[close please]Hex monitor stand that supports 27,32,34 monitors - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 05-14-2019, 12:55 PM - Thread Starter
zlpw0ker's Avatar
Rep: 3 (Unique: 2)
I'm IT, and I'm educating myself in network administrator and I have few hobbies and interests.
I want this dream monitor setup with 6 monitors, so last part of 2018 and beginning of 2019 I was saving up money to realize this, I even got money from christmas and such.
First thing, I realized that my 1080 seahawk x wouldnt give me enough DP for all my monitors, so I bought a second 1080 seahawk x.
In Januar 2019 I ordered 2x Acer x34p and 2x Dell u3219q. Both the acer x34p and u3219q took 2.5months to arrive in the shelfs on komplett.no. I cancelled the x34p and ordered 2x Dell u3417w and 1 or 2 weeks after the Dell u3219q arrived home and I plugged 1 in my second 1080 gpu. the second u3219q is sitting home since I dont have place on my desk for it.
My monitors will only be productivity, I have a center Asus pg279q for gaming,movies,VM's,network documentary,packet Tracer,Putty,GNS3 while my left and right 3417w monitors will be fully productivity with chrome,FF,excel spreadsheets,word documents and other things. 1 of my 3219q is planned being used for my internal hw monitoring, second u3219q would be monitoring of my home network, like Glasswire. While my Dell u2515h would also be for network monitoring but with Wireshark.
my desk is at max 68 inches wide which is comprised of 2 desks in a L-shape way.
Since Mars I have been searching for a desk monitor stand that supports 6monitors in different sizes in 27,32,34 UW and a 25inch. I have checked locally, on all online retailers in Norway, amazon,ebay and I finally ended on a monitor hex stand on multi-monitors.com and I found a model,but its too wide for my desk.
I have a little over 1week left of a 60 day open return policy and I want to ask if anyone knows any solution that fits my desk of 68 inches wide
requirements:
* Holds 27,32,34 inch monitors
* the hinges on the stand can be adjusted so the monitors can go outwards towards my FOV.
* The desk stand feet is sturdy and would have 2 C shaped feet so I dont have this terror that one day the feet will give in and not support and or otherwise be unstable.
* Not wider than 68 inches
I'm wondering if anyone knows a hex monitor stand that is not bigger than 68 inches and an alternative to what I found,but it is too wide.
Thanks for any help
Mobo: Asus X99-E WS USB 3.1 running a 5930K stock and cooling: H100i v2 | Mem: Corsair Dominator Platinum DDR4 32gb 2800(CMD32GX4M4A2800C16) | GPU: 1080 seahawk X | Boot drive 950 pro | HDD's: WD black 5x 6TB | PSU: Corsair AX860i | Case: Fractal Design XL R2 | Monitors: pg279q, Dell U2515H and Dell U2913WM, running triple screen with pg279q as main | FANs: 2x Noiseblocker eLoop Fan B12-P 140mm PWM(replaced stock fans on h100i v2) 2x Noiseblocker eLoop Fan B14-2 140mm(front fans) 1x Noiseblocker eLoop Fan B14-PS 140mm PWM (in front of PSU) | OS Win 10 Pro x64 | NAS: TS-831X RAID6 with 4x6TB. UPS: BlueWalker PW UPS VI 2000 PSW Schuko |
Network Infrastructure: Cisco SB Smart SG220-24p | Cisco RV325 router | Cisco catalyst 2950 switch | BlueWalker PW UPS VFI 1000 | TOTEN 19" Rack Floorstand 37U 600x800 |
zlpw0ker is offline
post #2 of 8 (permalink) Old 05-14-2019, 01:36 PM
LTSC Consiglieri
skupples's Avatar
Rep: 658 (Unique: 351)
WSGF makes the best stands below extreme enterprise custom order pricing.
Their XXL (the one I have) can easily do 3x 32s... they also sell upgrade kits so you can do 3 on top of 3, or 1 over 3, etc.
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is online now
post #3 of 8 (permalink) Old 05-14-2019, 02:16 PM - Thread Starter
zlpw0ker's Avatar
Rep: 3 (Unique: 2)
I have checked on WSGF before,but I couldnt find the monitor stand I was looking for. And they are also really expensive.
Can you link to the xxl stand,because I cant see it in their stand list.
zlpw0ker is offline
post #4 of 8 (permalink) Old 05-14-2019, 02:54 PM
LTSC Consiglieri
skupples's Avatar
I can't get onto WSGF from work (damn you security admin!)
it should be their XXL model + the upgrade poll to do 3 on top of 3. The XXL may have changed names to "Ultimate gaming edition" or something along those lines. It's the 3 way made for 27+
idk which 6 array you got from multi-monitor, most of them are usually nearly $2,000.... The WSGF XXL + upgrade bar should come in under that #, with equal build quality. I don't remember the OEM but they're one of the better ones.
also note, the larger the monitor scale, the more its gonna cost. The jump from 24x6 to 27x6 is quite obscene, so I'd assume the next step would be even more so.
oh wait, do you want 6 all in one giant long line? WSGF doesn't do that, just 3 on top of 3.
post #5 of 8 (permalink) Old 05-14-2019, 03:14 PM - Thread Starter
zlpw0ker's Avatar
Rep: 3 (Unique: 2)
I can link it
https://www.multi-monitors.com/produ...erpc-fads6.htm
This is the model I can fit on my desk and it costs 488 dollars
https://www.multi-monitors.com/produ...erpc40-3x2.htm
This is way wide for my desk and the cost is 788 dollars
I figured as much myself,the bigger the monitors the bigger the price.
I dont want all 6 monitors in a line,that would break my desk the floor would collase into a neutron star.jk aside tho.
I want 3 on top of 3. This is known as 3x2 I belive
Maybe I should register there and post my needs.
zlpw0ker is offline
post #6 of 8 (permalink) Old 05-15-2019, 03:13 AM - Thread Starter
zlpw0ker's Avatar
Rep: 3 (Unique: 2)
I posted on wsgf and they did not have anything what I was after so I guess I have to return 2 of the 4k monitors and buy a stand from multi-monitors when I have the space for it on my desk in the future.
A mod can close this thread.
zlpw0ker is offline
post #7 of 8 (permalink) Old 05-15-2019, 06:18 AM
LTSC Consiglieri
skupples's Avatar
I wouldn't use that cheap one if my life depended on it. It looks like 6 monitors would make it sway in the breeze of the room.
ahh, I see one of the big cost drivers. WSGF & the high end MM.COM devices have adjustable clip on mounts for the monitors. Allowing you to adjust them vertically, as well as the default horizontal/rotation axis normally included.
ahh sorry, best of luck to ya!
post #8 of 8 (permalink) Old 05-15-2019, 09:56 PM
Overclocker
JackCY's Avatar
Rep: 346 (Unique: 244)
You want something sturdy, well built and designed. You don't want to deal with constant wobble or having 3 expensive monitors fall down one day.
If you don't need angling then it's not so hard to make. Still it will probably not be much cheaper than buying it already made.
JackCY is offline
