What is going on with my monitor? - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 12-18-2018, 03:16 PM - Thread Starter
Jellystab's Avatar
Rep: 1 (Unique: 1)
Hi everyone,
I recently built a pc. I got a used EVGA 1080 Ti FT3 and two new Dell S2716DG monitors.
I never turn my pc off or sleep it. About once a week I will turn the main display on and it will look like the photo.
If I screenshot it and drag the screenshot or the browser to the other monitor everything is crisp and clear. Also, it's not just the browser that looks like this, it is anything that is displayed on the monitor.
To fix this problem I just restart my pc and in about a week or so it will happen again.
Initially I thought it may have been a driver issue because I had the GPU in my old pc that had an AMD card. So I used DDU to completely uninstall the AMD drivers and re-installed the Nvidia drivers and it took about a month until it happened again.
Now that I have completed my entire new build, I put the Nvidia card in it and it now occurs about once a week.
Any idea what this is and how to fix it?
Thanks,
jellystab
Jellystab is offline
post #2 of 12 (permalink) Old 12-18-2018, 03:21 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
Can be a simple cable issue or a problem with the logic board of the monitor.
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
post #3 of 12 (permalink) Old 12-18-2018, 04:55 PM - Thread Starter
Jellystab's Avatar
Rep: 1 (Unique: 1)
Thanks for the reply.
I will try replacing the cable.
+Rep
post #4 of 12 (permalink) Old 12-20-2018, 09:32 AM
Fishinfan's Avatar
Rep: 187 (Unique: 173)
My suggestion is to test the gpu card with another card( if you have one laying around).
Also, the last update this site got took off the rep system.
Fishinfan is offline
post #5 of 12 (permalink) Old 12-20-2018, 09:33 AM
Axaion's Avatar
Rep: 56 (Unique: 48)
Its probably pregnant
(14 items)
3700x
Crosshair VII Hero
MSi GTX 970 Gaming 4G
G.skill FlareX 3200Mhz CL14
SX8200 Pro 1TB +30 TB Spinning Rust
Seasonic SSR-1000TR
Dark Rock 4 Pro
Fractal R6 (Dont buy, terrible HDD trays)
Operating System
Win 10 Pro x64
Viewsonic VX2268wm
Keyboard
SteelKeys 6G
Mouse
Pro Intellimouse
Mousepad
QcK Heavy/Artisan Zero XL FX
Audio
Craptive AE-5
Axaion is online now
post #6 of 12 (permalink) Old 12-20-2018, 11:53 PM
hmcindie's Avatar
Rep: 1 (Unique: 1)
I have that same issue with an ACER model xb270hu. It happens maybe once in two-three weeks. It has something to do with the monitor sleeping as it mostly happens after the monitor has slept.
hmcindie is offline
post #7 of 12 (permalink) Old 12-21-2018, 12:09 AM
Shadowarez's Avatar
Rep: 25 (Unique: 22)
Mine has been flickering at anything above 60hz I have tried diff cards and cables. First card was a Titan X with a regular cable came with monitor other was a Fury R9 with a cable from Amazon $33 dp high bandwidth cable. Same issue then tried the Vega Fe card tried with multiple drivers 2 duff cables. Thinking it's time to use my first Rma.
Shadowarez is offline
post #8 of 12 (permalink) Old 12-21-2018, 12:59 AM
umeng2002's Avatar
Rep: 176 (Unique: 112)
I only have that issue sometimes with DisplayPort on my monitor (see my specs in my sig). I only see that sometimes during the Windows loading screen and goes away once Windows actually starts. With DVI, I've never seen it. Granted my monitor is from back when DisplayPort was brand new.
It probably has something to do with nVidia's DisplayPort implementation. I know the GTX 970 and I think other Maxwell cards had a firmware update not too long ago (maybe even Pascal)... something about DisplayPort.
My monitor from 2008 has that issue with DisplayPort and your new monitors have that issue with DisplayPort, the only common thing is nVidia & DisplayPort.
Actually using Windows, sometimes when the monitor wakes up with the Computer, using DisplayPort, it seems the timings get screwed up and the screen is torn... like the top and bottom of the frame buffer are in the middle of the screen around the tear... I simply turn the monitor off and then back on... no need to restart Windows.
It's clearly some sort of timing issue when the monitors wake up with nVidia GPUs.
EDIT:
It might also just be EVGA since my card is also EVGA. Go to EVGA's website and see if that card has a firmware update.
AMD Ryzen 2700X
Asus Prime X470-Pro
EVGA GeForce RTX 2070 XC Ultra
TeamGroup T-Force 16 GB (2x8) Pro Dark (B-die TDPGD416G3200HC14ADC01)
ADATA XPG SX8200 Pro 512GB NVMe
Seasonic Focus Plus Platinum SSR-750PX
Corsair H80i (not V2 or GT)
LG 34UC80-B
Keyboard
Logitech G413
Mouse
Logitech G503 RGB
Audio
Creative SoundBlaster Z (OEM)
umeng2002 is offline
post #9 of 12 (permalink) Old 12-28-2018, 11:20 PM
SirWaWa's Avatar
Rep: 39 (Unique: 34)
https://www.nvidia.com/object/nv-uefi-update-x64.html
The Z390
(19 items)
The X299
(18 items)
Intel i7 8086K @ 4.0Ghz
Asus ROG Z390 Maximus XI Extreme
Asus ROG Strix 1080 8GB GDDR5X A8G Edition
G.Skill Trident Z RGB 32GB DDR4 XMP 3200MHz 15-15-15-35
Intel 760p M.2 PCIe Solid State Drive 512GB
Intel 545s Series SATA III Solid State Drive 512GB
Corsair HX850 80 Plus Platinum
Corsair H115i PRO RGB 280mm Radiator
Corsair 750D
Operating System
Windows 10 Pro
LG 27MP68VQ-P 27" 1920 x 1080 75Hz IPS LED
Keyboard
Logitech G810 Orion Spectrum RGB
Mouse
Logitech G502 Proteus Spectrum RGB
Mousepad
SteelSeries 4HD
Audio
Logitech X-540 5.1 Speaker System
Intel i7 7820X @ 3.6GHz
Asus ROG Strix X299 Gaming XE
Asus ROG Strix 1080 Ti 11GB GDDR5X OC Edition
G.Skill Trident Z RGB 32GB DDR4 XMP 3200MHz 16-18-18-38-2N
Corsair 750D
Operating System
Windows 10 Pro
Asus ROG Strix VG27VQ 144Hz VA
Keyboard
Mouse
Mousepad
Logitech G440
Audio
Logitech Z323 2.1 Speaker System
SirWaWa is offline
post #10 of 12 (permalink) Old 12-28-2018, 11:48 PM
betam4x's Avatar
Rep: 0
General NVidia/Displayport nonsense. Might also be Acer. I have 2 Acer 25" monitors, and I've had issues with the monitors losing signal and the display blanking out several times along with the exact same issue you had. I do not recall ever having these issues with an AMD card. I've contemplated ordering new DisplayPort cables, but I own so many (non displayport) cables currently I could rival monoprice. I can't recall having your issue with HDMI, but the signal loss issue still happened. None of those issues happened if one of the monitors was hooked to DVI, however, with DVI you don't get HDCP.
betam4x is offline
