[ElChapuzasInformático][AMD] First AMD Ryzen 5 3600 (X470) Review (Spanish) - Page 6 - Overclock.net - An Overclocking Community
post #51 of 112 (permalink) Old 06-25-2019, 06:43 AM
sudo apt install sl
WannaBeOCer's Avatar
Rep: 177 (Unique: 123)
Quote: Originally Posted by Redwoodz View Post
[IMG class=inlineimg]/forum/images/smilies/rolleyes.gif[/IMG] You do realize this review shows a stock,6 core Ryzen 3 3600 MATCHING an 8 core I9-9900K in gaming on a non-overclocking bios with bad memory timings, and that is your conclusion? [IMG class=inlineimg]/forum/images/smilies/buttkick.gif[/IMG] [IMG class=inlineimg]/forum/images/smilies/lachen.gif[/IMG]
Am I missing something or are you ignoring the 6700k on those results?
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 4.2Ghz w/ 1v
Maximus VIII Formula
Radeon VII @ 1900Mhz/1250Mhz w/ 1v
TeamGroup Xtreem 16GB 3866Mhz CL15
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
Samsung 850 Evo 500GB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector Radeon VII - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Clear Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #52 of 112 (permalink) Old 06-25-2019, 06:44 AM
News Fiend
ryan92084's Avatar
Elchap's ryzen 2nd gen review early wasn't too hot iirc several of the scores were lower than more reputable sites. Probably from non release drivers etc and this one has leaked even earlier than last time.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #53 of 112 (permalink) Old 06-25-2019, 07:34 AM
Asterox's Avatar
Rep: 20 (Unique: 18)
Quote: Originally Posted by WannaBeOCer View Post
The Ryzen 5 3600 single core performance is 6.49% faster than Skylake in Cinebench R15 at the same clock speed.
Cinebench R15 is old software, so only "Cinebench R20 is version" that should be used for good comparison.
"Singlethread Cinebench R20"
Intel Skylake CPU 4.2ghz, 445
AMD Ryzen 3000 4.2ghz, 487
https://www.reddit.com/r/Amd/comment...t/r5_3600_r20/
https://www.computerbase.de/thema/pr...ead-ergebnisse
Asterox is offline
post #54 of 112 (permalink) Old 06-25-2019, 08:36 AM
5.3 Ghz 8 Core When
aDyerSituation's Avatar
Rep: 93 (Unique: 66)
What benchmarks are you looking at?
Dang
(16 items)
i7 7820x @ 4.6ghz, 3.2ghz Mesh Delidded
X299 ASUS ROG Strix-E
MSI Quicksilver 1070 8GB
32gb 3800mhz 16-17-16-37-1T (Model F4-3600C16Q-32GTZKK)
Intel 730 256gb SSD
Intel 530 256gb SSD
Seagate Barracuda 2TB HDD
Seagate Barracuda 1TB HDD
EVGA 750w G2
Deepcool Captain 240EX White
NZXT H440
Operating System
Windows 10 Pro
AOC G2460PF 24” 144hz FreeSync
Mouse
Zowie EC1-A
Mouse
Huge
Other
Dr Pepper, Monster, and Vape
aDyerSituation is offline
post #55 of 112 (permalink) Old 06-25-2019, 09:16 AM
zGunBLADEz's Avatar
Rep: 99 (Unique: 72)
idk but that 3600 is pretty close on those benchmarks against the 9900K which dont follow tdp to begin with and boost to 50x
mind you 42x $199 cpu is not even the x cpu
you going to show fps on 1080P and 720P show me as well gpu usage graphs as i want to see how far they are between both in that department..
dont see no point of seeing fps with 60-70% load on a gpu uncapped fps.. we need gpu load graphs on cpu bottlenecks
even a ram tweak match that
btw 42x on skylakeish cpu in cb15 is 180
amd have the ipc advantage big time this time..
zGunBLADEz is offline
post #56 of 112 (permalink) Old 06-25-2019, 10:31 AM
⤷ αC
AlphaC's Avatar
Rep: 904 (Unique: 590)
It's a good thing PC gaming isn't where the money is being made with Ryzen (they're using salvages from EPYC and probably keeping some for Threadripper). There's so many people that are simply too young to remember a time when AMD was on top (Athlon 64). Those same people tend to be the techtubers and such. I don't know how AMD can shake the "value brand" stigma after being close but not faster for so many years along with the epic failure of the Bulldozer line.
