But we will have to wait and see.
From a consumer product viewpoint, the 8 core versions is more like two quad cores in a single die. Ryzen has lower latency between cores in the CCX than intel, but the current limit at 6 cores really slows it down. Moving data between the two sets of L3 CCX modules slows things down. Granted Intel's old Core2Quads were nothing more than two dual cores on a single package connected via the NB, and that thing ended up working out pretty well. So for what it is Ryzen is still a great design as the two ccx's are on the same die. But a move to even 6 cores in a CCX would really spice things up.
Also really hoping for Clock speed of 4.5-4.8 with an OC.
All I know is Ryzen 2 is my next system upgrade. Sandybridge has severed me well, and Ryzen's clock speeds are not as high as I would like. But the performance at its current clock speed is pretty solid IMO. Just give me 4.5+
Moved my Server into a Ryzen platform with ECC memory running ESXI and Virtualized everything. Honestly can't be beat for the price. ESXI 6.7 works great on the platform. Intel's going to need to step up their game, as AMD has a solid product in this market and only thing slowing them down is not having enough mainstream push.
I hope Ryzen can stop Sandy Bridge from hurting you too!
I'm in the same boat as you. Looking forward to Ryzen 2 myself.
Computer viruses are like herpes. You never think in a million years you'd get one... Till you do.
bucdan is offline
Old 10-17-2018, 10:45 AM
D-S-J Level 1
D-S-J's Avatar
Quote: Originally Posted by Warrax22 View Post
Significantly lower than the rumors of 30% ipc and 5ghz but still a good jump...I wonder if it's enough to beat Intel tho.
It's possible it'll beat Intel's 2018 offerings. But how will AMD's 7nm Zen2 2019 fare against Intel's 2019 offerings. 2019 7nm tech only matching on beating 2018 tech isn't that thrilling, it's to be expected. 2019 AMD vs 2019 Intel is the real battle. With Intel's track record their 2019 offerings will be faster than their 2018 offerings.
D-S-J is offline
Old 10-17-2018, 10:47 AM - Thread Starter
Retired Staff
tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about tpi2007 has a spectacular aura about
tpi2007's Avatar
Quote: Originally Posted by paulerxx View Post
Clock for clock how much better are current Ryzen CPU when compared Intel's?
Right now, with Zen+ being 2.5 - 3% faster clock for clock compared to the first Zen iteration, AMD basically equalled Intel's Broadwell (2014 / 2015 chip) except in AVX performance, whereas Intel is basically still using the same Skylake architecture from 2015 (which came right after Broadwell) in their Coffee Lake chips.
Clock for clock in non gaming tasks AMD is on average around 3% behind in single threaded performance, but their SMT (Intel calls it Hyperthreading) implementation is superior, and there they can be up to 4% faster. In games it's a different story and AMD is worse than that core for core, but CCX implementation also matters in that regard. For example, if you compare the 2600X against the 8700K you get one result, but if you replace the 2600X with the 2700X, it gets better for AMD at the same clocks. It can be a combination of the games tested being well multithreaded and / or the fact that on a 2700X you've got 4C/8T on each CCX, whereas with the 2600X you've got 3C/6T and thus a higher chance that even more modern games will have to use more than one CCX more frequently, thus incurring in a bigger penalty, whereas with the 2700X they can stay within one CCX (4C/8T) more often.
See the benchmarks here: https://www.techspot.com/article/161...-core-8th-gen/
Is your CPU bottlenecking your GPU ? Find out: CPU and GPU usage along with FPS in-game
Read my reviews here.
Clubs (founder): The rare / unusual CPU club
Clubs (member): Corsair Professional HX / AX Series PSU Owners Club || The Official Cooler Master HAF X/932/922/912(+) Club
Core i7-3820
Asus Sabertooth X79
MSI GTX 1060 6 GB Gaming X
16 GB Corsair DDR3 1866 Mhz Dominator
Samsung SSD 830 128GB + WD Caviar Black 2TB
Optical Drive
Sony Optiarc DVD-RW
Corsair AX750 Professional Modular 80 Plus Gold
Corsair A70 + Noiseblocker M12-P
Cooler Master HAF 912 Plus
Operating System
Windows 7 Home Premium 64-bit
BenQ RL2455HM
Keyboard
Cooler Master Octane
Mouse
tpi2007 is online now
Old 10-17-2018, 10:50 AM
opt33 is on a distinguished road opt33 is on a distinguished road opt33 is on a distinguished road opt33 is on a distinguished road
Looks like Ryzen 2 will be my first AMD cpu in over 12 years. Along with whatever 7nm gpu first comes available.
opt33 is offline
Old 10-17-2018, 11:26 AM
I <3 narcissists
bigjdubb is an unknown quantity at this point bigjdubb is an unknown quantity at this point bigjdubb is an unknown quantity at this point
bigjdubb's Avatar
Is there any reason why we should think that Intel's 2019 offerings will be anything other than their typical single digit performance increase? If AMD manages to beat the 9900k by 5% they would be within a few percent of Intel's 2019 products. I can't recall the last time I was impressed by Intel's generational performance increase.
