The difference between the International and standard versions of Samsung Galaxy Tab S2 9.7"? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 01-19-2016, 07:21 AM - Thread Starter
lovepack's Avatar
Rep: 0
I cannot for the life of me find the difference in these models. I don't have the model number for the international version so when I called Samsung they were unable help.
lovepack is offline
post #2 of 7 (permalink) Old 01-19-2016, 07:59 AM
Retired Staff
coachmark2's Avatar
Rep: 487 (Unique: 382)
Generally, "International" refers to a GSM-capable device that is unlocked for use on any carrier. The International GSM+LTE edition of the Galaxy Tab S2 is model number SM-T815 and, of course, comes with an LTE modem and SIM card slot onboard.
There are variants for each carrier. Generally, AT&T takes the model number and adds an A to the end, T-Mobile adds a T, etc.
The Wi-Fi only model is the SM-T810
The unlocked international LTE model is the SM-T815
The AT&T cellular model is the SM-T817A
The T-Mobile cellular model is the SM-T817T
The Verizon cellular model is the SM-T817V
The Sprint cellular model is the SM-T817P
coachmark2 is offline
post #3 of 7 (permalink) Old 01-19-2016, 08:02 AM - Thread Starter
lovepack's Avatar
Rep: 0
Thank you! After hounding the Samsung rep I also discovered that the International model in this case does not come with any kind of manufactures warranty.
lovepack is offline
post #4 of 7 (permalink) Old 01-19-2016, 08:04 AM
Retired Staff
coachmark2's Avatar
Updated earlier post with model numbers
post #5 of 7 (permalink) Old 01-26-2016, 04:10 PM
Retired Staff
Robilar's Avatar
Rep: 675 (Unique: 477)
That's typically because the GSM versions of a lot of tablets are only released in specific markets. Thus if you are ordering a GSM supported tablet into the US from Asia, there is no warranty here for it.
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB x2 / 3TB x 2 - WD
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Scythe Big Shuriken 2 w/Corsair SP120 Fan
NMEDIAPC HTPC 6000B w/ Pro LCD Module
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #6 of 7 (permalink) Old 02-05-2018, 01:58 PM
Rep: 0
Compatibility motherboard
Hi I found this post and I have my motherboard broken, but it is a hard time to find an SM-T815 motherboard used. It is easier to find an SM-T817 but I don´t know about if a T-817 motherboard could be installed in a T-815.
I suppose that it could be installed and unlock after that.
Let me know your thoughts and Thanks!!
antonxerez is offline
post #7 of 7 (permalink) Old 07-03-2020, 06:15 AM
Hello everyone, well, I can't tell you what the difference is because I've never had this model before. I have the samsung galaxy a71 as a model and to be honest, I never thought I would say this about Android but I love it. Compared to the iPhone that I have been using for more than 5 years, the android turned out to be easier in my opinion. Yes, I agree that there is a difference in cost but if someone asks me what I can recommend from my own experience then my final answer will be: go for Samsung!
gravdesgdihoca is offline
