[ElChapuzasInformático][AMD] First AMD Ryzen 5 3600 (X470) Review (Spanish) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 112 (permalink) Old 06-24-2019, 02:43 PM
Tobiman's Avatar
Rep: 64 (Unique: 49)
Quote: Originally Posted by AlphaC View Post
Keep in mind it's tested on a x470 Gaming 7. If you actually own the board you know that F40 BIOs isn't fully ironed out yet even for Ryzen 7 2700X let alone the 3rd gen Ryzen chips.
For example with 1778 CB R15 score that's around 3.95-4GHz all core and even with Hynix RAM I attain over 176 single core CB R15. The CB R20 score seems in line with stock though.
Essentially what this suggests is that with mere 4.5GHz boost clock Ryzen 7 3800X/3700X will edge out the i9-9900k (5GHz single core boost, ~4.8GHz quad core boost) at stock. The cooling used isn't listed and that affects clockspeeds with precision boost.
The latency numbers for memory leave a lot to be desired. AMD slides have it at 69ns for 3200C14 kit , this review has 80ns. This may partially explain the gaming deficit., since in DX11 Firestrike and Dx12 Timespy Ryzen 5 3600 is almost on par with the i9. They didn't use 1% or 0.1% lows , a mere FPS number is given.
They don't say which particular kit they used and we can't assume it's a CL14 because there's 3200MHZ G-skill FLARE X memory with 16-18-18-38 timings.
Tobiman is offline
post #22 of 112 (permalink) Old 06-24-2019, 02:47 PM
⤷ αC
AlphaC's Avatar
Rep: 911 (Unique: 592)
The link in the article goes to the 3200C14 kit:
https://elchapuzasinformatico.com/20...x-ddr4-review/
edit: I think it's because they're running their RAM in the wrong DIMM Slot or something like that
Memory write on the Ryzen 5 3600 is listed as 25,600 MB/s when the Ryzen 5 2600X is 47,823 MB/s
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #23 of 112 (permalink) Old 06-24-2019, 02:51 PM
criminal's Avatar
Rep: 695 (Unique: 426)
Looking good.
I have a big bang house. I had all the materials for my new house brought in and dumped on a vacant lot. I took a stick of dynamite, lit the fuse on fire and tossed it into the pile of materials. BOOM went the explosion and when the dust settled I had a new house! Amazing isn't it?
Super P's Rig
(21 items)
Noahman
(9 items)
Ryzen 7 3700X
MSI MPG X570 GAMING PRO CARBON
Gigabyte RTX 2070S
XPG Spectrix D41 3600MHz
Samsung 850 EVO
MyDigitalSSD SBX
WD Black 500GB NVMe
EVGA SuperNOVA 850G2
Bykski CPU-XPR-AM
Phobya Balancer 150 Reservoir
XSPC EX280 Radiator
TC-A - CPU Liquid Cooling Pump
XSPC EX360 Radiator
Phanteks Pro M TG
Operating System
Windows 10
MSI Optix AG32CQ
Keyboard
G710+
Mouse
G305
Mousepad
Vipamz Extended XXXL
Audio
Sennheiser HD 439
Audio
Asus U7
5960X
Asus X99
MSI R9 380 Gaming
V-Color Skywalker 16GB 2666MHz
Kingston SSDNOW V300
EVGA 500 W1
CoolerMaster 120MM AIO
Fractal Design Define S
Operating System
Windows 10 Pro
criminal is offline
post #24 of 112 (permalink) Old 06-24-2019, 03:02 PM
Waiting for 7nm EUV
tpi2007's Avatar
Rep: 898 (Unique: 504)
Quote: Originally Posted by aDyerSituation View Post
I don't know about that. 196 in cinebench st is kind of low. Not sure what clock speed that was at but my 7820x @ 4.6 does 207ish.
