Little "Rainbow scratch" fix - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 08-13-2019, 07:04 AM - Thread Starter
Synoxia's Avatar
Rep: 6 (Unique: 4)
Hi, i own a XG2401 monitor, unfortunately i've got this little scratch over there that makes "rainbow effect" and it really bothers me... any suggestion? I thought about a cheap windshield repair kit
I dont think the LCD itself got scratched because this is unnoticeable while gaming, it bothers me mostly while browsing
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
G-Skill Tridentz OC 16 gb 3800 c14-16-17-16-32-48
EVGA G3 Gold
Noctua D15
Phanteks Enthoo pro TG
Operating System
Win 10 1903 build 18950 64bit
Viewsonic XG2401
Keyboard
Fnatic RGB Cherry mx brown
Mouse
Logitech G Pro Wireless 950 dpi
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
post #2 of 5 (permalink) Old 08-13-2019, 07:21 AM
Rep: 3 (Unique: 3)
If its a light scratch I suppose you could try and buff it out but you might make things worse.
You can apparently minimise the rainbow effect by lightly applying some petroleum jelly. A wax polish may also work, no idea have never tried.
clannagh is offline
post #3 of 5 (permalink) Old 08-16-2019, 03:18 PM
Martin778's Avatar
Rep: 15 (Unique: 15)
If it's a non-glare display - DON'T TOUCH IT and don't try to polish it, you will end up with a shiny spot and a destroyed panel.
Core i9 9900K @ 5.2 || EVGA Z390 DARK || 2x8GB G.Skill TridentZ RGB 4600 C18 @ 4266 C17 || GPU: EVGA Kingpin RTX2080Ti @ 2130MHz || Samsung 970PRO 1TB + 860EVO 2TB || Lian Li O11 Dynamic White || Corsair AX1600i || Screen: LG B8 OLED 55 and LG 34GK950F
Corsair H150i PRO + Noctua NF-A12x25
Martin778 is offline
post #4 of 5 (permalink) Old 08-17-2019, 07:27 AM
Overclocker
JackCY's Avatar
Rep: 339 (Unique: 240)
As above you could try something transparent to fill in the scratch. At least it's easy to wipe off if that doesn't work well.
Other than that you're screwed if the top surface is scratched. Even if it was glossy top layer polishing it would likely be quite a task to do it right. Considering how large and varied your scratch is... polishing... what ever effect it would have it would affect a large visible portion unlike say a 5mm single hair scratch.
JackCY is offline
post #5 of 5 (permalink) Old 08-22-2019, 04:41 AM - Thread Starter
Synoxia's Avatar
Rep: 6 (Unique: 4)
Exactly what happened... shiny spot when turned off, some of the scratch removed though
Tryndamere
AMD Ryzen 3700x
Asus C7H Hero Wifi
Radeon Vega 64
EVGA G3 Gold
Noctua D15
Operating System
Viewsonic XG2401
Keyboard
Mouse
Mousepad
Artisan ZERO Fx
Audio
JBL305
Synoxia is offline
