I perform better on my 75hz monitor than on my 144hz one - Page 2 - Overclock.net - An Overclocking Community
post #11 of 62 (permalink) Old 07-31-2017, 05:19 PM - Thread Starter
Passante's Avatar
Rep: 0
Exactly. It is weird. They're all faster than me.
And when switching between weapons you can feel that "delay" even more.
Passante is offline
post #12 of 62 (permalink) Old 07-31-2017, 05:31 PM
Overclocker
EastCoast's Avatar
Rep: 140 (Unique: 94)
If memory serves me correctly I think it may have something to do with flip queue size. There's another name that the nvidia calls it but I forget what it's called., I think that feature is been decommissioned for some time. And it required tweaking the registry in order to change it. 1 would be the fastest but have a performance hit. 2 was the middle ground. While 3 or 4 have the highest latency but offer higher frame rates. That was good for single player games.
You may need to find a copy of a program or app is called timer resolution. That might help your situation. You start the game 1st. Then you start TR. Then set it tp.500ms
EastCoast is offline
post #13 of 62 (permalink) Old 07-31-2017, 05:49 PM
Leopardi's Avatar
Rep: 18 (Unique: 18)
"Virtual Reality pre-rendered frames" is the option for nvidia.
Leopardi is offline
post #14 of 62 (permalink) Old 07-31-2017, 05:55 PM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
What's the actual input/processing latency of the panel?
High refresh rate doesn't always imply low input lag.
Originally Posted by TwoCables View Post
He has an AMD video card.
Can still adjust the D3D queue depths with FlipQueueSize in the registry.
However, since this doesn't vary because of the display itself, something else is likely the culprit.
Not the same option.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #15 of 62 (permalink) Old 07-31-2017, 05:58 PM - Thread Starter
Passante's Avatar
Rep: 0
Ok, this is interesting. I disabled my monitor through the device manager and now the game definitely runs faster. I need to do some more testing, hope it ain't a placebo effect.
Passante is offline
post #16 of 62 (permalink) Old 07-31-2017, 06:18 PM
Leopardi's Avatar
Leopardi is offline
post #17 of 62 (permalink) Old 07-31-2017, 06:23 PM
Overclocker
EastCoast's Avatar
ok you can check to see If u have multiples of the same monitor device. Keep in mind that you are supposed to have two of the same monitor in Hidden devices. One is for when you uninstall your video card driver. The second is for when you do install your video card drivers.
open command prmpt with Admin. privileges
type: SET DEVMGR_SHOW_NONPRESENT_DEVICES=1
enter
Next, type devmgmt.msc and hit Enter to open the Device Manager.
From the View tab, select Show hidden devices. You will see some additional devices get listed goto Monitor.
Delete all but 2 of the same monitor. Only delete the grayed out ones.. Just save 1 grayed out monitor of the same type and one active monitor of the same type.
post #18 of 62 (permalink) Old 07-31-2017, 07:01 PM - Thread Starter
Passante's Avatar
Rep: 0
Ok EastCoast, I did it. But I am curios why is it needed one grayed out copy?
Anyway, I have a great news for me and you all. Just minutes ago I found out a new tab in my GPU software under Display -> specs -> Override. There I have 2 options: "Adjust Voltage Swing" and "Adjust PreEmphasis". Both have a minimum value of 0 and max of 2. Just tried to play with both of them at 2 and viola, finally, this monitor started to run properly. thumb.gif
I suppose the PreEmphasis should be the equivalent of the prerendered frames for the Nvidia Gpus?
Passante is offline
post #19 of 62 (permalink) Old 07-31-2017, 07:02 PM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
Are you using the AMD driver to set 3D graphics settings for your games instead of using the in-game graphics settings provided by the games?
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #20 of 62 (permalink) Old 07-31-2017, 07:05 PM - Thread Starter
Passante's Avatar
Rep: 0
Everywhere where possible I set it to "use application settings".
Passante is offline
