[MacRumors] Apple Said to Release 31.6-Inch 6K Display With Mini LED-Like Backlight Design in 2019 - Page 3 - Overclock.net - An Overclocking Community
post #21 of 40 (permalink) Old 04-18-2019, 12:37 AM
Performance is the bible
Rep: 433 (Unique: 299)
Quote: Originally Posted by Dotachin View Post
afaik they only work for storage. Even if they manage to get full support for egpu etc, I wouldn't expect Intel to certify it and loose cpu sales.
Intel released the TB standard as free and certification free.
This was partially done because apple pushed them to do it.
I expect AMD to utilise it as well at some point as I expect apple will ask them to.
Defoler is offline
post #22 of 40 (permalink) Old 04-18-2019, 08:02 AM
Dotachin's Avatar
Rep: 38 (Unique: 30)
Yeah a couple weeks after my post usb 4 was announced
Dotachin is offline
post #23 of 40 (permalink) Old 04-18-2019, 09:27 AM
Insan1tyOne's Avatar
Rep: 137 (Unique: 110)
Even though the LED back-lighting sounds amazing, who cares about a 6K res. at 16:9? When are we getting the next 21:9 monitor upgrade? Currently the best one is the 37.5" panel that has a resolution of 3840x1600 at 75 Hz which has been out for over two years now. The next step up should be something like a 41.5" panel with a resolution of 5120×2160 at 75 Hz or greater. Hopefully all the big panel makers haven't forgotten about us ultra-wide fans.
Insan1tyOne is offline
post #24 of 40 (permalink) Old 04-18-2019, 02:58 PM
ILoveHighDPI's Avatar
Rep: 133 (Unique: 84)
I keep seeing 6K listed as a source resolution for Hollywood movies, the cameras are out there and at least some people will be working with 6K footage, but for the average video editor I’m assuming they just want more workspace around a native 4K image.
Really they should just move straight to 8K, but I guess if your primary demographic is 4K editing then 8K might require too large of a screen to keep native resolution playback at a comfortable size for critique.
ILoveHighDPI is offline
post #25 of 40 (permalink) Old 04-18-2019, 11:18 PM
You have the LG 34WK95U-W. 5120x2160 at 60hz.
Those panels are still massively expensive, so until they get better manufacturing process, we won't see big 21:9 updates.
Defoler is offline
post #26 of 40 (permalink) Old 04-19-2019, 06:50 AM
I agree with you, we don't need to mess around with all these 16:9 5K, 6K, etc. monitors. Just go from 4K to 8K. I mean most cinematographers, large-scale YouTubers, etc. are filming with RED's DSMC2 camera's which shoot natively at 8K. So I think there isn't really a big reason to be wasting time on 16:9 5K and 6K panels at this point.
Yes, that monitor has a great resolution for 21:9 at 5120 x 2160. But 34" is just way too small. I'm not sure why they would try and pack such a big resolution on such a small monitor. The PPI is was too dense. They should have gone up to 40" - 42" at least. I would be surprised if anyone even buys that monitor, I had the same feelings of disappointment when it was announced. I will be very sad if panel makers actually have abandoned 21:9.
post #27 of 40 (permalink) Old 04-20-2019, 12:30 PM
Overclocker
JackCY's Avatar
Rep: 300 (Unique: 219)
Good luck processing 8k footage. There is never such a thing as too high pixel density. 5k is great because most modern GPUs can run 1440p, = perfect 1/2 scaling, with good performance. With 8k you're stuck with 1/2 = 4k R.I.P. GPU or 1/4 = 1080p bleh. 6k at least you get a 1/2 = 3k.
For photos higher resolution is better but 8k is definitely more costly to make than 5-6k. And good luck getting good viewing angles past 32" even with IPS.
These 4k+ monitors are for specific customers.
