Freezer' Burn Overclocking Competition - Overclock.net - An Overclocking Community
post #1 of 549 (permalink) Old 03-25-2018, 03:24 PM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
Welcome to the first annual Freezer’ Burn overclocking competition. The goal of this competition is to have fun with overclocking and create a fair environment where we can compete against each other.
For this competition we chose to focus the on an older, readily available, and inexpensive GPU for the 3D portion. It was a difficult choice since there are many older generation graphics cards that fit this profile. In the end we chose to use the Nvidia GTX 260. Because hard modding is encouraged we think this is the perfect option since they can be purchased used for less than the price of a sit down dinner.
Here at Overclock.net most users will appreciate the potential of overclocking for gaming and other productivity applications. The other side to overclocking is to push the hardware to the limits and find out what it's capable of...for no other reason than fun. In this competition we will be using old used hardware for the 3D portion. The hardware is intended to be extremely inexpensive so you can experiment and overclock it without worrying about damaging your daily rig.
Competition by itself is fun, but lets face it, it’s more interesting when there are awesome prizes to win! I am extremely happy to report that this competition is vendor supported with over $2400 of prizes with no less than 20 WINNERS!!
Competition Duration: See attachment at bottom
This competition was designed with the goal that everyone can participate and be competitive. Whether you are an experienced subzero overclocker or just starting and this is all new, you can learn and participate in a fair and even environment.
You will only be allowed to participate in one category, but you an change categories at any time. There will be 4 benchmarks in each category but only your top 3 will be scored. We encourage you to participate in all 4 stages. However, we wanted to add the option of dropping one score in case you have difficulties getting a score or there are other problems. It’s in your best interest to submit to all 4 stages. The benchmarks for this competition are as follows:
  • Processor is limited to 4 physical cores with 8 threads max
  • Processor cores cannot be disabled to artificially emulate a 4 core CPU
  • Processor is limited to 5003Mhz maximum frequency
  • The processor and graphics card cannot fall below 20 degrees C
  • The CPU is limited to 4 physical cores, 8 threads max
  • There are no cooling or frequency limits, all forms of cooling accepted. Popular ones include: Chilled Water, Phase Change, Dry Ice, Liquid Nitrogen
For each benchmark you wish to compete in, you will be required to submit a screenshot and a picture of the computer running the benchmark. Only screenshots with the valid competition wallpaper will be accepted.
Official Competition Wallpaper: OCN Freezer' Burn Wallpaper.zip
HWBOT x265 Benchmark 4k
  1. Benchmark download: LINK
  2. Required Version: 2.1.0 or Newer
  3. Hwbot rules apply: LINK
  4. Required for screenshot: Benchmark window, CPUz Tabs (CPU, Memory, MB)
  5. No GPU restriction
Geekbench 4 - Single Thread
  2. Required Version: 4.2.2 or Newer
  4. Required for screenshot: Benchmark window, Benchmark result window, CPUz Tabs (CPU, Memory, MB)
  6. Note: Due to some bugged runs observed, it is best to save a validation URL for your submission. Any suspect top submission that does not have a validation URL may be disqualified.
3DMark03
  2. Free Public Key: N4LWE-T6HUX-8U4JB-28YLV
  4. Required for screenshot: Benchmark window, benchmark score window, Benchmark subdetails window, CPUz Tabs (CPU, Memory, MB), GPUz
  5. Systeminfo required Ex: Entering -nosysteminfo in the target line is not allowed
  6. Special Note: The game test results need to show descending order of score. Example: If GT3 is higher than GT2, the entire result will be considered bugged and rejected.
GPUPI - 1B
  2. Version: 3.3 Legacy and newer (3.2 Legacy also accepted)
  3. Hwbot rules apply:LINK
  4. Note: For best compatibility use a modern OS like W8.1 and the latest graphics driver
  5. Note: For best compatibility use the smallest batch and reduction size (1M/64)
  6. General Info Thread: LINK
  7. Run benchmark in CUDA mode
  8. Required for screenshot: Benchmark window, CPUz Tabs (CPU, Memory, MB), GPUz
  9. HWiNFO can be disabled but recommended "Full Detection"
  10. Compatibility issues: Try installing CUDA 9 standalone (Credit Mr. Scott) LINK
  11. GPUPI Screenshots and Settings used
    Spoiler!