Maybe Intel has been pretending to fail at making big performance gains because they haven't needed to make any big gains. Maybe they will knock our socks off next year, but optimism would be the only reason to believe such a thing.
Computer
(16 items)
AMD Ryzen 7 2700X
ASUS ROG STRIX X470I
Nvidia GTX 1080ti FE
G.SKILL TridentZ RGB
Samsung 970 EVO
CRUCIAL 1TB MX500 M.2
CORSAIR RMX650X
CORSAIR H100I PRO
Prolimatech MK-26 (2x 140mm fans)
Thermaltake Core P1
Operating System
Windows 10 Pro
LG 32GK850G
50" Vizio 4k TV
Keyboard
Logitech G110
Mouse
G.SKILL RIPJAWS MX780 USB
Audio
SMSL Q5 Pro
bigjdubb is offline
Old 10-17-2018, 11:27 AM
sudo apt install sl
WannaBeOCer is an unknown quantity at this point WannaBeOCer is an unknown quantity at this point
WannaBeOCer's Avatar
AMD's Zen+ single core performance is only 3.6% slower than Coffee Lake. If it's truely 13% faster than Zen+ that will put Zen 2 quite a bit faster than Intel. Along with IPC, AMD's SMT performance is superior to Intel's SMT(Hyperthreading)
Going to be an interesting year if Intel does indeed release their 10nm chips for the holidays of 2019.
Maximus
(18 items)
Core i7 6700K 4.8Ghz @ 1.4v
Maximus VIII Formula
Radeon RX VEGA 64 @ 1750/1105Mhz with 1175Mv
G-Skill 32GB 3200Mhz
Samsung 850 Evo 2TB Raid 0
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
EK-FC Radeon Vega
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
Thermaltake Core X5 Tempered Glass Edition
Operating System
Windows 10 Pro
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is online now
Old 10-17-2018, 11:38 AM
EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about EniGma1987 has a spectacular aura about
EniGma1987's Avatar
Quote: Originally Posted by reqq View Post
so.. whats the verdict.. we get 12 or 16 core on ryzen or only 8 core??
Im betting 12 core per die now, so 12 max on the AM4 platform. Epyc is supposed to get a 48 core product this gen, and so if they keep the same 4 die configuration that would mean 12 cores per die. It would also put them above Intel again on the desktop platform which AMD will want to do. And with 7nm they will have the space for it.
Yes Intel will be along those same 3-5% performance improvements for another generation or maybe 2. Along with possibly adding another pair of cores each gen depending how they want to counter AMD on the core count front. It wont be until the architecture overhaul in 2-3 years that we see possible major improvements moving to a next gen for Intel.
EniGma1987 is offline
Old 10-17-2018, 11:41 AM
D-S-J Level 1
D-S-J's Avatar
I expect Intel to be Intel. Just too much talk about 2019 7nm Zen2 vs 2018 9900K. Similar comparison would be 2018 9900K vs 2017 Zen1. Tech that's a year apart. Would be that be called fair? Comparing 2019 tech vs 2019 tech from competing companies would be considered fair.
D-S-J is offline
Old 10-17-2018, 11:45 AM
⤷ αC
AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about
AlphaC's Avatar
tpi2007 , I thought about buying a R5 2600X but ultimately the price difference to a R7 2700X is minimal when you factor in that people are paying $35-40 for the RGB cooler on Ebay even now. That's why I ended up getting the R7 2700X. Anything 4 threaded has the advantage in that you can lock it to a CCX.
What people underestimate is that the R7 2700X can hit ~4.2GHz or 4.3GHz all core quite easily with manual overclocks. It's when you have a full AVX load that it becomes an issue. It's been shown that Ryzen 7 2700X with a PBO overclock and BCLK overclock can easily reach 4.5GHz single threaded and 4.25GHz all core (see Crosshair VII Hero overclock guide). That's on a 240 AIO and not a copper radiator custom loop with a higher powered pump >6W.
Ryzen 7 1700X was able to hit ~3.9GHz all core @ 1.3-1.4V with better samples hitting 4GHz so a 10% jump from that is about 4.3GHz.
What I expect from Ryzen on 7nm to be very competitive is another 10% at least. So whatever the equivalent is to a R7 2700X @ 4.7GHz all core and 4.95GHz single threaded would be fine , although anything over 4.8GHz single thread and 4.5GHz all core out of the box would seem unlikely. Incidentally out of the box the i9-9900k boosts to 4.7GHz all core and 5GHz single threaded.
Elimination of CCX to CCX latency should remain a priority (decoupling it from memory speed or otherwise), even if it were to reach 4000MT/s memory speed the Infinity Fabric is only 2000MHz. Typically the ringbus on Intel CPUs is over 3.7GHz and when overclocking most people have it 4.5GHz or more.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
