Help! Monitor for PHoto Editing & Gaming ~ 27 Inch - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 06-05-2019, 07:33 AM - Thread Starter
JAM3S121's Avatar
Rep: 59 (Unique: 52)
Hey!
I'm really out of the loop on what tech and specs I need for a great monitor in 2019. My sig rig is out of date, but I have a GTX 1070, and a Dell 24.5 inch IPS (U2417H) and BenQ 24 inch 144hz Monitor (xl2420z).
My current photo and video workflow heavily uses two monitors and I'm not able to get consistent enough results (colorwise) between the two monitors. I also have not gamed as much recently because I've moved the orientation of the benq for my workflow. I'd really like a 27 inch panel with low response rate/refresh rate (doesn't need to be 1ms) but also has the best possible sRGB coverage. Ideally this monitor would do 80-120hz too. Does anything exist under $600 thats also not 1080p?
Requirements
27 inch
IPS like colors
lower refresh rate (under 3ms?)
97+ sRGB coverage
Under $600?
Thank you so much in advance.
JAM3S121 is offline
post #2 of 2 (permalink) Old 06-05-2019, 10:30 AM
Rep: 0
Here are the best monitors that you can choose if you have tight budget. They are -
ASUS VP228H
Dell E1916HV
AOC I2267FW
ASUS VS228H-P
All these above listed monitors has 27 Inches IPS display pannel.
Here are more monitor that you can checkout - https://bestofmonitor.com/10-best-ga...ors-under-100/
smanvendra12345 is offline
Tags