  1. Benchmark rules outlined above apply
  2. The CPU is limited to 4 core / 8 thread (Any generation, ES allowed)
  3. Processor cores cannot be disabled to artificially emulate a 4 core CPU
  4. The CPU frequency is limited to 5003Mhz
  5. The GPU is limited to Nvidia GTX 260 (both 192 and 216 shader model acceptable)
  6. Any component of your system must not fall below 20 degrees C
  7. Hwmonitor software will be required for all screenshots
  8. We require that you keep hwmonitor software open during the bench and that we clearly see the expected rise and fall of system component temps
  9. You are required to show temps for CPU and GPU (when applicable)
  4. No CPU frequency limit
Other than the benchmark software, you will be required to show your system information for the screenshot. There are many tools you may wish to use, but here are the required ones:
CPUz (System Monitoring Software)
Required Version: 1.78 or Newer LINK
HWMonitor (Thermal Monitoring Software - Ambient Section Only)
Required Version: 1.30 or Newer LINK
GPUz (Graphics Card Monitoring Software)
Required Version: 1.1.0 or Newer LINK
Note: As of right now, embedding a spreadsheet is currently not working with the recent OCN transition vbulletin. Due to this inconvenience, scores will be updated once every week and we will post an image of the score spreadsheet instead of embedding the live spreadsheet. The OCN management staff is working on a solution but it's not likely to change during the duration of the competition.
The scoring is straightforward. You will be awarded points for your position and the points are tallied to make a combined total score. Please note, only your top three submissions, from the possible 4 submissions, will be totaled.
Tiebreaker In the event that there is a tie in the total score, the winner will be the user with the fastest GPUPI time.
Final Results (Tentative)
Simply put, we want as many people to participate and have fun as possible. Normally in competitions like this, the top winners are the only people who receive the prizes. We wanted to make sure many people had a chance of winning something so for this competition we will have 14 lucky draw prizes. At the end of the competition, we will host a raffle for all the participants (other than the ambient/extreme top 3 winners).
To be eligible for a lucky draw prize all you need to do is make one legal submission to any of the 4 stages. Even if you only managed to run Geekbench 4 for instance, we want you to be eligible for the lucky draw prizes too.
Please take a minute and thank the sponsors by simply going to their website. This seems like a small and meaningless thing, but it makes a big difference.
OCN Freezer' Burn Event Sponsors
  1. First Place: $600 USD Shopping spree at Alphacool.com LINK
  2. Second Place: Eisbaer 280 CPU Water Cooler [$130 Value] LINK
  3. Third Place: Enermax RevoBron 700W PSU [$97 Value] LINK
  • Eisbaer 280 CPU Water Cooler [$130 Value] LINK
  • Enermax T.B.RGB Fan 3-Pack [$60 Value] LINK
  • Innovation Cooling Thermal Kit [$40 Value]
This kit consists of three products, two of which are effectively being launched at the start of this competition. The kit includes:
  • IC Diamond 24 Carat LINK
  • IC Graphite Thermal Pad LINK
  • IC Contact Test & Analysis Kit LINK
Thanks for reading and I hope you get involved! Everyone has a chance to win something, so even if you can only submit one score, its worth it just to be involved and get entered into the lucky draw prizes. On a personal level, I will definitely participate and make submissions. However, due to the fact that I and working with all the vendor sponsors, it would be a conflict of interest for me to win any prizes.
Have fun and keep it clean! I wish everyone the best of luck!!
Special thanks: @mus1mus For the artwork
Special thanks: @Noxinite For helping moderate
Special thanks: @DR4G00N For helping moderate
24/7 BENCH
(9 items)
[LGA115x] 8700k, 7700K, 7350k, G3258
[LGA2066] 7940X, 7740X
[OCF FTW] X299 OCF, Z170M OCF, Z97 OCF
E-Power, G-Power, H-Power, A-Power
B-DIE, HYKO, PSC, MFR
Seasonic Prime Platinum 1200W
Kingpin Cooling: Venom & T-REX
2x360 RAD Custom Loop
Dimastech Easy V3.0
mllrkllr88 is offline
post #2 of 549 (permalink) Old 03-25-2018, 03:25 PM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
Graphics Card Overclock Info
Overclocking Software and Voltage
I expect if you are here then you are familiar with common overclocking software such as MSI Afterburner or EVGA Precision. Those common programs allow you to increase the graphics clocks and if you enable some options in the settings, most of the times you can increase the graphics voltage too. The publicly available software will have limitations and it’s entirely possible, with the right software, that you can increase your graphics card voltage beyond the normal range with software. Below is a list of some software that might allow more voltage for your card.
Afterburner Extreme: I cannot post the link because the copyright is reserved by Guru3D.com.
Here is a article talking about the piece of software you are looking for: LINK
Note: This software requires an old system date or it will not open (I usually change the bios date to 2010). The unlocked voltage will need to be enabled in the settings, perhaps kernel mode. This is likely to only work on one style of reference card, but it might be worth trying on your card if you are not going to do hard mods
Physical GPU Mods
If you are new to mods I have created a thread that will help you. Even if you have some experience but you need a refresh, its worth a read-through. The thread can be seen here: LINK
Reference Style A: On-Semi NCP5388 Based
Reference Style B: On-Semi ADP4100 Based
Reference Style C: Volterra Based
**Check back soon**
Non-Reference Style: Asus
**Check back soon**
User Submitted Voltage-Mods
  • Nvidia Ver. P897 PCB: LINK
  • GALAXY GTX 260: LINK
  • NCP5388 VID Mod (Defeat early OVP): LINK
  • Various 260 mods LINK
24/7 BENCH
(9 items)
Dimastech Easy V3.0
post #3 of 549 (permalink) Old 03-25-2018, 03:27 PM
In VB's Basement
ENTERPRISE's Avatar
Have at it guys
Need help with your account or something forum related ? Please use our Contact Us form
ENTERPRISE is offline
post #4 of 549 (permalink) Old 03-25-2018, 03:38 PM
LN2 addict
bigblock990's Avatar
Rep: 70
IN!!!!!
Huge THANKS to the sponsors, the prize pool is amazing
Thread looks great mllrkllr88, awesome work putting this together.
bigblock990 is offline
post #5 of 549 (permalink) Old 03-25-2018, 03:39 PM
Chief Engineer
Mr.Scott's Avatar
Rep: 75
Very nice.
Loved by thousands, hated by millions.
Mr.Scott is offline
post #6 of 549 (permalink) Old 03-25-2018, 03:40 PM
sunset1's Avatar
Rep: 48
DaYm that is Strong heck of a comp guys. Nice one!!!!
"intelligence is the ability to question the status-quo."
sunset1 is offline
post #7 of 549 (permalink) Old 03-25-2018, 03:52 PM
kimandsally's Avatar
Rep: 3
Wow fantastic work here Millrkllr88 great competition and great prizes, I can't imagine how much work went into making this for us all, and on top of that modding cards and helping others mod their own cards ( like me ) and to @mus1mus I can't thank you enough.
One thing for sure if you want a job doing well MillrKllr88 is the man.
kimandsally is offline
post #8 of 549 (permalink) Old 03-25-2018, 03:58 PM - Thread Starter
External VRM FTW
mllrkllr88's Avatar
It's time to dust of that GTX260 that has been sitting in your closet or find one on ebay, they are very inexpensive LINK
24/7 BENCH
(9 items)
Dimastech Easy V3.0
post #9 of 549 (permalink) Old 03-25-2018, 04:05 PM
Overclocker
macsbeach98's Avatar
Rep: 96
Wow fantastic Comp and great prizes excellent job mllrKllr I cant wait.
macsbeach98 is offline
post #10 of 549 (permalink) Old 03-25-2018, 05:12 PM
OC...D
Jpmboy's Avatar
Rep: 1235
Great job! Should be lots 'o fun!
ASUS Z370/Z390 Motherboard Support Thread, Coffee Lake OC Guide
Rampage VI Apex / 7980XE / 2 Titan V / 32GB 4000C16/Corsair AX1500i/Intel 900P
For Sale
X299
(25 items)
x99
(18 items)
Z370 Z390
(23 items)
7980XE
7740X
7740X
ASUS Rampage VI Apex
Gigabyte Aorus G9
Gigabyte x299 Gaming
2x Nvidia Titan V
GTX 1080
G. Skill 2x(2x8GB) 3600c15 @4000c16
Team Group
INtel Optane 900P
2x256 Plextor Raid 0
WD Raptor
Samsung Sm 961
Corsair AX1500i
EVGA 850 G3
Corsair HX1200i
Aquacomputer GiGant 1680 (4x420)
Koolance EXC-800
Microcool Banchetto 101 (Alu)
Operating System
Win 10 Pro
Operating System
Win 7 Pro
ROG Swift
Keyboard
Ducky
Mouse
Spatha
6950X
ASUS Rampage V Extreme-10
Titan Xp
Titan Xp
G Skill 8x8GB 3200c14 @3400c13
Samsung 960 Pro
Optical Drive
ASUS BR/DVD/CD
Corsair AX1500i
2x360 Aq Copper Rads
Aquaero 6
Koolance ERM-3K3U (9-fan mora)
Ek Full Cover MB waterblock
CaseLabs Mercury S8
Operating System
Win 10 Pro
Operating System
Win 7 Pro
AGON 32 inch
Keyboard
Das Pro
Mouse
Logitech G700
8700K
9700K
8086K
ASUS Maximus X Apex
ASUS Maximus XI Extreme
GTX 1080
GTX 1070Ti FTW2
Titan V
2x8 GB G.Skill 4400c19
G.Skill 3600c16 4x6GB
Intel 750
Optical Drive
PLextor DVD/CD
Corsair AX1500i
Corsair HX 1200i
Seasonic Titanium 850W
360Rad + Chiller
Koolance ERM-3K3U
Corasir 570
Operating System
Win 10
Operating System
Windows 7 Pro
55" 4K
Keyboard
HyperX Alloy FPS Pro
Mouse
SteelSeries Rival
Jpmboy is offline
