[TECHSPOT] Do we need to re-review the Core i9-9900K? - Overclock.net - An Overclocking Community
post #1 of 77 (permalink) Old 11-08-2018, 08:11 AM - Thread Starter
Indentified! On the Way!!
LancerVI's Avatar
Rep: 153 (Unique: 114)
Benchmarking the i9-9900K with unlimited and 95-watt limited results might show two very different sides of the same CPU
Essentially then Intel has two seperate specifications for their high-end CPUs, a TDP limited specification that they loosely define or a clock multiplier table specification, and enabling one means it’s impossible to achieve the other. The TDP limit means you won’t reached the intended all-core clock speed while the clock multiplier table spec means you’re running well above the TDP.
Source: https://www.techspot.com/news/77313-...-i9-9900k.html
Interesting read.
MODs: I used the hardware news forum, but the piece is listed as an opinion piece by Techspot. Wasn't sure where to put it. Sorry, if in the wrong spot.
UPDATE 11/10/18: https://www.techspot.com/review/1744...00k-round-two/
Today we're revisiting our original Core i9-9900K review and updating it with 95 watt TDP limited results, basically results based on the official Intel specification. For better context about this please read our opinion article from earlier this week titled “Do We Need to Re-Review the Core i9-9900K?”.
The short version of this is that motherboard makers are currently getting blamed for running the 9900K out of spec, when in reality we strongly believe it’s Intel who’s cheating their own spec and pushing board partners to run the 9900K at the default clock multiplier table, rather than at the official power spec.
LancerVI is offline
post #2 of 77 (permalink) Old 11-08-2018, 08:40 AM
In VB's Basement
ENTERPRISE's Avatar
I have moved this into the Rumours section
ENTERPRISE is offline
post #3 of 77 (permalink) Old 11-08-2018, 08:52 AM - Thread Starter
LancerVI's Avatar
Thanks. I wasn't sure, as I don't see the information in the article as being rumor or unconfirmed, as they tested it. I think the opinion part comes in when he asks, "should we retest the 9900k."
LancerVI is offline
post #4 of 77 (permalink) Old 11-08-2018, 09:25 AM
jclafi's Avatar
Rep: 55 (Unique: 37)
Hot potato !
Oh sorry...
Very fast hot potato !
AMD R5 3600 - MSI X470 Gaming Pro - nVIDIA GTX1060 6GB O.C - Corsair Vengeance LPX 16GB @ 3200 - Cooler Master Storm Scout - Western Digital Green 240GB M.2 - Kyngston A400 480GB - Seagate Barracuda 1Tb - Cooler Master Hyper 212 Turbo - SamSung 32in LED - eVGA 750W - Razer Abyssus V2 - Logitech G27
jclafi is offline
post #5 of 77 (permalink) Old 11-08-2018, 09:56 AM
sudo apt install sl
WannaBeOCer's Avatar
Rep: 177 (Unique: 123)
Now, since first reviewing the Core i9-9900K I’ve tested over a dozen Z390 motherboards, ranging from the cheapest $120 models right up to the much more expensive flagship versions. Out of the box all boards from MSI, Gigabyte and Asrock run without a TDP limit in place, even with the default BIOS configuration.
However this isn’t the case for the Asus boards I’ve used, the default out of the box of cleared BIOS configuration employs the 95-watt TDP limit. To remove it without digging into the power setting and doing so manually you’ll need to load an extreme memory profile and then agree to using the Asus optimized settings rather than Intel’s. Basically Asus optimized means ignoring the TDP limit and running at the default clock multipliers like all boards from MSI, Gigabyte and Asrock.
I blame the motherboard manufacturers. Intel should force them by default to use the TDP limit.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 4.2Ghz w/ 1v
Maximus VIII Formula
Radeon VII @ 1900Mhz/1250Mhz w/ 1v
TeamGroup Xtreem 16GB 3866Mhz CL15
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
Samsung 850 Evo 500GB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is online now
post #6 of 77 (permalink) Old 11-08-2018, 10:09 AM
doom26464's Avatar
Rep: 11 (Unique: 9)
TDP been sort of a loose term on intel side for awhile. They really should just bump it up already, its no secret that intel processor are hot and power hungry.
doom26464 is offline
post #7 of 77 (permalink) Old 11-08-2018, 10:34 AM
sudo apt install sl
The only reason the 9900k is pulling so much power is because motherboard manufacturers are removing the TDP limit and allowing the chips to reach max turbo peak. That's not default from Intel and blame should be on them not Intel's chips because they are more efficient than Ryzen when running at similar clocks. They are hot for sure but I'm sure a 2700x @ 4.7Ghz on all 8 cores would also be as hot. Other chips were hot because of the glue and thermal paste they used. I always de-lid and run the IHS directly on the core with liquid metal without gluing the IHS back on.
Silent
(20 items)
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
XSPC D5 Photon v2
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Audio
Audio
SMSL M8A
post #8 of 77 (permalink) Old 11-08-2018, 10:39 AM - Thread Starter
LancerVI's Avatar
You left out the rest of what he said though:
So the problem we have here is motherboard makers for the most part aren’t abiding by either of these power limits, instead they are targeting the clock multiplier table. You could say motherboard makers are cheating but we don’t think that is it... we still feel Intel is cheating their own spec. There is simply no way all board makers did this on their own, what a mighty big coincidence that would be and surely Asus, MSI, Asrock and Gigabyte all work alongside Intel engineers to create their Z390 motherboards.
and
We’ve heard a lot of back and forth from AMD and Intel fans, and watching how opinions from both camps have changed over the past year has been interesting. For the 8th-gen release AMD’s pitchfork crew were shrieking at the top of their lungs for us to test with the 95-watt TDP limit in place, while the blue man group members disagreed. Now with the 9th-gen series it’s all over the place, some AMD extremists now want the TDP removed, “let the 9900K burn” they say.
On the other hand, some Intel extremists now say that motherboard markers aren’t abiding by the Intel spec and are causing the 9900K to run too hot. That’s partly true, though I’m not convinced motherboard makers are really the ones at fault here.
LancerVI is offline
post #9 of 77 (permalink) Old 11-08-2018, 10:43 AM
sudo apt install sl
According to his testing Asus abides by the default with the TDP limit set when defaults are enabled. Why are all the other manufacturers not and forcing peak boost on all 8 cores? That's a motherboard manufacturer choice.
Silent
(20 items)
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
XSPC D5 Photon v2
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Audio
Audio
SMSL M8A
post #10 of 77 (permalink) Old 11-08-2018, 10:48 AM - Thread Starter
LancerVI's Avatar
Please understand; I'm not saying you're wrong, I just thought it important to note the rest of what he said. Having said that, Intel surely knows what's going on. They bifurcated their TDP into two specifications and they can't have it both ways at the same time. One spec to make their cpus look more efficient. Another to make it the fastest cpu around. I maybe over simplifying it, but essentially, that is what they've done. I don't think you can lay ALL of the blame on mobo manufactures.
LancerVI is offline