Low? You're talking about a ~5% difference. They ran the chip at stock, thus with a 4.2 Ghz boost. The 3800X has a 4.5 Ghz boost, thus 7% higher, and if you compare price for price against the 9900K, the 3900X has a 4.6 Ghz boost, which is 9.5% higher.
tpi2007 is offline
post #25 of 112 (permalink) Old 06-24-2019, 03:06 PM
Old and Crochity
Darkpriest667's Avatar
Rep: 271 (Unique: 200)
Quote: Originally Posted by WannaBeOCer View Post
Last time every reviewer tested showed gaming wasn't affected. Unless you want them to disable hyper-threading?
https://support.apple.com/en-us/HT210108 -- How to enable full mitigation for Microarchitectural Data Sampling (MDS) vulnerabilities
The only way to fully protect yourself against the vulnerabilities is to disable hyperthreading.
“We conclude that disabling hyperthreading, in addition to flushing several microarchitectural states during context switches, is the only possible workaround to prevent this extremely powerful attack,” a research paper describing the Zombieload flaw, authored by researchers at Graz University of Technology, Cyberus Technology, Worcester Polytechnic Institute, and KU Leuven, says.
Quote:Originally Posted by Deadboy90 https://www.overclock.net/img/forum/go_quote.gif
You want true privacy? Go live in the woods with no electronics like in the early 19th century. Otherwise stop complaining.
In God we trust, all others we monitor - NSA motto
Darkpriest667 is offline
post #26 of 112 (permalink) Old 06-24-2019, 03:08 PM
rdr09's Avatar
Rep: 870 (Unique: 635)
I get 80ns with my Flares at an optimal default of 2400MHz on a Gen1+ and B350. A 67ns at 3200 CL14 DOCP.
2nd AMD Build
(10 items)
2700
X470
290
3200 CL14
1000
700
Operating System
10/64
40 1080
Keyboard
M100
rdr09 is offline
post #27 of 112 (permalink) Old 06-24-2019, 03:10 PM
sudo apt install sl
Rep: 183 (Unique: 126)
That's exactly why I asked if you wanted reviewers to test without hyper-threading since patches aren't affecting gaming.
https://www.intel.com/content/www/us...ology/mds.html
Is Intel recommending that I disable HT?
No. Intel is not recommending that users disable Intel® Hyper-Threading Technology (Intel® HT Technology). It’s important to understand that doing so does not alone provide protection against MDS, and may impact workload performance or resource utilization that can vary depending on the workload.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Radeon VII @ 2100Mhz/1250Mhz w/ 1218mV
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #28 of 112 (permalink) Old 06-24-2019, 03:30 PM
zealord's Avatar
Rep: 400 (Unique: 206)
This review sadly doesn't tell me much. Too much information is missing and not enough tests done.
zealord is offline
post #29 of 112 (permalink) Old 06-24-2019, 04:07 PM
Unkzilla's Avatar
Rep: 15 (Unique: 13)
edit: my 2700x system scores 180CB, 9900k 223 and believe it or not also have a ryzen 5 2600 with the cheapest possible motherboard (asrock b450m) which scores 173
Good comparison is 2600 vs 3600 where there seems to be a 13% gain
Probably not upgrade worthy but a decent purchase for those looking to buy a new system. I still maintain the 2600 is all you need for a 4k gaming setup
Unkzilla is offline
post #30 of 112 (permalink) Old 06-24-2019, 05:21 PM
Overclocker
JackCY's Avatar
Rep: 345 (Unique: 244)
Quote: Originally Posted by Ha-Nocri View Post
It's noticeable faster than 2700X in games. And ofc it's slower than Intel, we expected that. The fastest Zen 2 CPU (3950X I guess) won't catch 9900K, but it will be close enough ppl won't care.
It will sail right past 9900K lol, big time. 8C vs 16C, it's not even a competition, it's a slaughter.
You write your application right and 9900K has no chance with it's lower total performance.
3600 looks fine, matching Intel 6C/12T and older Zen 8C/16T. For more details gotta wait 2 weeks. For an early review, it's doesn't show anything too bad or too good. As expected and that's good.
JackCY is offline
