Highest MIPS - screenshots of 7-zip built-in benchmark - Page 2 - Overclock.net - An Overclocking Community
post #11 of 90 (permalink) Old 01-29-2018, 06:32 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Rep: 23 (Unique: 20)
Thanks, it is much better.
Utilization now is 3160%, as it should.
| OCN username | CPU                | Threads | CPU frequency OC | RAM frequency OC | RAM (CL) | Decompression MIPS |
| Jpmboy       | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 114481             |
| Tamalero     | Threadripper 1950X | 32      | 3.9GHz           | 3066MHz          | 16       | 99717              |
| gupsterg     | Threadripper 1950X | 32      | ?GHz             | 3200MHz          | 14       | 94081              |
| DStealth     | Core i7 8700K      | 12      | 5552MHz          | 4000MHz          | 16       | 49426              |
| Diablosbud   | Ryzen 5 1600       | 12      | 3.875 GHz        | 3200MHz          | 14       | 36784              |
| Sanmayce     | Core i5 7200U      | 4       | 2712MHz          | 2133MHz          | 15       | 9056               |
Get down get down get down get it on show love and give it up
What are you waiting on?
Sanmayce is online now
post #12 of 90 (permalink) Old 01-29-2018, 11:51 PM
Meddling user
gupsterg's Avatar
Rep: 786 (Unique: 360)
Sanmayce yes you have the info now on TR . I was at 3.95GHz, AIDA64 screenie shows this .
This is your thread/results gathering , so how you wish to do is your choice . I believe you are using the Current reading from Decompressing of Rating in MIPS. I can stop benchmark at differing time in a run to show an improved result for same settings. I think the Resulting fields are more representative of true performance for setup. See below screenies on same settings, without reposting, etc.
Name:	7-Zip 97665.jpg
Name:	7-Zip 99041.jpg
Name:	7-Zip 100067.jpg
gupsterg is offline
post #13 of 90 (permalink) Old 01-30-2018, 06:58 AM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
My bad, sometimes (too often recently) tunnel vision is my mode, stupid.
I don't feel that way, always open for new suggestions/layouts/approaches. Did choose Decompression MIPS as a mastermetric because of nearly full utilization of all the threads, not so with Compression, yet, the latter is even more important/indicative for power of one CPU-RAM subsystem. So, both are to be used in the future.
Yes, but if 'Current' is lower than 'Result' then the bigger enters the roster.
I would write to Igor to consider printing more stable stats, as:
- Initial (non-warmt) i.e. 1st pass stats;
- Average (all the runs summed and divided by their number);
- Top stats - the highest value of all runs.
The third one, to me, is absolutely a must-have.
However, the "legacy" is a heavy burden and my guess is no one will be gladdened to rehash all the gathered data, except me.
| gupsterg     | Threadripper 1950X | 32      | 3.95GHz          | 3200MHz          | 14       | 100067             |
Wanna address few more moments:
I always compare Decompression stats instead of Compression, the utilization of the former is nearly the number of threads x 100%, to draw conclusions it should be that way.
As Igor stated in his homepage, he tried to run more threads in 7-zip compression (than the actually available) in order to saturate the load.
So, compression stats are not that indicative! Yet, very important.
The screenshot with the 100067 MIPS is achieved at 3078% utilization (with 120/1772 Processes/Threads), room for betterment, on top of that in order to reach for highest output the benchmark should be run as:
- Administrator;
- In Realtime priority.
My point, we as users, still don't have a stable one-stop-shop reporter of [de]compression performance.
post #14 of 90 (permalink) Old 02-03-2018, 06:45 PM
Tamalero's Avatar
Rep: 6 (Unique: 5)
For testing purposes just tried the same bench a few times at 4Ghz.
I guess there isnt that much of a difference. I believe the RAM affects the scores a lot too.
https://www.overclock.net/forum/attac...=71825&thumb=1
Tamalero is offline
post #15 of 90 (permalink) Old 02-03-2018, 08:00 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Thanks, you are right, RAM settings matter a lot, yet, the huge discrepancy 113234KB/s (Core i9 7980XE) vs 60,145KB/s (Threadripper 1950X) still puzzles me.
| Tamalero     | Threadripper 1950X | 32      | 4.0GHz           | 3066MHz          | 16       | 100579             |
Also, the delta is too big: 96829 MIPS (at first run) versus 100579 MIPS (at 8th run). Those MIPS (million instructions per second) should be more stable. In essence, IPC is what mostly matters. Don't know why, but I cannot find any benchmark reporting IPC during heavy IMCs (Internal Memory ControllerS) loads, meaning bombardment of RAM with random 256bit reads (mostly uncached), hope 'Freaky Dreamer' package proves useful in tweaking 32-threaded CPUs with RAM various settings:
https://www.overclock.net/forum/21-be...l#post26663593
Regardless of different frequencies/steppings at which cores operate we need a stable mastermetric, namely, Instructions-Per-Clock.
post #16 of 90 (permalink) Old 02-05-2018, 11:59 AM
Rep: 43 (Unique: 39)
4.5 on chip, ram @ 4000, C16
DooRules is offline
post #17 of 90 (permalink) Old 02-05-2018, 02:21 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Nice, thank you DooRules, your machine rules, indeed!
The cute RED superpig (a popular Chinese mascot) has its ear pulled, reminds me of AMD's supercpu - lovely but thrashed.
| DooRules     | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 119726             |
However, comparing your Compression MIPS to Jpmboy's, it is second:
113234 KB/s (Core i9 7980XE)
109318 KB/s (Core i9 7980XE)
4MB/s
The access time to uncached RAM is roughly 2x smaller when compared to Threadripper, hence (AFAIU) the nearly 2x better Compression rates:
"Compression speed strongly depends from memory (RAM) latency, Data Cache size/speed and TLB. Out-of-Order execution feature of CPU is also important for that test."
Source: http://www.7-cpu.com/
My dissatisfaction from 7-zip fluctuations stands, your two machines cannot be "rated" in definite way. The whole point of [de]compression stats is to "catch" all those tweaks/settings of CPU-RAM subsystem - to see their affects, 7-zip is good but not enough.
post #18 of 90 (permalink) Old 02-06-2018, 03:56 PM
was playing around with something else @ 4,7, gave this a shot
DooRules is offline
post #19 of 90 (permalink) Old 02-06-2018, 04:10 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Many thanks, very interesting.
The first thing that caught my attention was the jump in AIDA's brutally fast L1 cache bandwidth getting even more brutal:
from 4972 GB/s (@4500MHz) to 5188 GB/s (@4700MHz)
The second thing was the nearly maximum utilization during your Decompression - 3588% - only 12% below the 36x100% limit! Such results I call MUTSI, that is, really indicative!
| DooRules     | Core i9 7980XE     | 36      | 4.7GHz           | 4000MHz          | 16       | 125571             |
Very glad that you shared these very informative shots.
post #20 of 90 (permalink) Old 05-08-2018, 11:04 AM
RealSteelH6's Avatar
Rep: 7 (Unique: 7)
Intel Core i5 8600[email protected]
G.Skill Trident Z RGB Kit 16GB DDR4-3200 CL14
MSI Z370M Mortar
RealSteelH6 is offline
