Nixeus Vue 27" H-IPS 2560x1440 LED Monitor (NX-VUE27) **USA BRAND** - Overclock.net - An Overclocking Community
post #1 of 225 (permalink) Old 07-26-2012, 01:02 AM - Thread Starter
speedyeggtart's Avatar
Rep: 35 (Unique: 30)
It has a height adjustable stand:
It can pivot into portait viewing mode:
Multiple Inputs: HDMI 1.4, Display Port 1.2, Dual Link DVI-D, and VGA 15-Pin (D-SUB)
AnandTech's NX-VUE27 Announcement:
http://www.anandtech.com/show/6131/nixeus-vue-27-a-430-wqhd-2560x1440-sips-led-monitor
MSRP is $499
Main Features:
* 27" H-IPS LED Backlight Display Monitor
* 2560 x 1440p WQHD
* 16.7 million True Colors
* 102% sRGB Color Gamut
* VESA Mounts 3.937" x 3.937" (100mm x 100mm)
* HDCP Support
* Height Adjustable Base Stand with swivel, 15° Tilt and 90° Pivot
* On Screen Display for Monitor Calibration
* A Grade H-IPS Display Panel (Better than A- Grade that some of the Korean models use) thumb.gif
* Glossy Display Panel
* 1 Year Limited Warranty
Specifications:
Warning: Spoiler! (Click to show)
Screen Size
* 27 inches
Maximum Resolution
* 2560 x 1440p WQHD
Backlit
* LED
Aspect Ratio
* 16:9
Color Support
* 16.7 Million True Colors
Brightness
* 380 cd/m2
Native Contrast Ratio
* 1500:1 (100,000:1 Dynamic Contrast Ratio)
Viewing Angles
* 178° horizontal/178° vertical
Refresh Rate
* 60Hz
Response Time
* 6ms (Gray to Gray)
Pixel Pitch
* 0.233mm
Speakers
* Stereo Speakers
Input Ports
* Dual Link DVI-D, Display Port 1.2, HDMI 1.4, VGA 15-pin (D-SUB)
Audio Port
* 3.5mm Audio Jack
Operating Systems Supported
* Linux, Windows, MAC OS
Languages
* English, Chinese, German, French, Italian, Spanish, Korean
Power Consumption
* 72 watts
Accessories
* Dual Link DVI-D Cable
* User Manual
* 3.5mm Audio Cable
* Power Supply
*Information and Pics taken from Nixeus forums.
I e-mailed Nixeus and they replied telling me their monitors are using higher A Grade IPS display panels (Not A - Grade panels)
*12-1-2012: Updated with correct information for LG Panel Type and pricing*
USER UNBOXING YOUTUBE VIDEOS:
LinusTechTips Unboxing:
http://www.youtube.com/watch?v=lYu9VWu67qw
Tinkertry Unboxing:
http://www.youtube.com/watch?v=Kvm-J207IQM
USER SETUP YOUTUBE VIDEOS:
User setup with MacBook Pro
http://www.youtube.com/watch?v=yxWMGlWOryQ
User triple monitor setup with laptop
http://www.youtube.com/watch?v=ix1nwFc9sUw
Available in USA:
At Amazon (With an average 4.5 Star Review!):
http://www.amazon.com/gp/product/B008M08SN6/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1P1CGPJH7C041QZ4FZS6&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
At Comp-u-plus:
http://www.compuplus.com/Monitor/Nixeus-Vue-WQHD-27inch-S-1218348.html
At NCIX USA:
http://us.ncix.com/products/?sku=80441&vpn=NX%2DVUE27&manufacture=Nixeus
Available in Canada:
At NCIX Canada:
http://www.ncix.ca/products/?sku=80441&vpn=NX%2DVUE27&manufacture=Nixeus&promoid=1382
speedyeggtart is offline
post #2 of 225 (permalink) Old 07-26-2012, 01:03 AM - Thread Starter
USER Reviews:
speedyeggtart:
Nixeus didn't ship out my monitor yet, so I was able to pick it up from their office!
The monitor box:
NOTE: The box is HEAVY - heavy enough that the box's plastic handles broke while I was carrying the monitor to my car. Good thing I'm short so the drop was minimal. So be sure to carry it by holding the sides or carrying from the bottom.
