[WCCF] RTX 3080 Timespy Extreme is alleged to be 35% above 2080 Ti - Page 3 - Overclock.net - An Overclocking Community
post #21 of 157 (permalink) Old 08-01-2020, 04:29 PM
sudo apt install sl
Rep: 196 (Unique: 132)
Quote: Originally Posted by EastCoast View Post
It's real funny isn't it? An entire data base of results proving you wrong. I want your tears fresh. If I see salt sentiment at the bottom of my flask I'm sending it back. [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
I love your new trolling attitude on these forums. Makes it lively again.
Silent
(20 items)
Core i9 9900K... CoffeeTime! @ 5.1Ghz w/ 1.36v
Maximus VIII Formula
Titan RTX @ 2100Mhz/2075Mhz
TeamGroup Xtreem 32GB 3200Mhz CL15
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
EVGA SuperNova 1200w P2
EK Supremacy Full Copper Clean
XSPC D5 Photon v2
Black Ice Gen 2 GTX360 x2
EK-Vector RTX RE Ti - Copper + Plexi
Thermaltake Core X5 Tempered Glass Edition
Operating System
Solus Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Alugraphics GamerArt
Audio
Definitive Technology Incline
Audio
SMSL M8A
WannaBeOCer is offline
post #22 of 157 (permalink) Old 08-01-2020, 04:31 PM
reflex75's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by Asmodian View Post
Quote: Originally Posted by reflex75 View Post
If power consumption increases as much as perf, then it's not really improving overall.
Should compare 2080ti vs 3080ti both at the same 250w TDP to check the real progress...
I disagree, if we are evaluating the technology you are correct but if we are evaluating the GPU I don't care how much power it uses (assuming I can still cool it with a water block). Even if we have no gain in efficiency I would still want a GPU that could do 2x what my 2080 Ti can. I have a 4K120Hz display and I want to be able to drive it with one GPU.
Childish brute force thinking...
You can already reach that level of performance with 2080ti by using massive cooling if you don't care about efficiency.
And in few generations we will use power plant for a single gpu to still improve performance...
reflex75 is offline
post #23 of 157 (permalink) Old 08-01-2020, 04:41 PM
sudo apt install sl
Because 400w is not enough for A100 SXM4 and limits its boost frequency at only 1410Mhz.
Again the PCIe version is rated at 250w and the card has 6912 CUDA cores. We won't have that many CUDA cores. We never had a Ti card that had a power target more than 250w.
Silent
(20 items)
HP EX950 2TB
Samsung 850 Evo 1TB
Samsung 850 Evo 1TB
XSPC D5 Photon v2
Operating System
Solus Linux
Acer XF270HUA
Keyboard
Cherry MX Board 6.0
Mouse
Logitech G600
Mouse
Audio
Audio
SMSL M8A
post #24 of 157 (permalink) Old 08-01-2020, 04:42 PM
Retired Staff
JedixJarf's Avatar
Rep: 307 (Unique: 246)
That's against a stock OEM 2080ti. When you factor in OC'd cards like the Kingpinm etc. The difference can dwindle down to 20% - 0%.
https://www.3dmark.com/hall-of-fame-...sion+1.0/1+gpu
The reason that argument sucks is because you can OC the the 3080ti too (presumably).
JedixJarf is offline
post #25 of 157 (permalink) Old 08-01-2020, 04:47 PM
Overclocker
EastCoast's Avatar
Rep: 157 (Unique: 102)
The OC is always presented in the review so that's moot. It's up to the reviewer to expound on it. And, the results as a whole have always omitted their best OC'd card from the previous gen. Not just the OEM card. Thus making the percentage much larger then it really is.
Would you expect everyone with a 2080ti to have just a OEM? Of course not. So those cards, even if WC, should be factored in. If you really want to know if a 3080 is better then a 2080ti one would want to know what the percentage is based on more then just the OEM cards out there. It's a valid argument.
Now if you read the link in the OP it mirrors what I'm saying. In part it says...
When compared to the Turing cards, the GeForce RTX 3080 looks to be around 35% faster than a stock GeForce RTX 2080 Ti which would make it the biggest performance jump over the previous generation Ti offering. We also compared the score to my heavily overclocked RTX 2080 Ti graphics card (Lightning Z) and found the difference to end up around 12%.
Were I stated in an earlier post a difference between 20%-0%. Which I stand by (depending on OC card used).
EastCoast is offline
post #26 of 157 (permalink) Old 08-01-2020, 05:41 PM
Robotic Chemist
Asmodian's Avatar
Rep: 202 (Unique: 134)
No I cannot. I have shunt modded my GPU and use 12x140mm worth of radiator. If the technology cannot do it without brute force yet I will take brute force. In the end it is the performance that matters to me, a more efficient GPU is better but only if it is at least the same speed. I do not want power limits to hold back performance.