Anyone with an impartial view can see that Intel is in deep trouble because people that actually use their PCs for more than just gaming at 720p/1080p will benefit from higher efficiency , higher IPC, and automatic boosting to max clock on all cores even on stock cooler (Wraith Spire was used for R7 1700 as well). That is not even counting the Intel security patches that haven't been finalized. If you have a 65W part on stock cooler at out of the box clocks even close to the performance of an i7-9700K/i9-9900K how is that not a win for AMD? It's $200 versus a $400-500 part which requires more cooling, a Z390 motherboard that isn't garbage (~$100 MSI Tomahawk or ~$130 B450 Pro Carbon is likely to run the Ryzen 5s), and also z390 has zero upgrade path whereas any half decent AM4 board is going to be able to go up to 12 cores and 16 if you have x570.
Before Ryzen 3rd gen Intel still had an AVX2 advantage, with Ryzen 3rd gen the AVX2 performance is double wide. The only thing that remains for Intel is AVX-512 which is very rarely used.
If you recall Athlon64 was to Pentium 4 what this Ryzen 3rd gen chip generation will likely be to the 14nm+++ Intel chips. Athlon XP/MP was already competitive with Pentium 4 as it largely improved FPU, also was first CPU to 1GHz. Guess who led K8 (Athlon64)? Jim Keller. Who had a large hand in the Zen architecture? Jim Keller.
Even before that the K6-III led in frequency versus the Pentium III although pricing was not a strong suit. K6 is credited with bringing computing to the masses , clock for clock matching Pentium II except when FPU was used.
It wasn't until Intel Core that Intel really was ahead.
Anyhow consoles are bought by people that don't care about the brand of CPU. Zen 2 is also going into consoles. For the first time in a very long time AMD CPUs are also being used in mainstream laptops and even the iconic Thinkpad rather than low-end budget models. Every laptop / ultrabook / all-in-one worth buying that doesn't have strong Nvidia GPU or an 8th gen Intel CPU with 6+ cores is an AMD Ryzen product more or less.
It was definitely a smart business decision by Lisa Su and all others involved not to market to DIY. Breaking into the cloud space with Google Stadia (people don't care if they don't even own the GPU), breaking into the Apple ecosystem with radeon GPUs (guess what people don't care about the GPU if it's Apple products), breaking into mobile with Samsung partnerships, going for cloud compute with Amazon AWS + Baidu + Alibaba and Microsoft Azure as well is going to help AMD generate funds for R&D. Anything that needs x86 still isn't run on ARM yet without work done compiling , which isn't always feasible for closed source.
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #57 of 112 (permalink) Old 06-25-2019, 10:38 AM
5.3 Ghz 8 Core When
I want to see what the 3800x can clock to. 4.7 all core should match a ~5ghz 9900k hypothetically
Dang
(16 items)
Intel 730 256gb SSD
Intel 530 256gb SSD
EVGA 750w G2
NZXT H440
Operating System
Windows 10 Pro
Mouse
Zowie EC1-A
Mouse
Huge
Other
post #58 of 112 (permalink) Old 06-25-2019, 01:56 PM
Madonion.com
Damage Inc's Avatar
Rep: 2 (Unique: 2)
I leaked AMD64 numbers a month before its official release. Put a 3200+ on top of the ORB too. Back then, no o/ced P4 could touch an average 3200+ unless cooled with LN2. I sure hope you're right and I want AMD to beat Intel, but that vcore at 4.2Ghz worries me unless AMD use the worse silicon on the entry level chips.
Some people do remember. I'm the guy who leaked the 3200+ scores back in 2004 if I remember correctly, put one on top of the ORB twice after years of Intel's 3D dominance. I think me and JCViggen were the first people to post the FX-51 numbers too.
Damage Inc is offline
post #59 of 112 (permalink) Old 06-25-2019, 04:15 PM
⤷ αC
AlphaC's Avatar
https://elchapuzasinformatico.com/20...0-x570-review/
(x570 board)
The AIDA64 memory write is still busted it seems but the latency is now 75ns.
AlphaC is offline
post #60 of 112 (permalink) Old 06-25-2019, 06:17 PM
tyvar's Avatar
Rep: 14 (Unique: 10)
[QUOTE=Pendulum;28016230]The 3700X/3800X aren't going to be much faster than the 3600 in single core/gaming is my point. I paid $288 for my 6700K 4 years ago, while it was initially slightly more expensive than the 3600 that was also 4 years ago and my CPU is considered ancient tech at this point.
While I want AMD to dethrone Intel to break up their monopoly it doesn't look like they're going to do so in gaming performance quite yet and hopefully AMD can gain the lead until Intel can produce 7nm.
Your CPU isn't considered ancient tech. The days of CPUs becoming obsolete rapidly are over, for good or ill, and will probably never come back. GPUs are probably hitting that point now.
With silicon chip design hitting hard physical limits in what can be done, we may be looking at much longer development times for improved processors.
Lots of efforts will now be spent in optimizing chip layouts (by hand even) and software, to give us those last bits of IPC increases without ballooning die sizes, while software cuts out the cruft to run more efficently. Thats the future of computing technology over the next decade or two.
tyvar is offline
