Ryzen review leaked - Ryzen 3900X and 3700X Review PCGH - Page 3 - Overclock.net - An Overclocking Community
Closed Thread
post #21 of 113 (permalink) Old 07-05-2019, 11:57 AM
Cuthalu's Avatar
Rep: 0
Quote: Originally Posted by Imouto View Post
On one hand we have the scholars who want completely irrelevant and out of touch performance data.
On the other we have sane people who'd like actual, real life workloads results.
So you're saying there aren't anyone gaming @ 144+ Hz, really?
First and foremost CPU benchmark needs to test CPU, not GPU. Otherwise there's not that much point and validity to the test. And then we have a lot of people who desire high fps for their high Hz monitors AND televisions. 720p is just one way to really test CPU and to reflect actual usage scenarios where people target specific or as high as possible fps.
Obviously one way to achieve similar results would be using 1080p or 1440p with the LOWEST possible game settings instead of ultras, again creating a CPU dependent high FPS scenario.
Cuthalu is offline
post #22 of 113 (permalink) Old 07-05-2019, 12:10 PM
Founder
LiquidHaus's Avatar
Rep: 78 (Unique: 72)
I'd like to say let's move passed the 720p dilemma/discussion.
But there's not much left to say other than lets see how other reviews pan out. The images look as though it was one part of a test that was a multiple part test of different resolutions/settings/etc.
We've got two days left and the NDA won't be a problem anymore. I'm as anxious as anyone because my wallet is fully prepped for this release. I still have very high hopes for the end results of multiple reviewers.
Motherboard manufacturers wouldn't have doubled down on creating these very expensive boards if it wasn't going to be worth it to them (low projected sales)
www.liquid.haus
Team Heatkiller
LiquidHaus is offline
post #23 of 113 (permalink) Old 07-05-2019, 12:12 PM
momonz's Avatar
Rep: 23 (Unique: 16)
2019 and people still defending 720p testing for highend CPU doesn't make sense for practical reasons.
1080p should be the minimum.
black or white
(17 items)
AMD Ryzen 3600
Asus Strix X470-i
XFX RX 480 GTR Black
GSkill Trident Z 16gb 3200mhz B/W
Samsung 970 EVO 1TB
Samsung 850 EVO 500gb SATA
WDC Caviar Black 1tb
Seasonic SGX-500
Cryorig H5 Universal
NZXT H200i Black
Operating System
Windows 10 Pro
Asus PB298Q
Keyboard
Ducky One TKL RGB white/white
Mouse
Logitech G302
Mousepad
SteelSeries QCK Mini
Audio
SteelSeries Arctis Pro with DAC
Audio
Hivi Swans M10
momonz is offline
post #24 of 113 (permalink) Old 07-05-2019, 12:15 PM
Imouto's Avatar
Rep: 228 (Unique: 109)
Quote: Originally Posted by Ultracarpet View Post
If you are gaming at 60hz literally any CPU released in the last decade will probably be fine. There is almost 0 point in comparing a bunch of games at 1440p or 4k maxed settings with different CPU's just to find out that they have a variance of 5 FPS from top to bottom of the stack.
Oh, there are plenty of reasons to compare them. Mainly minimums, 1% and 5% worse/better frame times, total load and load across cores and also frame time graphs. All of these are far more interesting than 720p gaming tests.
144+ Hz at 720p? I'm pretty sure I could count them with one hand. Worldwide. Not counting that Russian guy at the ISS.
There are more metrics than minimums and average FPS which are far more interesting than this 720p HFR nonsense. I, for once, will be waiting for the Digital Foundry review. Really liked the way they present data.
https://www.eurogamer.net/articles/d...0-super-review
#EnthusiastLivesMatter
Imouto is offline
post #25 of 113 (permalink) Old 07-05-2019, 12:22 PM
Ultracarpet's Avatar
Rep: 216 (Unique: 139)
Quote: Originally Posted by EastCoast View Post
Didn't this website also sign Nvidia's NDA 2.0? In any case this review is completely useless. No one in their right mind is going to try to extrapolate 720p results for those who have monitors at 1080p, 1440p and 4K, for example.
If they want to include 720p they also have to include higher resolutions so you can reference the difference. As their results typically won't coincide with other reviews.
This all comes off as a "hit piece" leak article
Why is creating a CPU bound scenario so hard for people to understand. This is honestly blowing my mind.
The 720p results show exactly what the CPU is capable of producing in terms of FPS on that given game/engine. It is not difficult to extrapolate.
