How do I cap/customize my FPS - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 11-16-2017, 09:23 AM - Thread Starter
Rep: 4 (Unique: 2)
Hi everyone,
How do I cap my FPS, I don’t want to use V-Sync because it only caps it at your refresh rate and I want to customize the FPS. I also have ASUS GPU tweak if you can do it on there.
https://youtu.be/raEg3GiT57I
Thanks
Zic05 is offline
post #2 of 7 (permalink) Old 11-16-2017, 10:16 AM
Cysquatch's Avatar
Rep: 72 (Unique: 47)
download MSI afterburner with rivatuner. I believe you can do it in there. What refresh rate is your monitor?
Cysquatch is offline
post #3 of 7 (permalink) Old 11-16-2017, 10:18 AM - Thread Starter
Rep: 4 (Unique: 2)
144Hz, And will MSI afterburner affect ASUS GPU tweak
Zic05 is offline
post #4 of 7 (permalink) Old 11-16-2017, 06:45 PM
Koslov's Avatar
Rep: 6 (Unique: 6)
It's better to cap your fps using the in-game settings. If none is present sometimes you can pull up the console or edit a *.ini file.
otherwise get riva turner statistic sserver to limit your fps but it adds a little bit of delay.
Koslov is offline
post #5 of 7 (permalink) Old 11-16-2017, 06:57 PM
Boo Hiss metadtaclock.net
nvidiaftw12's Avatar
Rep: 237 (Unique: 190)
It shouldn't. I think you can disable overclocking. Your asus software will have it if it's built off Rivatuner. That's probably your best bet.
nvidiaftw12 is online now
post #6 of 7 (permalink) Old 11-17-2017, 07:13 AM - Thread Starter
Rep: 4 (Unique: 2)
Well, I installed MSI afterburner and rivia and then uninstalled MSI afterburner and kept Rivia. Though when I tried the FPS cap I turned on my monitors FPS counter and caped the FPS on rivia and nothing happened. Haven’t tried it in game yet.
Thanks
Zic05 is offline
post #7 of 7 (permalink) Old 11-18-2017, 08:36 AM - Thread Starter
Rep: 4 (Unique: 2)
Everything works just fine, with rivaturner. Thanks for all the help!
Zic05 is offline
