How would I fix this? - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 11-21-2017, 04:39 PM - Thread Starter
Samzon's Avatar
Rep: 2 (Unique: 2)
I'm asking for a friend who doesn't have a soldiering machine. How would she go about it?
Samzon is offline
post #2 of 10 (permalink) Old 11-21-2017, 04:51 PM
moisiss's Avatar
Rep: 5 (Unique: 5)
moisiss is offline
post #3 of 10 (permalink) Old 11-21-2017, 04:57 PM - Thread Starter
Samzon's Avatar
Rep: 2 (Unique: 2)
Originally Posted by moisiss View Post
Take it somewhere and pay someone who knows how to do it.
Eh. I was hoping for something we could try at home.. Thanks though!
Samzon is offline
post #4 of 10 (permalink) Old 11-21-2017, 05:05 PM
Computer Arsonist
NeoReaper's Avatar
Rep: 90 (Unique: 76)
There isn't any way of fixing that besides soldering, not reliably.
Piledriver Reborn
(20 items)
Intel I7 4770k 4.7Ghz
Asus Z97-P
Gigabyte RX 480 4GB (580 BIOS)
16Gb Corsair Vengeance PRO (4x4Gb) @ 2600Mhz
Kingston A1000 M.2 NVME 240Gb
Seagate Constellation ES 2TB
Western Digital Green 1TB
Corsair Modular RM650X
Corsair ML RGB 120mm x3 With Lighting Node Pro
Corsair H150i Pro
Gamemax Onyx Tempered Glass RGB
Operating System
Windows 10 Pro
Samsung 27" Curved S27D590C
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Dark Core SE RGB
Mousepad
Corsair Polaris RGB
Audio
Corsair Void Pro Wireless 7.1
Audio
Blue Raspberry
Audio
Corsair ST100 RGB
Other
Ikea Corner Desk
NeoReaper is offline
post #5 of 10 (permalink) Old 11-21-2017, 05:58 PM
essanbee's Avatar
Rep: 103 (Unique: 84)
Wire glue. Conductive glue.
http://www.thinkgeek.com/product/b70c/
Who knows???
Big Blue
(14 items)
Intel Core i5 2500K
P8P67 DELUXE
EVGA GTX 980 FTW
G.Skill
Western Digital WD1002FAEX-00Z3A0
Optical Drive
ASUS DRW-24B1ST
THERMALTAKE TOUGHPOWER XT 775W
SWIFTECH H20-320 EDGE HD APOGEE HD WATER BLOCK
APEVIA X JUPITER S TYPE METALLIC BLUE
Operating System
WIN7 64bit
ASUS VE258Q
Mouse
RAZER DEATHADDER 3500dpi
Audio
Creative Soundblaster Z
Other
SSD Samsung 840 EVO 250 GB for OS
essanbee is offline
post #6 of 10 (permalink) Old 11-25-2017, 11:14 PM
Retired Staff
Robilar's Avatar
Rep: 675 (Unique: 477)
Which tablet is it ?
Home PC
Intel G3440
Asus B85M-E/CSM
EVGA GTX 950
Patriot Viper 3 - 2x8GB 1600hz
Samsung EVO 850 - 500GB + 4TB x2 / 3TB x 2 - WD
Optical Drive
LG CH12LS28 Bluray
Corsair CX430 V2
Scythe Big Shuriken 2 w/Corsair SP120 Fan
NMEDIAPC HTPC 6000B w/ Pro LCD Module
Operating System
Windows 10 64 Bit
Samsung 75" TV....
Keyboard
GooBang Doo MX3
Mouse
GooBang Doo MX3
Robilar is offline
post #7 of 10 (permalink) Old 11-25-2017, 11:22 PM
Shaded War's Avatar
Rep: 180 (Unique: 154)
I'm sure one of your local retailers such as Walmart or a hardware store will have a soldering iron for under $10. My local walmart has a cheap one in stock for only $5.77.
Command Center 2.0
(14 items)
Intel i7-6800K
Asus Strix x99
Zotac GTX 1080 AMP
32GB Corsair Vengeance 3000Mhz
Samsung 970 Pro 1TB
Seagate 4TB HDD
Corsair AX850
Corsair H100i (original, not v1 / v2)
Corsair 600T
Operating System
Windows 10 Pro x64
3x Asus VE248Q
Samsung 55" 4K HDR Quantom Dot
Audio
Creative Titanium HD
Audio
Sennheiser HD700
Shaded War is offline
post #8 of 10 (permalink) Old 11-07-2019, 10:06 PM
kyliespirit's Avatar
Rep: 0
I'd better suggest taking it to a tablet repair shop instead of trying to do something you are not familiar. ou You might end up causing a disaster by trying to fix it on your own.
kyliespirit is offline
post #9 of 10 (permalink) Old 11-07-2019, 11:05 PM
Graphics Junkie
UltraMega's Avatar
Rep: 33 (Unique: 29)
I mean, it's only 4 connections and they are all pretty large. All you would really need to do is order a replacement plug if you cant reuse the one that came off and just heat up those 4 connection spots with a soldering iron enough to reconnect the plug. If you're gonna solder something, this would be an easy place to start. Watch some youtube videos on basic soldering. I'm not very good at it myself but I could solder that easy.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #10 of 10 (permalink) Old 11-07-2019, 11:37 PM
flearider's Avatar
Rep: 1 (Unique: 1)
unless you know how to solder ..it will be risky ..
you will need flux solder and a hot iron .. steady hands ..
flux the pads solder the tip of the iron .. and touch for a second or 2 on the pads ..
the hardest part will be the 6 wire connectors but with enough flux it should just run to the small pads .. a quick once over
flearider is offline