By referencing GPU results from Rise of the Tomb Raider and pairing with the data from the 720p results of this leak, I could make you very accurate fake graphs that would be within like 5% of reality (given that the same parts of the game were benchmarked). For example, in Guru3d's 2080ti review, the 2080ti was capable of 81 fps at 4k max settings in rise of the tomb raider. Guess what the CPU graph would look like at 4k for this game? Hint: There would be a lot of results around 80fps lol.
The 720p results matter because it gives you the info you need to make an informed choice about purchasing a GPU and Monitor. If a CPU is only managing 140 fps at 720p and you are buying a GPU capable of 250 fps at 1080p, then you either need a faster CPU or you can buy a cheaper GPU because your FPS isn't going higher than 140 at any resolution... and there would be almost no point in buying a 240hz monitor over a 144hz monitor.
Ultracarpet is offline
post #26 of 113 (permalink) Old 07-05-2019, 12:23 PM
Laptop Enthusiast
Imglidinhere's Avatar
Rep: 447 (Unique: 333)
Quote: Originally Posted by lifeisshort117 View Post
I'm okay with what I'm seeing. As far as I can tell, the scores were obtained only at 3.8ghz for the 3900x.
If that's the case, then the 15% IPC uplift means it's operating at an effective 4.35GHz roughly compared to previous gen chips? HMM...
SKYNET v3.1
(17 items)
SKYNET Mobile v3.0
Inspiring Greatness
Ryzen 5 2600
ASRock B-450M Pro4
6GB GTX 1060
16GB Corsair DDR4 LPX @ 3000 CL15
Sabrent 256GB NVMe SSD
1TB WD Black NVMe SSD
512GB Samsung 840 Pro SSD
1TB WD Black HDD - External
650w Antec NeoECO
AMD Wraith Stealth
Fractal Design Define Mini-C
Operating System
Windows 10 Pro
DELL S2419NX
Keyboard
RedDragon K556
Mouse
Logitech G502 Proteus Spectrum
Audio
HyperX Cloud Revolver-S Headset
Audio
Bose Companion 2 Series III
i7-8750H @ 3.9GHz
Intel HM370
6GB GTX 1060
32GB DDR4 2666
256GB SSD
500GB Samsung 840 Pro
1TB Western Digital Black NVMe SSD
180w Power Adapter
Tongfang GK5CN6Z
Operating System
Windows 10 Home
1920x1080 144hz IPS Display
Mouse
Mousepad
Xtrac Ripper
Intel Core i5-6300HQ
Dell Proprietary
4GB Nvidia GTX 960M
Samsung 12GB (1x8GB 1x4GB) DDR3L 1600 MHz
256GB SanDisk M.2 SSD
1TB HGST 7.2k HDD
130w PSU
Custom Cooling by Dell Solutions
Operating System
Windows 10 Home 64-Bit
15.6" 1920x1080 IPS Screen
Keyboard
Dell
Mouse
Logitech G602 Wireless
Mouse
Xtrac 'Ripper' Mouse Pad
Imglidinhere is offline
post #27 of 113 (permalink) Old 07-05-2019, 12:24 PM
Ding Chavez's Avatar
Rep: 25 (Unique: 24)
Why is the 8600K faster than 9600K? Looks like a mistake. I'll wait for proper reviews.
Ding Chavez is offline
post #28 of 113 (permalink) Old 07-05-2019, 12:27 PM
ejb222's Avatar
Rep: 28 (Unique: 23)
I'm no expert, but 720 benches are misleading in my opinion. I game at 3440x 1440 so the percentage variations in 720 are never realized at my resolution. Why pick 720...why not 360p or use Duke Nukem 3d?
"Everybody wants to go to heaven but nobody wants to die."
ejb222 is offline
post #29 of 113 (permalink) Old 07-05-2019, 12:32 PM
AmericanLoco's Avatar
Rep: 112 (Unique: 70)
720P measures only the CPU. It basically eliminates the GPU from the equation. Back in the day when every gamed at 1024x768 and 1600x1200, all of the CPU reviews would use 640x480 or 800x600. However, I think reviews that ONLY do 720p are kinda useless, as at that point you're basically measuring how fast the CPU can execute the game engine's main thread. At higher resolutions, the CPU also starts getting busier doing other things - like issuing draw calls to the GPU, computing geometry, etc... I think these days, 1080p is a good balance between GPU use and CPU usage.
AmericanLoco is offline
post #30 of 113 (permalink) Old 07-05-2019, 12:38 PM
Cuthalu's Avatar
Rep: 0
That's fine as long as it's tested with the lowest possible settings. The problem is that most reviewers only know how to write "max" and "ultra", while all other settings are left untested. Besides, lowest possible res with lowest possible settings would still be an interesting data point in itself.
Cuthalu is offline
Closed Thread
