Aorus AD27QD - 10bit Question - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-12-2019, 11:34 PM - Thread Starter
NEK4TE's Avatar
Rep: 11 (Unique: 8)
Hello,
Recently purchased this monitor, however, i am confused when it comes to 10bit.
What exactly does this do / how it works? (Is it important)
I did do some Google re-search, however, its still not completely clear to me.
Hopefully, somebody will be able to explain better (thanks!)
Also, in Windows 10, AMD / RADEON Settings, when Monitor is set 60Hz (In Windows), i can see Color Depth set to 10bpc ( i can even change it to 12 ), however, if i change Monitor to 144Hz (In Windows) , i can only set it to 8bpc.
Is something wrong here, its supposed to be like this?
60Hz (Windows):
144Hz (Windows):
This was changed automatically to 8bpc after i changed refresh rate, and unable to set it back to 10bpc while on 144Hz.
Please advise, thank you!
NEK4TE is offline
post #2 of 8 (permalink) Old 05-12-2019, 11:35 PM - Thread Starter
NEK4TE's Avatar
Rep: 11 (Unique: 8)
Just to add, just found out, even if i set Windows 10 to 120Hz, i am able to set it to 10bpc.
NEK4TE is offline
post #3 of 8 (permalink) Old 05-13-2019, 10:14 AM
QuantumPion's Avatar
Rep: 3 (Unique: 2)
From what I understand, 10bit color basically means HDR color mode. HDR color is only supported up to 120 hz by display port standards, or something like that.
QuantumPion is offline
post #4 of 8 (permalink) Old 05-13-2019, 04:29 PM - Thread Starter
NEK4TE's Avatar
Rep: 11 (Unique: 8)
Thanks for responding.
This is confusing for me as well, so, in case a game is played with 144Hz (and if game supports HDR), it cannot run in 10bit color mode? = false advertising, or i am confused 200% ?
Thanks
NEK4TE is offline
post #5 of 8 (permalink) Old 05-14-2019, 07:02 AM
Overclocker
JackCY's Avatar
Rep: 361 (Unique: 258)
LOL no, completely unrelated.
Thanks
8bit = 256 per color.
10bit = 1024 per color.
10bit uses more bandwidth, only certain applications support 10bit output and unless you have professional GPU driver with OpenGL-10bit support etc. you're not gonna get say Photoshop to show 10bit. You need the Quadro/FirePro driver for that. On consumer cards you can get 10bit, or should be able to, via 3D APIs, such as some video players, games if they would care to support 10bit.
1440p 144Hz 8bit = 14.08Gb/s
1440p 144Hz 10bit = 17.60Gb/s (25% more)
If it doesn't have DP 1.3+ it will be limited to 17.28Gb/s and may not allow you or offer you in EDID by default a 10b 1440p 144Hz.
HDR mode is again different, by default uses 10b which means most HDR advertised monitors never reach max refresh in HDR mode at least not without sacrificing chroma quality. Some are fine but not all. Even in SDR mode some monitors especially Gsync ones have to sacrifice chroma quality to achieve max advertised refresh rate, more of an issue with 4k monitors though.
I don't think they are false advertising, you just need to read better and check what you're buying.
JackCY is offline
post #6 of 8 (permalink) Old 05-14-2019, 08:36 PM - Thread Starter
NEK4TE's Avatar
Rep: 11 (Unique: 8)
Thank you for your time and providing this useful information.
This clears it all up.
Thanks again!
NEK4TE is offline
post #7 of 8 (permalink) Old 05-21-2019, 05:46 AM
Rep: 3 (Unique: 2)
Can HDR mode run in 8-bit color? How does it compare to HDR mode in 10-bit color with 4:2:2 chroma compression?
Also I think my original point is still mostly correct although I phrased it wrong. 10-bit color mode's max refresh is limited by the DP standard used, and that 10-bit color is used for HDR color mode.
post #8 of 8 (permalink) Old 05-30-2019, 04:34 PM
Overclocker
JackCY's Avatar
I think HDR standard specifies 10bit minimum. Technically you can do HDR in any bit depth (and suffer from even more banding below 10bit) but what you can buy now is standardized HDR 10bit mostly.
https://en.wikipedia.org/wiki/High-d...ideo#Standards
4:2:2 will look bad if you focus on the chroma resolution difference that there is.
Yes.
JackCY is offline
