ViewSonic XG2401 better than LG? - Overclock.net - An Overclocking Community
post #1 of 181 (permalink) Old 03-10-2016, 12:10 PM - Thread Starter
CtrlAltElite's Avatar
Rep: 55 (Unique: 50)
Bought my xl2420g last week and its really not cutting it. When in gsync mode the colors suck, very little adjustments when on that engine. The classic mode is much better. That said, I was going to return it and get the LG 24GM77. I saw Viewsonic has a decent solution out also ViewSonic XG2401. Was curious your thoughts on the the Viewsonic compared to the LG
Feeling sad? Funniest thread ever! CLICK
.-[SandyBridge]-.
.5ghz Pl+s Club.
We Are Gr33n Machine
The Silverstone case owners club
CtrlAltElite is offline
post #2 of 181 (permalink) Old 03-10-2016, 03:09 PM
Redbugz007's Avatar
Rep: 1 (Unique: 1)
The Viewsonic is a Freesync Monitor, Your current one is a G-Sync and the Ben-Q is neither, do you need Adaptive Display tech?. Adjustments to the image should be available through the NV control panel as well btw. The LG uses PWM lighting which can cause headaches, the Viewsonic doesn't. i don't have the Lg but I do have the VS so feel free to ask any questions.
Redbugz007 is offline
post #3 of 181 (permalink) Old 03-10-2016, 04:09 PM - Thread Starter
With g sync engine on the colors suck. and the horizontal lines bother me.Ive been running in classic mode engine just bc the picture is better. Figure if the viewsonic without free sync on has better picture than the benq, id consider that
.-[SandyBridge]-.
.5ghz Pl+s Club.
post #4 of 181 (permalink) Old 03-10-2016, 04:44 PM
Malinkadink's Avatar
Rep: 108 (Unique: 84)
The LG does not use PWM and is flicker free. Its also easily the best 24" 1080 144hz TN panel you can buy. From my understanding the monitor has been discontinued and while there is still plenty of stock floating around, prices will surely go up in due time.
Malinkadink is offline
post #5 of 181 (permalink) Old 03-10-2016, 08:07 PM
Redbugz007's Avatar
Rep: 1 (Unique: 1)
You are correct: http://www.tftcentral.co.uk/articles/flicker_free_database.htm
post #6 of 181 (permalink) Old 03-13-2016, 10:05 PM
KenKen8899's Avatar
Rep: 0
Seriously man, I don't know why you'd think twice about going with the VS.... even if you have an NVIDIA card, the input lag is WAY LOWER than the LG panel and you might as well get some Adaptive-Sync tech for yourself for later (just in case...). The price is amazing as well, just see for yourself.
http://www.tomsguide.com/us/viewsonic-xg2401,review-3428.html
KenKen8899 is offline
post #7 of 181 (permalink) Old 03-16-2016, 10:00 PM
AMD Acolyte
qwertymac93's Avatar
Rep: 76 (Unique: 70)
I just got the xg 2401 in today and the measurements look very good for a TN panel after calibration, pre-calibration is certainly good enough for gaming I'd say. Input lag is definitely low when set to "ultra fast".
