[TechSpot] Samsung's plans to kill the notch: Yes, please. - Page 4 - Overclock.net - An Overclocking Community
Old 10-28-2018, 02:23 AM
twitchyzero Level 1
twitchyzero's Avatar
Quote: Originally Posted by Sir Beregond View Post
Really have never figured out how the curved edge screen was supposed to be of any value as an end user.
blame Apple and the social media generation
even electronics have to be sexy and aesthetically-pleasing
form over function
granted, I don't want my phone to look like it's from 2009, but brands like Samsung take it too far
no I don't care if it's 0.3mm thinner than last year, just give me something reliable, minimalistic and durable
isn't that one of the main causes that they found themselves with exploding Notes?
Nvidia Surround Gaming
My PC Hardware Upgrade CyclesWarning: Spoiler! (Click to show)
CPU: Athlon 1.3GHz | Core 2 Duo OC'd 2.0GHz | Core i5-3570K OC'd 4.8GHz
RAM: 2x256MB DDR-333MHz | 2x1GB DDR2-667MHz -> 2x2GB DDR2-800MHz | 4x4GB OC'd DDR3-2133MHz
GPU: GeForce2 MX 64MB -> Radeon 9600 Pro 256MB | Radeon X1950 Pro 256MB | GeForce GTX 670 FTW 2GB SLI OC'd
twitchyzero is offline
Old 10-29-2018, 10:02 AM
Avonosac is an unknown quantity at this point Avonosac is an unknown quantity at this point
Avonosac's Avatar
Quote: Originally Posted by HybridCore View Post
Lens correction works differently because it's not guessing. It's remapping points to a new location to cancel out the effects of distortion in the lens. Neural networks make guesses and fill in information that didn't exist. They're very different beasts. One requires insane amounts of data to train the system and the other one is a much simpler set of transformations (albeit nonlinear).
Sigh, ok lets go.
It isn't remapping other points to new locations because those "points" have been condensed into other pixels. We aren't talking perfect lensing where pixel shape is a function of the lensing effect, we're talking dynamic occlusion. However, in either case you have a region of pixels which are inaccurate which need correction from (at least) the pixels around it. In this case the only difference between complete interpolation and 'adjustments' is the weight at which the pixels within the region are being trusted.
In the event of total occlusion, you would expect completely untrusted in the center and low trust on the border. While in a partial obstruction you're looking at a higher level of trust applied to the pixels within the corrected region.
The algorithm, even with a single source of input is exactly the same.
You'll note I also said they would use more than one sensor, which together would provide the similar "partially" trusted source data for the final composite image.
Avonosac is offline
Old 10-29-2018, 11:11 AM
HybridCore is an unknown quantity at this point HybridCore is an unknown quantity at this point
Quote: Originally Posted by Avonosac View Post
Sigh, ok lets go.
I'm not arguing that you're not losing resolution/information when doing software-based distortion correction compared to using actual corrective lenses. It's information that's permanently lost since it wasn't captured from the start. That still doesn't change the fact that software-based lens distortion correction is still just a remapping of information (basically stretching and squishing the input image) and AI a kind of trained guessing/filling algorithm in the simplest terms. They are still very different even if the end results are similar.
HybridCore is offline
Old 10-29-2018, 01:13 PM
Web Developer full stack
charlesquik Level 1
charlesquik's Avatar
Take a look at Xiaomi Mi Mix 3.
There is a slider in the back to show the cameras.
Now this is a true no-notch phone.
charlesquik is offline
Old 10-29-2018, 02:46 PM
Avonosac's Avatar
Spoiler!
You have not understood my explanation of the algorithm at all, so you either aren't an engineer or you don't understand the fundamentals to both problems. If you don't understand software and _what_ AI is, I can't help you. But your summary of the "problem" very obviously demonstrates your lack of understanding.
Your assertion is false, these problems are the same thing.
Avonosac is offline
Old 10-30-2018, 12:01 AM
MegaTechPC
Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about Majin SSJ Eric has a spectacular aura about
Majin SSJ Eric's Avatar
I couldn't possibly care less about the supposed privacy implications of this, all I know is I WANT it!!!! Fully bezel-less screen up front with embedded cameras/sensors/etc is the holy grail of smart phone design and if Samsung pulls it off they will deservedly get the credit for having the proper vision of where these designs are going. Slow, cumbersome, and over-complicated motorized cameras are not the answer, embedded tech is where its at!
3DMark11 - P25138
3DMark Firestrike - P20998
Intel Core i7 4930K @ 4.7GHz | Asus Rampage IV Extreme | 2 x EVGA GTX Titan SC (1254MHz) | 16GB Patriot Viper Extreme DDR3 2133MHz (4 x 4GB) | Corsair AX1200 | Silverstone Temjin TJ11 | Corsair Force 3 240GB (System) | 2 x Intel 320 160GB SSD (Dedicated Gaming Drives) | Hitachi Deskstar 1TB (Data) | MS Windows 10 Pro | EK Supreme HF/FC-Titan/Rampage IV Extreme blocks | Hardware Labs GTX 560/240 rads | Alphacool VPP-655 D5 pump | Bitspower mod kit/pump top/fittings/120mm res
Majin SSJ Eric is offline
