ASUS PB278Q 1440P MONITOR "DISPLAY-PORT: NO SIGNAL, AND HDMI: NO SIGNAL" GTX 780 - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 01-27-2015, 09:53 AM
Willfoxylove's Avatar
Rep: 0
Still not working.
Willfoxylove is offline
post #12 of 16 (permalink) Old 01-27-2015, 10:38 AM - Thread Starter
SteezyTN's Avatar
Rep: 64 (Unique: 54)
Originally Posted by Willfoxylove View Post
I'm having this same issue and I just bought the monitor last week. What's the best solution?
Did you not read my solution? The monitor has to be on first before the PC is on.
SteezyTN is offline
post #13 of 16 (permalink) Old 01-27-2015, 02:11 PM
Rep: 0
Tried that, doesn't work. I wouldn't have posted otherwise.
post #14 of 16 (permalink) Old 01-27-2015, 04:13 PM - Thread Starter
SteezyTN's Avatar
Then it's obviously a problem with your GPU, or cable connection
SteezyTN is offline
post #15 of 16 (permalink) Old 07-19-2015, 02:19 PM
ricobanderas's Avatar
Rep: 0
Just want to chime in on this issue that just happened to me in case it helps someone having trouble with signals to ASUS monitors. I'm using 64-bit windows 8.1.
I run a dual monitor setup through a EVGA GTX970, DisplayPort going to ASUS VG248 and HDMI going to ASUS VE248. Last night I turned off the monitors and let the computer go to sleep automatically after a couple hours. Today upon turning the monitors on, my main monitor (the VG using DP) had no signal. Using HDMI to this monitor worked fine, so I figured it was some driver or firmware conflict. I went through a bunch of stuff, including calling EVGA and flash installing some displayport drivers for the BIOS. This appeared to have no effect. After restart and a driver reinstall, still no signal through DisplayPort.
I don't know what compelled me to do this, but just while in Windows I switched the Power plugs of the monitors. Voila - both monitors working. Notably, my VE was going direct into the wall, while the VG was going into a strip with other electronics. Swapping these fixed it. I really did not expect it to be a monitor and power source issue. I'm also not entirely sure what effect the displayport drivers had. Anyway, FWIW, YMMV....
ricobanderas is offline
post #16 of 16 (permalink) Old 02-26-2019, 02:18 AM
Rep: 0
My Asus started working with Macbook 2016
@Willfoxylove I'm pretty sure this won't help you anymore since it's been 4 years...hehe Anyway, I thought I hopefully can help someone else with a mac. I read about Windows users changing stuff related to powering saving so I tried going into System Pref -> Energy Saver and unticking "Automatic graphics switching" on my Macbook 2016 and suddenly my Asus PB278Q lit up. Thanks everyone for ideas!
ripern is offline