Opening the box and taking out the contents, I found out the stand and stand base made up the bulk of the box's weight.
The directions for installing the stand was not informative enough, but at least the screws are labeled so you know where they go:
I'm using a display port 1.2 cable to connect the monitor to my Gigabyte Windforce GTX 670...
Running some tests - I did not find any dead or defective pixels and there was no back light bleeding... at least I couldn't find any:.
Adjusting the height was fairly easy, but tilting it was kind of hard (at least it feels solid). I found out to swivel left or right that you had to hold on to the monitor shaft and twist left or right.
Rotating it clockwise into portrait mode was fairly easy:
Playing Battlefield 3 in 2560x1440p I didn't notice any input lag and it did not affect my reaction time or gaming scores (K/D Ratio) - anyone that has played with me knows that I don't camp and I don't nade/noob tube spam! I always play FPS games with V-Sync OFF. As you can see, I play BF3 ALOT! (Feel free to add me on Battlelog):
I'm happy that I waited for the Nixeus Vue. It is definately worth upgrading from my i-INC 27" 1920x1200 Monitor...I would get another one but I would need to upgrade my desk first! cheers.gif
Battlefield 3 Gaming Performance @ 2560x1440p with a Gigabyte Windforce GTX 670 OC thumb.gif
I ran some benchmarks to see how my PC rig performed with the Nixeus Vue 27's 2560x1440p Resolution:
Here are my Resolution Settings on a full server for a 64 Player Operation Firestorm
I ran FRAPS 8 times while I was flying the jet - dog fighting and shooting at ground units (Yes I'm a decent jet pilot). I fly close to the ground and try to keep the same runs. These frames per second was replicated and consistent during my benchmark runs.
At 2560x1440p, Battlefield 3 really puts the GTX 670 to work as you can see the numbers on MSI Afterburner... BF3 chews up about 1.8GB worth of GPU Memory! If you are planning to purchase a 2560x1440 IPS monitor, you are definitely going to need a Graphics Card with at least 2GB of Memory!
post #3 of 225 (permalink) Old 07-26-2012, 01:22 AM
JanqeD's Avatar
Rep: 11 (Unique: 11)
If it can compete with the Korean IPS monitors then Ill buy this instead but I have a feeling it wont be able to be shipping that the other companies offer. Fingers crossed though GO USA :Dlol
JanqeD is offline
post #4 of 225 (permalink) Old 07-26-2012, 01:27 AM
Rep: 10 (Unique: 9)
Where did you find this Info at ? Google is blank
wkstar is offline
post #5 of 225 (permalink) Old 07-26-2012, 01:34 AM - Thread Starter
I'm crossing my fingers too... I've been borrowing my friend's IPS monitor and he's comng back from a long summer vacation and I have to give it back soon... mad.gif
post #6 of 225 (permalink) Old 07-26-2012, 01:37 AM - Thread Starter
From their forums - my brother told me about it knowing I've been researching and looking for an IPS WQHD display... they usually let their existing customers know about new products first...
post #7 of 225 (permalink) Old 07-26-2012, 01:42 AM
DaClownie's Avatar
Rep: 286 (Unique: 244)
Replying right now to sub... if the price is in line with the Korean monitors (a bit more is fine if it has warranty) I'll purchase.
R.I.P. Syrillian - August 13, 2011
Amazing during your time here on earth, but your calling in heaven must be extraordinary.
About drbaltazar's translated posts:
i like the!new GPU from AMD!this discovery( could mean !alot ! i like grapes!
DaClownie is offline
post #8 of 225 (permalink) Old 07-26-2012, 01:42 AM
Skoobs's Avatar
Rep: 95 (Unique: 88)
imb4 FOTM even though that thing is ugly as heck
SoCal Member
Steam: xSKOOBSx
Origin: xSKOOBSx
Skoobs is offline
post #9 of 225 (permalink) Old 07-26-2012, 01:48 AM - Thread Starter
My brother owns one of their products... he tells me their warranty service and customer service is really good from his experience...
post #10 of 225 (permalink) Old 07-26-2012, 10:07 AM
Rayyeter's Avatar
Rep: 2 (Unique: 2)
Also subbing to see what the price is next week.
Rayyeter is offline
