WCCF: Intel Core i9-10900K 235W Power at 4.8 GHz – Over 90C Temps With a 240mm AIO Cooler - Page 10 - Overclock.net - An Overclocking Community
post #91 of 111 (permalink) Old 05-19-2020, 05:09 PM
Mooncheese's Avatar
Rep: 20 (Unique: 16)
Quote: Originally Posted by Falkentyne View Post
You gave the wrong numbers in the PM. You gave me current IIN which is the power supply current to the VRM.
And 2.1 mOhms loadline on an 8700k:
1520 - (2.1 * 111) =1.286.9 volts. (vdroop=223mv)
Then for fixed vcore, you simply have to plug in the BIOS voltage set and the loadline calibration mOhms value if you know it. Then you cross-reference the 1286.9 volts to see how close you are to it.
Example:
if you used 1.350v set in BIOS with a Loadline Calibration of 0.525 mOhms, pulling 111 amps (Probably LLC6/Turbo on gigabye or Asus):
1350mv - (111 * 0.525)=1.291v.
So you would be good with 1.350v set in BIOS with LLC=Level 6 or = Turbo.
Keep in mind that this does not guarantee CPU longevity. It only guarantees that the CPU will not degrade suddenly. For guaranteed longevity, power limits and TAU and thermal limits must not be exceeded.
I apologize, ok so Current (IOUT): 111a is the correct value and going by your math that would put max safe voltage in BIOS at 1.350v assuming ~.500mv of LLC (Gigabyte, Turbo)?
I'm currently at 1.386v @ 5.1 GHz, 0 AVX, so I'm actually beyond 1.52v limit accounting for LLC on this board and need to dial it back?
8700k @ 5.1 GHz - 0 AVX @ 1.386v Dynamic Offset w/ EK Monoblock + Delid | Gigabyte Z370 Aorus Gaming 7 | EVGA 2080 Ti XC2 Ultra @ 2070 Mhz core, 8025 MHz memory @ 1.019v w/ 375W FTW3 vbios + Phanteks Glacier Block | EK CE 420 + EK XE 360 | 2x16GB G-Skill Trident Z Royal 3600 MHz 17-20-20-38 | 2 TB Sabrent Rocket | Corsair RM1000x | Thermaltake View 71 | Alienware AW3418DW + Asus ROG Swift PG278Q (for 3D Vision) on Amazon Basics Arms | Win10 Pro 1809
Mooncheese is offline
post #92 of 111 (permalink) Old 05-19-2020, 05:15 PM
Facepalm
Falkentyne's Avatar
Rep: 455 (Unique: 316)
If you value the life of your CPU, I would pull it back a little, yes.
Keep in mind that cooling also matters here. If you were running sub-ambient or on chilled water, exceeding the curve a bit (like your 1.386v set) would not be a problem at all.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #93 of 111 (permalink) Old 05-19-2020, 06:52 PM
Mooncheese's Avatar
Load temps don't exceed 65C with a good delid, is this not low enough? Also, all of this is assuming LLC on Gigabyte Z370 Aorus Gaming 7 is .500mv @ Turbo? Turbo isn't the highest setting, it's one step down from highest, highest on this board is Extreme.
I have a multimeter but can't seem to find out where exactly the voltage pins are on the back of the mobo and can't find any information on this via the internet. It's also not mentioned in the manual. Does anyone know how to measure voltage on Gigabyte Aorus Gaming 7?
post #94 of 111 (permalink) Old 05-19-2020, 07:00 PM
Facepalm
Falkentyne's Avatar
LLC High is 50% vdroop reduced and Turbo "should" be 75% reduced. At least this is it on Z390. I heard Z370 had some funky stuff going on with 9900K's installed however.
default LLC is 2.1 mOhms (Standard/Normal= 2.1 mOhms). So High on your board "should" be 1.05 mOhms and Turbo should be 0.525 mOhms.
post #95 of 111 (permalink) Old 05-19-2020, 07:06 PM
Vermin Supreme 2020
skupples's Avatar
Rep: 734 (Unique: 386)
Quote: Originally Posted by junglechocolate View Post
LMAO I swear every build I see on youtube has one of those with their nice RGBs. So air cooling is still superior ?
custom loops are still superior.
Add me on Steam, same name
skupples is offline
post #96 of 111 (permalink) Old 05-19-2020, 08:30 PM
High Clocker
bmgjet's Avatar
Rep: 191 (Unique: 165)
Still no reason to upgrade from this 7900X at mixtures of 5.0-5.1 core speeds.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #97 of 111 (permalink) Old 05-20-2020, 08:09 AM
Mooncheese's Avatar
post #98 of 111 (permalink) Old 05-20-2020, 11:44 AM
m4fox90's Avatar
Rep: 18 (Unique: 16)
Hm...I feel ignored
He's literally on my ignore list lmao
Silence in the Snow
(12 items)
Ryzen 3900X
ASRock X370 Taichi
RTX 2080Ti Black Edition/Hydro Copper
G.Skill RipJaws V 16 GB
Samsung 960 EVO 500GB
2x WD 1 TB SSD
EVGA G3 1000W
EK PE360 + Hardware Labs Black Ice GTS360
EK Supremacy EVO
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Home
Predator XB271HU
m4fox90 is offline
post #99 of 111 (permalink) Old 05-20-2020, 12:16 PM
OG AMD
Redwoodz's Avatar
Rep: 600 (Unique: 465)
Quote: Originally Posted by WannaBeOCer View Post
10 cores on a single die running at 4.8Ghz+ is an achievement AMD will never be able to achieve.
LOL. They had the first 5.0GHZ 8 core cpu did you forget?
https://valid.x86.fr/cache/banner/4d8m5e-6.png
https://valid.x86.fr/cache/banner/bs72bx-6.png
AMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
RedwoodCustomPC
AM4
(6 items)
Redwoodz
(10 items)
Professional
Ryzen 5 2600
ASRock X470 Taichi
MSI RX570 Armor MKII 8GB
GSKill Trident Z D-die
TeamGroup Excalibur
GSKill Ripjaws PS850G
AMD FX Vishera 8350
ASRock Extreme 9 990FX
HIS X 7970 IceQ
Gskill Trident
Samsung 840 Pro
Seasonic SS-760XP
TT Water 2.0
Samsung Series 9 27"
Keyboard
Mionix Zibal
Mouse
Mionix 5000
Phenom II X6 1100t
MSI 890FX GD65
MSI Radeon HD5670
GSkill RipjawsX DDR3 PC3 12800 2x4GB CL8
WD Black 1TB SATA III
Optical Drive
Samsung BD
Kingwin Lazer Platinum 500w
Zalman 9900MAX
Fractal Design R3
Operating System
Windows 7 64 Professional
AOC 22" LED
Keyboard
Logitech
Other
Samsung 470 SSD 128GB
Redwoodz is offline
post #100 of 111 (permalink) Old 05-20-2020, 12:20 PM
sudo apt install sl
Rep: 191 (Unique: 131)
You mean 4 modules with 1 shared FPU?
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector RTX RE Ti - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Solus Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
