[TECHSPOT] Do we need to re-review the Core i9-9900K? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 77 (permalink) Old 11-08-2018, 02:51 PM
sudo apt install sl
WannaBeOCer is an unknown quantity at this point WannaBeOCer is an unknown quantity at this point
WannaBeOCer's Avatar
Quote: Originally Posted by jclafi View Post
First R7 2700 reach 4.7 Ghz. ???? Almost impossible never see it... Second intel sell 9900k w/ max turbo specs and label it as 95W CPU...
Others chips hot because of glue thermal bla bla bla... Delid.... I always delid... bla bla bla .....
A lot of crap detect here boys to justify intel hot potato..
Intel isn't the one forcing the max turbo on all 8 cores. If you read the article he confirmed Asus sets the 9900k default to use the TDP limit while all the other manufacturers have it disabled. Second the 9900k uses less power and runs cooler than the 2700x at the same clock speed as a 2700x. So if a 2700x could reach 4.7Ghz it would use more power and run hotter than a 9900k.
It should be an option by the motherboard manufacturer. Just like how many video cards have a bios switch to use a low power profile or a high performance profile.
Quote from Linus' review
Since our thermal and power consumption numbers are very different from other publications, here's some clarification on our board settings:
-Multi-core enhancement: Disabled
-SVID behavior: "Intel Fail-Safe" / Intel's default
-XMP: Enabled
-All power duration and limit settings default
-Core multiplier at defaults
-Core voltages at defaults
Cooler: Corsair H115i w/IC Graphite thermal pads
The performance numbers we got were double-checked against Intel's engineers, and they were in line; This suggests that our thermal tests are indicative of stock performance (with motherboard vendor optimizations disabled). We did not ask Intel about their thermal or power consumption results.
OC3D's results who also has the 9900k at default
Name:	Screen Shot 2018-11-08 at 1.57.05 PM.png
Name:	Screen Shot 2018-11-08 at 1.56.46 PM.png
Name:	Screen Shot 2018-11-08 at 2.02.43 PM.png
Name:	Screen Shot 2018-11-08 at 2.03.18 PM.png
Maximus
(18 items)
Core i7 6700K 4.8Ghz @ 1.4v
Maximus VIII Formula
Radeon RX VEGA 64 @ 1750/1105Mhz with 1175Mv
G-Skill 32GB 3200Mhz
Samsung 850 Evo 2TB Raid 0
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
EK-FC Radeon Vega
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
Thermaltake Core X5 Tempered Glass Edition
Operating System
Windows 10 Pro
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #22 of 77 (permalink) Old 11-08-2018, 03:31 PM
⤷ αC
AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about
AlphaC's Avatar
No mention of motherboard used for the other CPUs + chipset has more power use on Ryzen. If you wanted a proper comparison you'd need EPS12V power with a motherboard packing comparable VRM of >90% efficient powerstages (i.e. Crosshair VII Hero , Taichi using NexFETs, STRIX X470-F , Prime X470 Pro, or X470 Gaming 7) as the OC3D review uses Z390-E STRIX board. Most midrange Ryzen boards are using powerpaks ~85% efficient which only lower end Z390 boards use.
I don't bother with Linustechtips because I prefer reading and besides that he has no details on test methodology.
https://www.anandtech.com/show/13400...600k-review/21
~166W for i9-9900k , i7-9700K ~ 123W, R7 2700X ~ 119W
https://www.hardocp.com/article/2018...n_cpu_review/5
~158W for i9-9900K , R7 2700X ~121W
https://www.techpowerup.com/reviews/..._9900K/18.html
180W required for no throttle in AVX load : "Instead of 4.8 GHz all-core (180 W), it was running at around 4.1 GHz when left at stock TDP."
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #23 of 77 (permalink) Old 11-08-2018, 03:38 PM
rdr09 has a spectacular aura about rdr09 has a spectacular aura about rdr09 has a spectacular aura about rdr09 has a spectacular aura about rdr09 has a spectacular aura about rdr09 has a spectacular aura about rdr09 has a spectacular aura about
Quote: Originally Posted by AlphaC View Post
We'll see what happens when people put them in H370 (i.e. ones with decent VRM which is very rare) and non Z390 boards with Cooler Master 212 coolers.
https://www.extremetech.com/computin...-core-slugfest
CB R15 = 2,011 vs 1822 on R7 2700X (+10%)
https://www.trustedreviews.com/revie...-core-i9-9900k
CB R15 = 2,058 vs 1,769 on R7 2700X (+16%)
POV-RAY = 10,984 vs 9,445 (+16%)
https://www.phoronix.com/scan.php?pa...0k-linux&num=7
Blender (AVX) : +14%
V-ray: +8%
I'd be very wary of any result citing over 23% advantage in a non AVX2 multithreaded workload.
My R7 2700 @ 4025 and RAM @ 2400 gets 1826 in CH15. Something's off.
rdr09 is offline
post #24 of 77 (permalink) Old 11-08-2018, 03:53 PM
jclafi Level 1
jclafi's Avatar
Will leave this to you, perhaps you learn something. You work for Intel ? Look´s like.