Native (Click to show)
Calibrated (Click to show)
"We should make it clear that NVIDIA is a good company, and we respect their attempted transition into being a smartphone company." - Roy Taylor, AMD
BF3 STATS/BF4 STATS
z87
(19 items)
Media Rig
(18 items)
Core i5 4670k - [email protected]
MSI z87m GAMING
MSI R9 280 GAMING - 1.15ghz core/1.5ghz mem
A-DATA 2x4GB DDR3
PNY 2x4GB DDR3
Crucial M500 240GB
Seagate 3TB
Antec TruePower TP-550
Xigmatek Gaia + Cougar VortexPWM
Silverstone PS07
Operating System
Windows 10 Pro
Viewsonic XG2401
Keyboard
CM Storm QuickFire Rapid
Mouse
Logitech G402
Mouse
Reflex Lab Pro 32 Heavy
Audio
Beyerdynamic DT 770 PRO-80
Audio
Yamaha RX-V663
Audio
Micca MB42x Bookshelf Speakers
Audio
SMSL Q5
AMD Phenom II 720
ASRock 870 Extreme 3
HIS 5750 (840core/1200mem)
2*2GB A-Data DDR3 1600
Seagate Barracuda ST1000DM003
Seagate Barracuda ST3000DM001
Optical Drive
Lite-On Blue Ray WH14NS40
Corsair CX-430
Arctic Cooling Freezer 64 PRO
NZXT Beta EVO
Operating System
Windows 10 pro 64-bit
Vizio M43-c1
Keyboard
Logitech K400
Mouse
Gigabyte M7700
Audio
Sony STR-DN1070
Audio
Definitive Technology BP8 Tower Speakers
Audio
Definitive Technology 2002 Series Center Speaker
Audio
Definitive Technology ProMonitor 1000 Bookshelf Speakers
qwertymac93 is offline
post #8 of 181 (permalink) Old 03-16-2016, 10:41 PM
MenacingTuba's Avatar
Rep: 308 (Unique: 224)
This is impossible, but it does not surprise me that a Toms Guide review fan would post this. The LG's measured signal delay is negligible. We can argue about adding half the measured pixel response time for a total lag value, but even if this is done the total delay amounts to a whopping (sarcasm) 3.4ms (negligible).
Can you screen shot the pre-calibrated gamma results? The 1080p 144hz TN panels gamma is usually way too low (AOC G2460PF, Asus VG248QE) or way too high (Acer GN246HL and BenQ XL2411Z & XL2430T).
Changing monitors overdrive settings usually has no perceivable and barely a measurable effect on input lag. Ultra Fast likely just adds excessive overshoot ghosting (transparent, dark and colored glow which forms around movement) which you can check for here: http://testufo.com/#test=ghosting
Google (insert monitor) review before making a thread about it. Research (Google) before buying a monitor and then asking if it is good.
10 Bit Monitors: 99% are 8 bit+FRC and AMD Quadro or Nvidia Firepro gpu's are required to send+receive a true 10 bit signal. 10 bit consumer content (games, movies TV) does not exist.
MenacingTuba is offline
post #9 of 181 (permalink) Old 03-17-2016, 12:45 AM
AMD Acolyte
Pre-Calibration (Click to show)
Post-Calibration (Click to show)
I wasn't talking about overdrive, that is controlled by the "response time" setting and changing THAT setting to "ultra fast" does indeed add a lot of overshoot.
The "input lag" option is separate and I didn't notice any worsening of the image quality when changing it.
BF3 STATS/BF4 STATS
z87
(19 items)
Media Rig
(18 items)
MSI z87m GAMING
A-DATA 2x4GB DDR3
PNY 2x4GB DDR3
Crucial M500 240GB
Seagate 3TB
Silverstone PS07
Operating System
Windows 10 Pro
Viewsonic XG2401
Keyboard
Mouse
Logitech G402
Mouse
Audio
Audio
Yamaha RX-V663
Audio
Audio
SMSL Q5
AMD Phenom II 720
Optical Drive
Corsair CX-430
NZXT Beta EVO
Operating System
Vizio M43-c1
Keyboard
Logitech K400
Mouse
Gigabyte M7700
Audio
Sony STR-DN1070
Audio
Audio
Audio
post #10 of 181 (permalink) Old 03-17-2016, 01:51 AM
Those are fantastic gamma results on par with the LG. Thanks to you we now know the Viewsonic (assuming there's no panel lottery) is the best 1080p 144hz TN panel in terms of pricing and all around performance.
I thought you were referring to the overdrive setting since I didn't know the Viewsonic had an input lag setting. The lag setting was likely included for marketing purposes.
