[WCCF] AMD Zen 3 set to deliver >8% IPC with 200 MHz better clock. - Page 6 - Overclock.net - An Overclocking Community
post #51 of 67 (permalink) Old 10-16-2019, 04:34 AM
reqq's Avatar
Rep: 9 (Unique: 9)
Quote: Originally Posted by guttheslayer View Post
The extra latency lies within chiplets as well, a multiple chiplet CPUs will have 2 layers of latency when communicating with the I/O
Improving the inter-CCX within chiplet (by merging them as 1 CCX) will reduce one layer of latency, which means it should bring performance improvement across all products of Zen 3, regardless if the CPU has 1 or 8 chiplet.
Hence to answer your question, no. The latency will remain between chiplet to chiplet but it will be still faster overall when compared to multiple chiplet Zen 2.
Cant they improve IF speed and IO speed? Intel ring bus seems to go at 4000 mhz ++ while Ryzen IO and IF is like same speed as your memory, 1800 mhz??
reqq is offline
post #52 of 67 (permalink) Old 10-16-2019, 06:35 AM
News Junkie
Newbie2009's Avatar
Rep: 300 (Unique: 234)
When is Zen 3 out?
All AMD PC
(9 items)
AMD 3600X - stock
Asrock B450 Micro ATX Fatality
5700xt Anniversary Edition 2150/900
Corsair 3200mhz 16gb @ 3466mhz
1tb m.2 SSD
Corsair SFX 750
Fractal Design Node 202
Operating System
Windows 10
Sony 55"
Newbie2009 is offline
post #53 of 67 (permalink) Old 10-16-2019, 07:42 AM
EniGma1987's Avatar
Rep: 342 (Unique: 252)
There are two Infinity Fabrics, one "external" and one "internal". The external one is what goes to memory and other sockets and such and runs at memory speed. Internal one was already doubled in speed with Zen2, and that is used for inter-CCX communication and things like that. AMD has already said internal IF will not increase in Zen3.
EniGma1987 is offline
post #54 of 67 (permalink) Old 10-16-2019, 07:09 PM
Hey I get one of these!
KyadCK's Avatar
Rep: 315 (Unique: 220)
Well, no, not really, not for Ryzen 3/ Zen 2.
All four CCXs go to the IO bridge using IF. IO bridge goes to the RAM at just DDR, not IF. CCXs do not communicate with each other directly.
Courtesy of Reddit;
Forge
(15 items)
AMD Ryzen R9 3900X
Gigabyte X570 Master
AMD 5700XT PowerColor Devil
32GB G.Skill TridentZ Neo (2x16GB 3600Mhz/C16)
Intel 900P 480GB
Corsair AX1200
Corsair H150i
Phanteks Evolv X
Operating System
Windows 10 Enterprise x64
2x Acer XR341CK
Keyboard
Corsair Vengeance K70 RGB
Mouse
Corsair Vengeance M65 RGB
Audio
Sennheiser HD700
Audio
Sound Blaster AE-9
Audio
Audio Technica AT4040
KyadCK is offline
post #55 of 67 (permalink) Old 10-17-2019, 07:50 AM
EniGma1987's Avatar
Courtesy of Reddit;
Attachment 301030
Regardless how the CCXs communicate, with each other directly like in Zen1 or through IO die in Zen2, it is internal IF. Which already doubled in bandwidth and is not getting a speed boost in Zen3 according to AMD.
post #56 of 67 (permalink) Old 10-18-2019, 01:21 AM
PC Enthusiast
VeritronX's Avatar
Rep: 30 (Unique: 30)
The difference is there is no extra IF latency involved with core to core traffic on the single CCD designs in zen 3 if they are one single CCX, and what was previously two seperate links to the IO die per CCX could probably be combined into one larger link. It wouldn't surprise me if the IO die was kept the same and just routed slightly differently.
Edit: Did some testing, my 3600X when at 4.2Ghz with tightened 3200C14 ram gets a core to core latency of 50.4ns average (11.4-73.5ns) and the same chip with only one CCX enabled (3+0 mode) has an average of 24.5ns (11.9-29ns) using sisoft sandra's multi core efficiency test.
VeritronX is offline
post #57 of 67 (permalink) Old 10-18-2019, 07:24 AM
Otherworlder
epic1337's Avatar
Rep: 222 (Unique: 128)
am i the only one who noticed the L3 cache in the Milan CCX?
32+ MB L3, does this mean we'll encounter a die with more L3 per CCX? 64MB? 128MB?
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #58 of 67 (permalink) Old 11-19-2019, 01:10 AM
kapulek's Avatar
Rep: 7 (Unique: 6)
kapulek is offline
post #59 of 67 (permalink) Old 11-19-2019, 08:47 AM
Overclocker
JackCY's Avatar
Rep: 346 (Unique: 244)
And in the end it turns out that the for server designed dies have more cache and clock 200MHz higher on boost clock while all of this makes zero difference for regular people retail products used for desktop PCs.
SMT4 is the same, makes sense for server farms, not for gaming
JackCY is offline
post #60 of 67 (permalink) Old 11-19-2019, 07:11 PM - Thread Starter
guttheslayer's Avatar
Rep: 111 (Unique: 65)
They combined 4 Cores CCX to 8C CCX that itself is a big leap. There might be alot of others minor optimization which add up to pretty big gains.
All in all, the latest improvement will definitely help in games and we could possible see >10% more FPS compared with Zen 2 (with everything considered). That could possibly be just enough to edge out the 9900KS.
guttheslayer is offline