JackCY is offline
post #28 of 40 (permalink) Old 04-21-2019, 06:05 AM
Hardware Princess
Hydroplane's Avatar
Rep: 22 (Unique: 20)
Hopefully it will be able to be attached to a PC without having to do a weird workaround
CHILLER DESTRUCTION
Build Log - White Voodoo
Z390 Station
(10 items)
White Voodoo
(14 items)
9900K @ 5.5 1.46v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4133c16 1.5v
Samsung 970 Evo Plus 250gb
EVGA 1300 G2
Dehumidifier
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Intel Core i9-7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
Gigabyte Aorus Waterforce WB 1080 Ti SLI 2037/6318 1.09V
Trident Z 32GB (4x8GB) 3200C14 @ 3800C16 1.50V
Samsung 960 Evo 1TB
EVGA 1600 T2
HWLabs Nemesis GTR 420+280 Rads
(7) Noctua NF-A14 iPPC-3000 PWM Fans
EK-XRES 140 Revo D5 RGB PWM
LD Cooling PC-V7 280/420
Operating System
Windows 10 LTSB
Operating System
Linux Mint 19.1
NEC PA271W 2560x1440
Keyboard
Razer Blackwidow Chroma V2
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #29 of 40 (permalink) Old 04-21-2019, 06:42 AM
toncij's Avatar
Rep: 60 (Unique: 41)
It doesn't work like that. You don't make it easier on the GPU if you scale. GPUs render 5K even if you scale the GUI 200%. They also render 8K no problem. Even video rendering of 8K is just fine on TITAN RTX. No issues. (Premiere)
6K is there as it is enough to give you 1600px height at ~30-32" as usual to be integer scaled (rendered at 6K, downscaled to GUI viewport of 2560x1600 (yes, 16:10). Viewport DPI vs display PPI is 1/2 then. Dell's 8K is somewhat in a strange place - either 1/3 or 1/2, one being too large for typical DPI, one being to small. Added sharpness is there, of course but not sure if for much perceptible benefits.
It's not meant for gaming, but you can game on 8K too; older or simpler (graphically) games like Diablo 3, HotS or StarCraft work great on 5K (150ish fps or more on 2080Ti)
My GPUsWarning: Spoiler! (Click to show)
3dfx Voodoo, 2x3dfx Voodoo 2, Voodoo 3, Creative Riva TNT 2 Ultra, GeForce 256, ATi Radeon 3D Rage Fury MAXX, GeForce 2 Ultra, ATi Radeon DDR 7500, ATi Radeon 8500, ATi Radeon 9000 Pro, ATi Radeon 9800 XT, ATi Radeon X600 XT, ATi Radeon X850 XT, GeForce 8800GTX, ATi Radeon X1650 XT, GeForce GTX 280, ATi Radeon HD 2900XT, ATi Radeon HD 3870 X2, GeForce GTX 480, ATi Radeon HD 7970 (x2), GeForce GTX 780Ti, GeForce Titan Black (x4), GeForce 970 (x2), GeForce Titan X (x19), AMD RadeonProDuo (x2), GeForce 1080 (x2), Titan X (Pascal) (x2), EVGA FTW 1080 (x2), Quadro P6000 (x2), 1080Ti FE (x2), Titan Xp (x2), TITAN V+ 1080Ti (x2)
toncij is offline
post #30 of 40 (permalink) Old 04-23-2019, 09:58 AM
junglechocolate's Avatar
Rep: 1 (Unique: 1)
Yeah but why stop there, lets go to 10K. Ridiculous. this doesn't add anything gaming wise. Bring back 3D Please. Much more immersive than this constant resolution jump. It's still flat 2D
i7 930 @ 3.8Ghz HT
Asrock X58 Extreme 3
Corsair XMS3 6GB 1600mhz
EVGA GTX 1080 Ti BE SC
Corsair RMS 750W
LG C6 4K 3D OLED 55", Potalion 1440p Korean IPS "glossy panel", Dell Ultrasharp U2515H
junglechocolate is offline
