I perform better on my 75hz monitor than on my 144hz one - Overclock.net - An Overclocking Community
post #1 of 62 (permalink) Old 07-30-2017, 04:40 PM - Thread Starter
Passante's Avatar
Rep: 0
Hi all, recently purchased the AOC G2460PF as an upgrade from a generic 75hz monitor. I was hoping for a slight boost in my overall gaming experience, but instead everything got worst.
I play mainly FPS games and I constantly underperform on the new monitor. In game I feel heavy and slow, the whole game feels delayed. As soon as I switch back to my old monitor suddenly my score and performance returns to the usual level.
Tried both of the drivers available for the monitor without any result.
I feel like I've thrown money out of the window.
Passante is offline
post #2 of 62 (permalink) Old 07-30-2017, 04:58 PM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6215 (Unique: 3521)
Are you using FreeSync or V-Sync? I ask because it sounds like high input lag to me and V-Sync is known for having the worst input lag.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #3 of 62 (permalink) Old 07-30-2017, 05:21 PM - Thread Starter
Passante's Avatar
Rep: 0
Have tried with FreeSync (since I got the rx 460), Vsync on or Off. It always feels delayed. "InputLag" would be more appropriate as a definition I guess.
Also, I tried to run it without driver, still the same.
Passante is offline
post #4 of 62 (permalink) Old 07-30-2017, 09:48 PM
cskippy's Avatar
Rep: 7 (Unique: 7)
Check to see if display scaling is enabled in Nvidia Control Panel. It's under adjust desktop size and position. It should be set to no scaling and let Monitor do the scaling, GPU if Monitor can't be selected.
Also, sometimes with different monitors the Nvidia game settings can change so double check that maximum prerendered frames is set to 1, vsync off in control panel etc.
cskippy is offline
post #5 of 62 (permalink) Old 07-30-2017, 09:49 PM
TwoCables's Avatar
He has an AMD video card.
Optical Drive
Optical Drive
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
Keyboard
Mouse
Mousepad
Audio
X-Fi Titanium HD
Audio
post #6 of 62 (permalink) Old 07-30-2017, 09:57 PM
cskippy's Avatar
Rep: 7 (Unique: 7)
All my information is still relevant to check with their drivers.
cskippy is offline
post #7 of 62 (permalink) Old 07-31-2017, 02:12 PM - Thread Starter
Passante's Avatar
Rep: 0
I have "GPU Scaling" as an option and it is off, in the "Display" tab and in the game specific tab.
Something is terribly wrong here. To give you an example, I was running with a knife chasing a guy, he was with weapon and he outrun me.
At this point I wonder if the GPU is powerful enough for 1080p since my 75hz monitor's native resolution is 1600x900 and games run fast there.
But games such as CS:GO, CS 1.6 shouldn't be any problem for such card.
Passante is offline
post #8 of 62 (permalink) Old 07-31-2017, 03:52 PM
Pinp0int's Avatar
Rep: 2 (Unique: 1)
Do you actually have the monitor running at 144hz? :) Often monitors default to 60hz and with certain cables (such as DVI-I or HDMI) can't go above that.
Pinp0int is offline
post #9 of 62 (permalink) Old 07-31-2017, 04:39 PM - Thread Starter
Passante's Avatar
Rep: 0
Yep, it's running at 144hz through a DispalyPort cable.
Passante is offline
post #10 of 62 (permalink) Old 07-31-2017, 04:45 PM
Overclocker
EastCoast's Avatar
Rep: 141 (Unique: 94)
Let me guess at the start of around where ypou are frozen until the counter expires you and 10+ other guys are running and everyone beating you down the road. Correct?
EastCoast is offline
