AMH A399U 4K monitor - Page 7 - Overclock.net - An Overclocking Community
post #61 of 311 (permalink) Old 05-26-2015, 06:07 AM
EniGma1987's Avatar
Rep: 338 (Unique: 248)
Originally Posted by King4x4 View Post
Monitor arrived.
Post the tests that you want
VA panel? Seems to be a VA Panel not an IPS.
Could you please take a picture of the monitor at a 45 degree angle from head on, so the camera is pointing more towards the side of the monitor. That will show us how much IPS glow from off angle viewing we get. Or if there is not glow, would lend more credence to the panel being a VA type. I suspect it could be a VA type too though because of the Philips panel that everyone is using right now in this same size, but that panel is supposed to have a 5000:1 ratio and this lists 3000:1 which is closer to high grade IPS contrast normally is, or towards a low grade MVA typical contrast. Hmm...
EniGma1987 is offline
post #62 of 311 (permalink) Old 05-26-2015, 07:07 AM
mars2k's Avatar
Rep: 1 (Unique: 1)
Keeping.
Trying to sell my Benq BL3201 locally at not big of a loss.
Those who have 290x beware. You need to change the DP cable that comes with the monitor and it needs to be less than 3m. Had issues with mine developing with flickering until I changed the cable again.
Had issues with a mini DP to DP cable. No clear stands on DP cable or cable makers don't always follow. Need to get a certified DP cable. DP group has a list of cert'd caqbles. I found this http://www.amazon.com/gp/product/B00A7R9I22/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 to be the onlyu cert'd cable for mini DP to DP. This fixed an issue I had with a 4K monitor connected to my 290X2.
mars2k is offline
post #63 of 311 (permalink) Old 05-27-2015, 03:12 AM
bobbavet's Avatar
Rep: 18 (Unique: 16)
Yeh I agree with this. My 120Hz 1080p would always play up until I sourced one of the Accell cables.
From memory other cables can have an unconnected pin in the plugs.
Accell is the only one with full pin, hence full DP1.2 data transfer rate.
bobbavet is offline
post #64 of 311 (permalink) Old 05-27-2015, 04:36 AM
HardwareDecoder's Avatar
Rep: 142 (Unique: 106)
I don't think that is accurate, I was having some bad display port issues recently and someone told me about this pin. So I went and read a bunch of stuff about it, it is PIN 21 and it is supposed to be disconnected because it will transfer 3.3v power on both ends.
Has nothing to do with the bandwidth. Not saying buying a certain cable is a bad idea however... Just had a DP cable nightmare recently my self. I do mean nightmare too.
HardwareDecoder is offline
post #65 of 311 (permalink) Old 05-28-2015, 07:44 PM
pox67's Avatar
Rep: 0
I have one of these monitors.
Colours aren't as vibrant as the QNIX 2710's it replaced but blacks are much better if the room is fairly dark.
I am getting some flickering every 30 seconds or so and is very annoying. Thanks to King4x4 for alerting me to the fact that this is probably the mini DP ports on the 7970's that I have. Those mini DP ports have been nothing but trouble...
Anyway once I get a certified miniDP - DP 1.2 cable and verify the flickering is gone I'll remove the glass front. I agree with see3d that most things need modding so happy to do this smile.gif
Edit: someone has already removed the glass but I don't read Korean and the page won't translate...
http://blog.naver.com/bbaga6666/220334529848
pox67 is offline
post #66 of 311 (permalink) Old 05-28-2015, 08:41 PM
EniGma1987's Avatar
post #67 of 311 (permalink) Old 05-28-2015, 08:55 PM
see3d's Avatar
Rep: 1 (Unique: 1)
I would really appreciate your checking the reflections without the glass. I have been holding off pulling the trigger solely for this one issue. I thought it funny that google claims the Korean site is translated, but it is still in Korean... LOL
I don't have any windows behind me, but I like to keep a bright room for working in. Seeing my own reflection in the screen would not be cool -- I am not a narcissist. typer.gif
...Anyway once I get a certified miniDP - DP 1.2 cable and verify the flickering is gone I'll remove the glass front. I agree with see3d that most things need modding so happy to do this smile.gif
see3d is offline
post #68 of 311 (permalink) Old 05-28-2015, 09:00 PM
pox67's Avatar
Rep: 0
I'll take a look tonight and see how easy the glass pries off tonight.
In a room with NO windows (converted garage) and a single fluorescent light overhead I found it very annoying. I actually put a small lamp behind the monitor and turned off the overhead light. That helped a lot.
pox67 is offline
post #69 of 311 (permalink) Old 05-29-2015, 03:14 AM
pox67's Avatar
Rep: 0
I just went to take a look and as soon as I put a screwdriver behind it I saw how easy it would be. I undid 3 screws in top right corner to get the backing clear a bit and then just went around the edges slowly leveraging with a couple of flat head screwdrivers. 5 minutes work a VAST improvement smile.gif
It appears to be semi matte, just right really. Much less matte than Dell monitors. Probably less than the QNIX 2710 mattes as well.
The photos are pretty terrible but you can see the big difference between glass and no glass.
pox67 is offline
post #70 of 311 (permalink) Old 05-29-2015, 03:32 AM
Intel Pariah
King4x4's Avatar
Rep: 98 (Unique: 75)
Please don't force me to take mine off mine.
Check out my buids:
Build Log: Hydra
Build Log: Hydra 2
Build Log: Hydra 2.5
Build Log: Hydra 3
Build Log: Mini-Hydra
Hydra
Hydra 2
(23 items)
Hydra 3.0
(10 items)
Intel i7 3930k @[email protected]
Asrock X79 Fataility Champion
3xInno3d GTX 780 with Full Nickel EK Waterblocks
Gskill RipjawsX [email protected] 11-11-11-31
2xSamsung 830 256gb
Seasonic 1250 watt
Custom H2O - 3x XSPC RX360 with EK Blocks
Danger Den Double Wide 21
Surround Gaming [email protected] (X-Star)
Keyboard
Cooler Master Trigger Red Caps
Mouse
Roccat Kone+
Audio
Roccat Kave 5.1 Headphones
Audio
Creative ZX (Incoming)
4930k
Asus Extreme Black Edition
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Sapphire R9 290x
Gskil TridentX 2400mhz
Samsung 830 256GB
Samsung 840 500GB
2x Seasonic 1250watt
EK Supramacy
4x EK Blocks
6x EK XTX480
EK XT360
Case Labs TH10
Operating System
Windows 8.1
BenQ 3201 32in 4k IPS
Qnix 32in 1440 MVA
Qnix 32in 1440 MVA
Keyboard
Coolermaster Storm Trigger
Mouse
Roccat Kone
Audio
Creative ZX
Audio
AKG K7XX
3900x
Gigabyte Aorus Ultra
EVGA 1080 Ti
EVGA 1080 Ti
Ballistix Sport LT 32GB
EVGA G2 1600w
Full EKWB
Caselabs TH10
Operating System
Win 10 Pro
Acer 144hz G-Sync
King4x4 is offline
