I perform better on my 75hz monitor than on my 144hz one - Page 3 - Overclock.net - An Overclocking Community
post #21 of 62 (permalink) Old 07-31-2017, 06:20 PM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
Oh, that's good. It sounds like you know better performance is achieved with those settings. I'm glad to rule that out. I immediately became curious to see if what you found was really more of a band-aid kind of solution, but maybe not.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #22 of 62 (permalink) Old 07-31-2017, 06:34 PM
Nick7269's Avatar
Rep: 115 (Unique: 107)
Sometimes upgrades are not smooth as we would like, so don't give up! So assuming that you have already checked to see your gpu drivers are up to date, I am curious about the rest of the rig. An AMD 460 may not be the best but it should still perform well. Does the computer have at least 4 gig of memory or hopefully 8 gig? Have a decently strong cpu? Need more power to drive those higher speeds we are all looking for. Maybe you have a bottle neck somewhere slowing you down?
Nick7269 is offline
post #23 of 62 (permalink) Old 07-31-2017, 06:44 PM
Overclocker
EastCoast's Avatar
Rep: 140 (Unique: 94)
Originally Posted by Passante View Post
Ok EastCoast, I did it. But I am curios why is it needed one grayed out copy?
Anyway, I have a great news for me and you all. Just minutes ago I found out a new tab in my GPU software under Display -> specs -> Override. There I have 2 options: "Adjust Voltage Swing" and "Adjust PreEmphasis". Both have a minimum value of 0 and max of 2. Just tried to play with both of them at 2 and viola, finally, this monitor started to run properly. thumb.gif
I suppose the PreEmphasis should be the equivalent of the prerendered frames for the Nvidia Gpus?
To rule out any conflicts between old and new device drivers for your monitor. They sometimes accumulate in upwards of 5-7 of the same type of monitor device which are then grayed out (one at a time can be used). None of which is a problem as long as it's the same driver version.
But from reading your post looks like you got it sorted so congrats!!
EastCoast is offline
post #24 of 62 (permalink) Old 07-31-2017, 06:54 PM - Thread Starter
Passante's Avatar
Rep: 0
Yes, now that "delay" and sense of heaviness is gone. But I wonder why does it have to be so not intuitive. That "voltage swing" setting should be set by default! It is almost hidden in sub menus...
Passante is offline
post #25 of 62 (permalink) Old 07-31-2017, 06:56 PM
TwoCables's Avatar
This may be a very isolated and unique situation.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #26 of 62 (permalink) Old 07-31-2017, 07:02 PM
Leopardi's Avatar
Rep: 18 (Unique: 18)
It's an AOC, so this is definitely related to overclocking somehow.
Leopardi is offline
post #27 of 62 (permalink) Old 07-31-2017, 07:05 PM
TwoCables's Avatar
Ok. Can you explain?
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #28 of 62 (permalink) Old 07-31-2017, 07:10 PM
Leopardi's Avatar
The 2460 AOC's are cheap because they are overclocked to 144Hz, and are known to have lots of units with missing frames etc.
Leopardi is offline
post #29 of 62 (permalink) Old 07-31-2017, 07:13 PM
Overclocker
EastCoast's Avatar
Oh, I see so the monitor was the problem after all. Wow, amd driver's come a long way to detect that monitor and allow the option to tweak it.
Impressive!
post #30 of 62 (permalink) Old 07-31-2017, 07:43 PM
TwoCables's Avatar
No, that's not it. The Acer XB241H and ASUS PG248Q are 120Hz native panels as well, just the same as the AOC G2460PG and G2460PF. All 4 of these monitors are using pretty much the same panel and 144 Hz is a factory overclock.
The reason why the AOC monitors are cheap is, they have far less features (they are much more basic) and you're not paying for the Acer or ASUS brand name (which also includes many other things you're paying for).
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
