Fast charger is not fast !! - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 04-22-2019, 01:47 PM - Thread Starter
Welliam's Avatar
Rep: 4 (Unique: 4)
I bought a fast charger Ldino has QC3 18W for tablet Asus s3 10 but the charging is still slow !! I only had to use old usb cable because this tablet has usb c and the charger cable come with micro usb so is this the reason ?
Welliam is offline
post #2 of 6 (permalink) Old 04-22-2019, 02:18 PM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
The protocols used on both devices have to be the same and compatible. Charger and device have to be able to take the extra power. Poor cable can heat up and reduce charging rate.
The way it fast charges is to force higher power delivery over communicating with the device to agree that it can take the up to 20V and 18W. They need the higher voltage to transfer higher power and lower losses at the cable, most USB cables (and even other) are pretty trash no matter what you buy.
I think the problem is your device is not QC3, it only says so on gsmarena but as far as I know QC3 is not on MediaTek? You need Qualcomm's Snapdragon for QC3. Sadly each company has tried to proprietarize their corner of the market and I don't think USB-PD is widely used yet that would work on any standardized device.
As far as I can find you can buy a fast charging Asus charger for this device but it's not included with the device, it's bought separately.
If you ask me, you could probably try Mediatek compatible fast charger, it's likely just Asus being fake (misleading customers with a more popular buzzword/brandword) and writing quick charge 3.0 when they should have written pump express 3.0.
JackCY is offline
post #3 of 6 (permalink) Old 04-22-2019, 02:23 PM - Thread Starter
Welliam's Avatar
Rep: 4 (Unique: 4)
Asus advertise this in all pages like their product page and even on Amazon. I tried some apps that measure the amp but it reported that my tablet does not has power profile so I can not get the reading from a software. btw I used the origingal cable and I dont have Asus QC3 here only that ldino.
Welliam is offline
post #4 of 6 (permalink) Old 04-22-2019, 03:09 PM
Overclocker
JackCY's Avatar
Yeah their marketing probably wrote what they want not what it actually supports. Dig around and you will find it what charger works and what fast charging is supported by the hardware used in the device.
There are USB meters that can show you the voltage and current being transferred (if you don't have a multimeter for measuring, those meters are easy to use if one plans to test and test a lot with their different devices). Don't bother with software apps.
JackCY is offline
post #5 of 6 (permalink) Old 05-01-2019, 10:48 PM
xxicrimsonixx's Avatar
Rep: 477 (Unique: 423)
Definitely try a quality USB cable (you mentioned it was old, but was it a brand name, or a cheap one?). Cables do make a difference, in both charging speed, and data transfer speed. Always make sure to use a quality one if possible.
I would suggest trying that first.
Steam/Origin ID: xxicrimsonixx
i7 4930K
ASRock Fatal1ty X79 Professional
Gigabyte Aorus 1080ti SLI
16GB G. Skill Ripjaws Z
2x 250GB Samsung 840 Series SSD RAID 1
2x 3TB Seagate Barracuda 7200.14 RAID 1
Optical Drive
Samsung Burner w/ Lightscribe
Cooler Master Silent Pro 1200W Gold
Custom Watercooling
Cooler Master HAF 922 w/ Dust Filters
Operating System
Windows 10 Professional 64-bit
55" 4K Samsung Curved TV
Keyboard
Roccat Sova Mechanical
Mouse
Roccat Kone XTD
Audio
Glow Amp One > HD650
Audio
Yamaha Receiver + 5.1
Other
Xbox One Wireless Controller
xxicrimsonixx is offline
post #6 of 6 (permalink) Old 10-27-2019, 06:11 AM
Thomas73's Avatar
Rep: 7 (Unique: 7)
There is one crucial point you missed,firstly most tablet require 9v 2a or 2.5a charging meaning your charger QC3 or not must be a 9v 2a at least & the usb C charging cable is compatible fo 9v 2a or 2.5a,most type c cables are designed for 5v 3a,huawei super charge cables 5v 4.5a,both of this would work great on any smartphone that supports QC 3 & 4,but would charge slowly on a tablet.This cable is specifically intended for PD & Tablet charging.https://shopee.sg/Vention-USB-Type-C...kaAnmfEALw_wcB
Thomas73 is offline
