Highest MIPS - screenshots of 7-zip built-in benchmark - Page 3 - Overclock.net - An Overclocking Community
post #21 of 90 (permalink) Old 05-08-2018, 12:06 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Rep: 23 (Unique: 20)
Thank you RealSteelH6,
it's good to add this CPU-RAM configuration, I myself want to run similar build but with i3-8100 and 64GB.
| OCN username | CPU                | Threads | CPU frequency OC | RAM frequency OC | RAM (CL) | Decompression MIPS |
| DooRules     | Core i9 7980XE     | 36      | 4.7GHz           | 4000MHz          | 16       | 125571             |
| DooRules     | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 119726             |
| Jpmboy       | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 114481             |
| Tamalero     | Threadripper 1950X | 32      | 4.0GHz           | 3066MHz          | 16       | 100579             |
| gupsterg     | Threadripper 1950X | 32      | 3.95GHz          | 3200MHz          | 14       | 100067             |
| DStealth     | Core i7 8700K      | 12      | 5552MHz          | 4000MHz          | 16       | 49426              |
| RealSteelH6  | Core i5 8600K      | 6       | 4.6GHz           | 3200MHz          | 14       | 47152              |
| Diablosbud   | Ryzen 5 1600       | 12      | 3.875 GHz        | 3200MHz          | 14       | 36784              |
| Sanmayce     | Core i5 7200U      | 4       | 2712MHz          | 2133MHz          | 15       | 9056               |
It surprises me to see i5 8600K and i7 8700K so close in decompression.
Get down get down get down get it on show love and give it up
What are you waiting on?
Sanmayce is offline
post #22 of 90 (permalink) Old 05-08-2018, 12:16 PM
RealSteelH6's Avatar
Rep: 7 (Unique: 7)
I'm also surprised, it almost looks like that HT has zero benefits there and the score just is lower because of the slower clock speed.
RealSteelH6 is offline
post #23 of 90 (permalink) Old 05-08-2018, 12:33 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
As far as I understand those additional 6 threads should have delivered ... something, perhaps the 32MB dictionary is the reason, most of the RAM accesses are outside the LLC (last level cache) i.e. non-cached which stalls the process.
In the i7-8700K the memory usage is 2648MB whereas in your case 1324MB, maybe the 6 virtual threads are accessing RAM without cache help.
By the way, I wrote to Igor asking him to consider adding third value, namely, MAX of the runs, to no avail:
https://sourceforge.net/p/sevenzip/d...read/19d2b845/
Sanmayce is offline
post #24 of 90 (permalink) Old 05-08-2018, 12:41 PM
Iconoclast
Blameless's Avatar
Rep: 3149 (Unique: 1877)
The 8600K was benched with 18.05, which is way faster at decompression than 16.04. Everyone needs to be on the same version for the comparison to be relevant.
Number of threads also changes how memory is used because 7-Zip's bench is essentially spawning another test, using it's own dictionary allocation, with each thread.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #25 of 90 (permalink) Old 05-08-2018, 12:44 PM
DRAM Obsessor
CJMitsuki's Avatar
Rep: 12 (Unique: 10)
Here are my numbers but this is with an early segfault bugged R7 that is getting sent to AMD today so Im sure there were segfaults during the benchmark. Ill be installing my 2700x and submit that later tonight after the benchmark and of course dealing with my memory timings on the new CPU.
CPU- AMD Ryzen [email protected]
MOTHERBOARD- ROG Crosshair VIII Hero
GPU- EVGA GTX 1080ti SC2 @2075mhz
RAM- G.SKILL TridentZ 32gb (4 x 8gb) @ 3800mhz (14-15-15-22-36-1T)
COOLING- CORSAIR Hydro Series H115i Pro w/ Noctua NF-A14 (x7)
CASE- Lian Li O11 Dynamic
MONITORS- VIOTEK GN34DB (x2)
CJMitsuki is offline
post #26 of 90 (permalink) Old 05-08-2018, 12:45 PM
Iconoclast
Blameless's Avatar
Just ran the bench on my primary signature system with both 16.04 and 18.05 to illustrate the differential:
16.04
18.05
post #27 of 90 (permalink) Old 05-08-2018, 12:58 PM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Thank you CJMitsuki,
looking forward for your Ryzen 2700X results.
| DooRules     | Core i9 7980XE     | 36      | 4.7GHz           | 4000MHz          | 16       | 125571 (v.16.04)   |
| DooRules     | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 119726 (v.16.04)   |
| Jpmboy       | Core i9 7980XE     | 36      | 4.5GHz           | 4000MHz          | 16       | 114481 (v.16.04)   |
| Tamalero     | Threadripper 1950X | 32      | 4.0GHz           | 3066MHz          | 16       | 100579 (v.16.04)   |
| gupsterg     | Threadripper 1950X | 32      | 3.95GHz          | 3200MHz          | 14       | 100067 (v.16.04)   |
| Blameless    | Core i7 5820K      | 12      | 4.3GHz           | 2666MHz          | 12       | 51235 (v.18.05)    |
| DStealth     | Core i7 8700K      | 12      | 5552MHz          | 4000MHz          | 16       | 49426 (v.16.04)    |
| RealSteelH6  | Core i5 8600K      | 6       | 4.6GHz           | 3200MHz          | 14       | 47152 (v.18.05)    |
| Blameless    | Core i7 5820K      | 12      | 4.3GHz           | 2666MHz          | 12       | 38268 (v.16.04)    |
| Diablosbud   | Ryzen 5 1600       | 12      | 3.875 GHz        | 3200MHz          | 14       | 36784 (v.16.04)    |
| Sanmayce     | Core i5 7200U      | 4       | 2712MHz          | 2133MHz          | 15       | 9056 (v.16.04)     |
Many thanks Blameless, didn't notice neither the version difference nor that Igor did make major improvements, for so long the 7-zip decompression stayed the same.
Sanmayce is offline
post #28 of 90 (permalink) Old 05-08-2018, 03:41 PM
cssorkinman's Avatar
Rep: 499 (Unique: 279)
For what it's worth - daily clocks.
Ryzen Shine!
(15 items)
Ryzen 1800X @ 4125mhz 1.432 Volts
MSI X370 Titanium
Fury
Sapphire Nitro + 5700XT
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GTZ
Samsung 850 pro
Optical Drive
Hp 1260 I
PC power and cooling 910 watt silencer
liquid unobtanium Koolance 480mm radiator, 390 block - 3/4 OD tubing
Thermaltake P5
Operating System
Win 7 HP/Winspy 10 64bit
24" hp @ 1900x1200
Keyboard
Logitech G19
Mouse
Logitech MX 518
Mouse
fUnc industries
cssorkinman is offline
post #29 of 90 (permalink) Old 05-09-2018, 11:18 AM - Thread Starter
Integer Benchmarker
Sanmayce's Avatar
Thanks cssorkinman, a must-have your result is.
| cssorkinman  | Ryzen 7 1800X      | 16      | 4172 MHz         | 3200MHz          | 14       | 81761 (v.18.05)    |
Sanmayce is offline
post #30 of 90 (permalink) Old 05-09-2018, 05:25 PM
Iconoclast
Blameless's Avatar
4.41GHz Westmere with 7-zip 18.05:
