Achieva Shimian Monitor Club - Page 349 - Overclock.net - An Overclocking Community
post #3481 of 3519 (permalink) Old 03-12-2016, 02:56 PM
Ragsters's Avatar
Rep: 218 (Unique: 203)
I just found this laying around in my house. Will this work with a video card that does not have dvi-d card like a R9 nano?
http://www.amazon.com/gp/product/B00IA4JJ9G
Tiny Dancer
(19 items)
Son's Build
(16 items)
White Noise (R.I.P)
(31 items)
i7 6800k
Asrock X99e-itx
RX Vega 56
Corsair Vengence LPX
SAMSUNG 960 EVO M.2 500GB NVMe
Corsair SF600w
Corsair H75
NF-F12 industrialPPC-2000 PWM
Ncase M1 V5 (Silver)
Operating System
Windows 10
BenQ 32" IPS 4K (BL3201PH)
Keyboard
Vortex Poker 3 (White with White LED)
Mouse
Logitech G102 Prodigy (Matte White)
Mouse
Glorious PC Gaming Race XXL Extended
Audio
Soundblaster Omni 5.1
Audio
Sennheiser HD 598
Audio
kanto Yu2 Desktop Speakers (Gloss White)
Audio
Kanto Sub 6 (Gloss White)
AMD Phenom II X6 1055T
Gigabyte 880GMA-UD2H
Asus GTX 660 Ti
Corsair Vengeance Pro
PNY SSD CS1311
Samsung SSD 830
Samsung Spinpoit F3
Antec Neo Eco 520C
Corsair H50
Silverstone FT03B
Operating System
Windows 7 Home Premium 64bit
Samsung SyncMaster 220wm
Keyboard
Coolermaster Quickfire Rapid
Mouse
Steelseries QcK
Mouse
Zowie Mico
Audio
Logitech LS21 2.1 Stereo Speakers
i7-3770K
Asus Maximus V Formula
VisionTek Reference 7970
Diamond Reference 7970
Corsair Dominator-GT 16GB (4x4GB)
SanDisk Extreme Pro
Western Digital Black 640GB
Seasonic X650 (Custom MDPC Sleeve)
Swiftech MCP35X DDC Pump - White Top
XSPC AX360 Triple 120mm Radiator - White
EK-Supremacy Clean CSQ - Nickel Plexi
Bitspower Silver Shining Fittings
7 x Scythe Gentle Typhoons D1225C12B4AP-15
Bitspower Acrylic DDC Pump Top
Bitspower DDC Top Upgrade Kit
Bitspower DDC / MCP35x Pump Heatsink - White (BP-DDCPC-WH)
2 X EK-FC7970 Nickel CSQ GPU Block
2 X EK-FC7970 Backplate - Black CSQ
EK-FB KIT ASUS M5F Nickel Motherboard Block
XSPC AX480 Quad 120mm Radiator - White
EK-Ram Monarch X4 CSQ - (EN) Nickel Plexi
CaseLabs Merlin SM8 (All White)
Operating System
Windows 7 64bit Home Premium Upgrade
Achieva Shimian Lite "Perfect Pixels"
Keyboard
Das Keyboard Model S Professional
Mouse
Mionix Avior 7000
Mouse
SteelSeries QCK Mini
Audio
Klipsch Pro Media 2.1
Audio
Sennheiser 598
Audio
Creative Soundblaster Z
Other
NZXT LED Kit - 2 Meter - White (CB-LED20-WH)
Ragsters is offline
post #3482 of 3519 (permalink) Old 03-14-2016, 06:04 AM
Rep: 1 (Unique: 1)
This screen has been serving me well for the most part since 2012. In the last year though, I have to wiggle the DVI cable at the monitor end to get it to "handshake" and get a signal from the PC, ONLY off a cold start i.e. first thing in the morning.
Swapped out the cables and it made no difference. Thoughts anyone?
vroom34 is offline
post #3483 of 3519 (permalink) Old 04-28-2016, 07:21 AM
Recr3ational's Avatar
Rep: 43 (Unique: 32)
Does anyone know the size of screw the Shmian uses? The screw hole is extremely short which worries me a little bit. Thanks
Recr3ational is offline
post #3484 of 3519 (permalink) Old 04-28-2016, 11:55 AM
joeh1974's Avatar
Rep: 1 (Unique: 1)
I believe I used M4 screws to attach it to my 3M monitor stand:
http://www.amazon.com/3M-Easy-Adjust-Monitor-Stand-MS110MB/dp/B0013CD0DI/ref=sr_1_3?ie=UTF8&qid=1461869639&sr=8-3&keywords=3M+monitor+stand
I forget the exact length, but I do have a bit of the screw still protruding outside of the backplate. It still fits snugly, and I've had no issues with either monitor stand functioning as expected.
joeh1974 is offline
post #3485 of 3519 (permalink) Old 06-01-2016, 07:30 PM
Derpinheimer's Avatar
Rep: 34 (Unique: 33)
Hi guys,
I have a weird problem that seems to be developing on this monitor. Had it for over 3 years now and it has vertical lines of moving pixels. I tried my best to get it on video but it was hard, and the youtube compression seems to have murdered it.
https://drive.google.com/file/d/0BxXDcqW2MuZfWW1kdmRvNmtvWE0/view
Heres a screengrab to hopefully make it clearer what I'm trying to point out
Any thoughts? Is the monitor dying?