R5 2600 - MSI X470 Gaming Pro - nVIDIA GTX1060 6GB O.C - Corsair Vengeance LPX 16GB @ 3200 - Cooler Master Storm Scout - Western Digital Green 240GB M.2 - Kyngston A400 480GB - Seagate Barracuda 1Tb - Cooler Master Hyper 212 Turbo - SamSung 32in LED - eVGA 750W - Razer Abyssus V2 - Logitech G27
jclafi is offline
post #25 of 77 (permalink) Old 11-08-2018, 04:49 PM
sudo apt install sl
If you install a 9900K in any motherboard and disable the "manufacturer optimizations" it will run with the 95w target the way Intel intended it to run. It's an issue with motherboard manufacturers not the 9900k. I've been against MCE ever since it was released and now that Intel set the PL2 to go up to 210w doesn't mean that the manufacturers should set it by default to run that high. Hopefully they have warnings in the box of their motherboards they ship that say the 9900k won't run anywhere near Intel's target since we decided to run it at peak boost instead.
I'm sure you would be in an uproar if motherboard manufacturers started clocking AMD chips high just cause those chips could.
Maximus
(18 items)
EK-FC Radeon Vega
XSPC D5 Photon v2
Operating System
Windows 10 Pro
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Audio
Audio
SMSL M8A
post #26 of 77 (permalink) Old 11-08-2018, 06:50 PM
guttheslayer is an unknown quantity at this point guttheslayer is an unknown quantity at this point
guttheslayer's Avatar
Quote: Originally Posted by Imouto View Post
Why are you like this? Why do you want to put these forums to shame with every single post you make?
Well... He had to defend intel on every post cos he was probably paid to do so.
Exacly !
There is no need for any exactly go do a post search on his acct. and you realised every post he made is about how great intel is, intel didnt do any wrong etc. Go search.
He is beyond even what a typical hardcore fan will do. More like he is someone from Intel.
guttheslayer is offline
post #27 of 77 (permalink) Old 11-08-2018, 07:00 PM
⤷ αC
AlphaC's Avatar
jclafi , did you notice the Intel XTU shows 187W or so package power? His graphs show 150ish watts only
AlphaC is offline
post #28 of 77 (permalink) Old 11-08-2018, 09:53 PM
Laptop Enthusiast
Imglidinhere is on a distinguished road Imglidinhere is on a distinguished road Imglidinhere is on a distinguished road Imglidinhere is on a distinguished road Imglidinhere is on a distinguished road
Imglidinhere's Avatar
I blame the motherboard manufacturers. Intel should force them by default to use the TDP limit.
Pfft, Intel will NEVER do that. They're the KINGS of anti-competitive play. You've gotta be crazy to think Intel is innocent in this. They know full well what goes on here. Did you not see the fiasco with Principled Technologies?
Intel are just as dirty as any motherboard manufacturer.
SKYNET Mobile v3.0
(12 items)
Inspiring Greatness
i7-8750H @ 3.9GHz
Intel HM370
6GB GTX 1060
32GB DDR4 2666
256GB SSD
500GB Samsung 840 Pro
180w Power Adapter
Tongfang GK5CN6Z
Operating System
Windows 10 Home
1920x1080 144hz IPS Display
Mouse
Logitech G502 Proteus
Mousepad
Xtrac Ripper
Intel Core i5-6300HQ
Dell Proprietary
4GB Nvidia GTX 960M
Samsung 12GB (1x8GB 1x4GB) DDR3L 1600 MHz
256GB SanDisk M.2 SSD
1TB HGST 7.2k HDD
130w PSU
Custom Cooling by Dell Solutions
Operating System
Windows 10 Home 64-Bit
15.6" 1920x1080 IPS Screen
Keyboard
Dell
Mouse
Logitech G602 Wireless
Mouse
Xtrac 'Ripper' Mouse Pad
Imglidinhere is offline
post #29 of 77 (permalink) Old 11-09-2018, 05:58 AM
Almost Canadian
OutlawII Level 1
OutlawII's Avatar
Just butthurt AMD fanbois sounds like to me. Instead of constantly bashing Intel maybe you guys should jumping AMD for producing a slower product with literally no OC headroom. Personally i could care less that the mobo manufactures have better settings and higher TDP over Intel specs. Get over it, move on buy what you want.
OutlawII is offline
post #30 of 77 (permalink) Old 11-09-2018, 07:24 AM
Top kek
ku4eto is an unknown quantity at this point ku4eto is an unknown quantity at this point
You sound like a butthurt Intel fanboy.
If all Motherboard makers were enforcing by default the 95W TDP limit, you would have cried a river. Because the gaming performance of the 9700/9900K on stock would have been HORRIBLE due to throttling.
Previous Hardware:
Spoiler!
Desktop PC
(19 items)
AMD FX-8320
ASRock Fatal1ty 990FX Killer
Sapphire Nitro+ RX480
XFX RX470 Singlefan
MSI RX580 GamingX 4GB
Mushkin Redline 996996 2x4GB 2133Mhz
Western Digital 160GB 7200RPM 8MB
Maxtor 250GB 7200RPM 8MB
Corsair Force LS
WesternDigital Blue 500GB 7200RPM 16MB
Corsair TX850M
ThermalTake Frio Silent 14
ThermalTake View 27
Operating System
Windows 10 Enterprise 1607
Operating System
Linux Mint 17.3 Rosa
AOC i2267FWH
Keyboard
Logitech K120
Mouse
Bloody V5
Audio
Corsair HS30 Raptor
ku4eto is offline