I understand I am not everyone but I am not sure how it is childish.
I guess I can see comparing the scores from an early/stock 3080 to a max OC 2080 Ti under water but you are using the scores from cards running under N2 or dry ice. Your point seems to be that a 3080 is 0% faster than a max OC 2080 Ti under N2, but you conveniently don't mention the exotic cooling, which changes how impressive that statement sounds fairly significantly.
A 3080 matching a 2080 Ti under N2 sounds pretty good instead of diminishing the improvement so you leave that part out, because spin is always the name of the game for you.
"Soldering resistors onto your video card to bypass the manufacturers over current protection kind-of sort-of absolute-definitely voids your warranty"
Desktop
(17 items)
AMD Ryzen 3950X
Asus Crosshair VIII Hero
Nvidia 2080 Ti
32GB DDR4 3600
Intel 900P
Samsung 960 Pro
Optical Drive
Asus BW-16D1HT
Seasonic 1200W
EK Velocity + EK GPU Block
Old Marble Slab
Operating System
Windows 10 Pro
LG C9 55"
Keyboard
Wooting two
Mouse
Logitech G903 Lightspeed
Mousepad
Logitech G PowerPlay
Audio
Arctis Pro Wireless
Other
Mellanox 40GbE
Asmodian is online now
post #27 of 157 (permalink) Old 08-01-2020, 05:48 PM
Spaghetti
Buris's Avatar
Rep: 43 (Unique: 35)
Quote: Originally Posted by WannaBeOCer View Post
Why do you think the power target is higher than 250w? A 6912 core A100 uses 250w, we're definitely not getting that many CUDA cores.
1. The A100 runs at a pretty low clock, which isn't great for most games.
2. The A100 is the only Ampere GPU that's confirmed to be on TSMC's 7nm, the rest will supposedly be on Samsungs 8nm, which is significantly less efficient (only +10/15% Perf/W over TSMC's 12nm)
MARS
(18 items)
Ryzen 9 3900x
Gigabyte X570 Aorus Master
EVGA 1080 Ti FTW3
G-Skill Sniper
WD EMAZ001
WD Black SN750
EVGA G3
Noctua U12A
NZXT H500
Operating System
Microsoft Windows 10
Operating System
Pop! OS
BenQ XL2730z
Keyboard
Aukey Mechanical
Mouse
Mionix Castor
Mousepad
Aukey
Audio
PreSonus Eris E3.5
Audio
SennHeiser 598
Audio
Blue Yeti
Buris is offline
post #28 of 157 (permalink) Old 08-01-2020, 05:57 PM
Facepalm
Falkentyne's Avatar
Rep: 463 (Unique: 321)
This guy speaks the complete truth.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #29 of 157 (permalink) Old 08-01-2020, 06:11 PM
wingman99's Avatar
Rep: 63 (Unique: 46)
From what I see with exotic cooling and overclock folks only gain 1-3% performance improvement in benchmarks.
i5 8600K @ 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB DDR4 XMP 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #30 of 157 (permalink) Old 08-01-2020, 06:31 PM
Overclocker
EastCoast's Avatar
Oh, you've shown me the light, hellelujah. Because the only way to get no temps in your score is to only use LN2.
But that's your narrative isn't it, the pic. It's the only result ever. It's the only result that 3Dmark has. It's the only result that matters. Because if I don't baby you into showing you the data base in my proir post all the scores then must be LN2 it is. Perhaps they used N2 as later noted in your post, lol.
No, if you read my post I said that it could be between 20-0%. But I get it, your panties are in a bunch on something you've deemed negative about nvidia. Not surprised in the slightest though. Grow some thicker skin.
A 3080 matching a 2080 Ti under N2 (??) sounds pretty good instead of diminishing the improvement so you leave that part out, because spin is always the name of the game for you.
As you've already seen, you don't need LN2. But nice attempt to pivot to change the narrative of the conversation. But I'm going to steer it back. And I want you to grab your jimmies because they might cause chaffing.
Now, if the performance is so good with 3080/3080ti why do they need to incorporate DLSS (rumored) to further improve performance? Anyone with a 2080ti can load up BF5 and see that unless they use 4k DLSS is disabled. The point being, drum roll....wait for effect...I'll get there soon enough...this is getting arkward...those results could have been provided using DLSS 3.0. Which means that it's brute force performance is much lower.
No you say? Put down the hand bag. And lets take a trip down memory lane and follow the yellow brick road. No, we aren't going to see the wizard. Just 3dMark Vantage were they allowed GPU Physx into the benchmark to boost hall of fame scores. Where you going? Ah, I see you remember. Carry on...
Oh my, it's like a watching old betties duke it out with hand purses. Arguing that Anacin is better then Bayer. Either or should help your "spinning" problem.