I can try to get a better video or picture if desired
Derpinheimer is offline
post #3486 of 3519 (permalink) Old 06-20-2016, 11:44 AM
Retired Staff
cam51037's Avatar
Rep: 162 (Unique: 105)
I'm having an issue with my Shimian 1440p monitor, wondering if anyone has experienced this before?
Basically, when I turn on the monitor, the light in the bottom right corner of the monitor turns from red to blue, as it should, and then the backlight comes on. Even though the monitor is plugged into my computer, no video is displayed. I've been able to temporarily fix the problem by unplugging the DVI cable from the computer and plug it back in - after trying this a few dozen times eventually the monitor begins to display again. It seems that once the monitor is outputting video it has no issues until I turn the monitor off again. Then I have to unplug and plug the DVI cable back in a few dozen times to have any video display.
Some things I've tried:
  • Using a different DVI cable - no effect
  • Using the current DVI cable with a different monitor - no issues
  • Checking monitor power and video connections to ensure they're solid and that they aren't dusty
I did some reading and wasn't able to find anybody with this issue on a Shimian monitor, but I found a thread where it was happening to somebody with another Asian 1440p display. It sounded like the problem was a dislodged ribbon cable in the monitor itself, but I just want to see if anyone in the OCN community has experienced this before I start tearing this monitor apart. Also, the monitor is out of warranty (just my luck :rolleyes:).
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/f/18042/distributed-computing-general"><span style="font-size: 12px;"><strong><em>CHECK OUT THE DISTRIBUTED COMPUTING SECTION FOR ALL THE INFO ON BITCOIN AS WELL AS OTHER CRYPTOCURRENCIES! </em></strong></span></a></div><span></span><p style="text-align:center;"><span> </span></p><span></span><p style="text-align:center;"><span style="font-size:12px;"><a href="https://pgp.mit.edu/pks/lookup?op=get&amp;search=0xEFFBC2817A4C2195" target="_blank">My PGP Key (KEY ID: 7A4C2195)</a></span></p></div></div>
cam51037 is offline
post #3487 of 3519 (permalink) Old 07-08-2016, 05:14 PM
Fuzoos's Avatar
Rep: 0
Originally Posted by Derpinheimer View Post
Hi guys,
I have the same issue. The vertical lines are in groups of 4 lines with a large space between groups. I can hardly see them unless the background is dark. I'd love to know what is going on as I purchased 2 monitors and the issue appeared to happen to both monitors at the same time. Makes me think that there was some kind of voltage surge that happened affecting both monitors - they're plugged into the same outlet. I also tried different DVI cables.
I was thinking about getting new PCB boards for the monitors, but for $150 more apiece I could just get new monitors.
Fuzoos is offline
post #3488 of 3519 (permalink) Old 07-08-2016, 05:36 PM
Fuzoos's Avatar
Rep: 0
Originally Posted by roberts6910 View Post
I wanted to give you all a heads up for replacement PCBs in case any of you have a dead or dying panel (like I had!) Just found a seller on the site below - here is my short review of what I received.
PCBs came in today - exactly what I needed. These are the ones that OC perfectly.
I had ordered two sets to get my Korean panels back up and running (and to overclock them). One got to 115hz before the panel freaked out the other to 120hz no problem (I have them both at 110hz). I did get coil whine on one set even with the bits covered as suggested. Not a big deal for me since I usually am gaming or have some background music playing while on the PC - the whine is most evident on pages with a lot of white.
I also got a 10% discount for ordering 2 sets - they told me all multi sets always get this discount. Not too shabby. $75 shipped per set (before the discount).
If you need PCBs for your LG panel, or want to OC your current one, I can say this is a solid product and seller.
Now I am set for my Evga 1080 that comes in sometime today!!! So stoked thumb.gifthumb.gif
CLICK HERE FOR THE PCBs
What was the display model are you using this on? Shimian QH270?
Fuzoos is offline
post #3489 of 3519 (permalink) Old 07-08-2016, 11:07 PM
roberts6910's Avatar
I don't remember. I have the panels debezzled with the metal surrounds painted black. Then I JB welded monitor mounts (and the PCB mounts) to the back and have a nearly seamless setup. One is out of a Catleap and one was from a Yamakasi monitor if I remember correctly - I bought them in 2013. I have a third panel that I need to buy a set for, but again no idea where that came from - I tossed the plastic nearly two years ago.
All of these panels are some model of the the LG LM270WQ1 panels if that helps.
roberts6910 is offline
post #3490 of 3519 (permalink) Old 07-09-2016, 12:46 AM
Fuzoos's Avatar
Rep: 0
Thanks for the info. I was actually looking online for PCB boards earlier and they were hard to find.
Looking at the pictures, I think my monitor - the Shimian QH270 - has the smaller TCON connections. Comparing the image on the site and this video they seem to be smaller https://youtu.be/By7hrUXJCPk?t=3m5s
I think I'm going to end up buying some new monitors and keeping my Shimian's as extra "non-main" monitors.
Fuzoos is offline
