Need Help Finding this Part - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 10-13-2019, 10:31 PM - Thread Starter
RyuKobs's Avatar
Rep: 0
Hey Guys,
I have old not working Samsung Ex2220 monitor, when I opened it up I found a ribbon cable which had disintegrated, I am hoping this is the issue. I cannot track down a replacement cable and I was hoping you guys could help me.
The cable seems to be a power connector for the panel, it connects the from the power board to two small sockets on the panel.
Part Number is Hung Fu AWM21575 E9W252-H VW-1
The Panel is an AU Optronics M215W01 V.6 XXXXG
I attached some pictures sorry for the potato quality.
Thanks in advance!
RyuKobs is offline
post #2 of 8 (permalink) Old 10-13-2019, 10:44 PM
Graphics Junkie
UltraMega's Avatar
Rep: 34 (Unique: 30)
How did the cable get damaged?
Given that this is an old, basic small monitor I doubt you will be able to find the part you're looking for.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #3 of 8 (permalink) Old 10-13-2019, 11:02 PM - Thread Starter
RyuKobs's Avatar
Rep: 0
I have no Idea how it did, the outer plastic part is crumbling exposing the bare wires, I am guessing heat since the most badly affected part is near where it connects to the power board combined with age.
My thinking was someone who repairs monitors might see this post and maybe know where to get this part.
If all else fails I'll go scrap yard hunting when I find the time xD
RyuKobs is offline
post #4 of 8 (permalink) Old 10-13-2019, 11:20 PM
What should be here ?
huzzug's Avatar
Rep: 358 (Unique: 256)
Searching with AWM21575 gets results for different models, but if you can frankenstein it, you can get it to work.
Also, https://m.made-in-china.com/company-lyrachen/ can get you in touch with other manufacturers of cables.
#2 their debt is insane, even for a "diverse field" company. They cannot even afford to service the debt maintenance let alone make an actual dent in the debt itself. - Internet Stranger
huzzug is offline
post #5 of 8 (permalink) Old 10-13-2019, 11:33 PM - Thread Starter
RyuKobs's Avatar
Rep: 0
Thank you for the suggestion. The ribbon cable is basically 20 pin split into two 10 pin. Maybe I could use two 10 pin ribbon cables and jam it in and hope for the best xD
RyuKobs is offline
post #6 of 8 (permalink) Old 10-14-2019, 12:04 AM
Meep
Gilles3000's Avatar
Rep: 304 (Unique: 223)
worth the shot, those ribbon cables are dirt cheap anyway.
Gilles3000 is offline
post #7 of 8 (permalink) Old 10-14-2019, 12:19 AM
Observer
iamjanco's Avatar
Rep: 96 (Unique: 57)
Here's the service manual for the monitor (in PDF format). BN96-13895A is the part number for the cable, which is annotated toward the end of the parts breakdown on page 5-6:
That's the LVDS cable for the model you're working on. They can be easy to destroy if you don't disassemble the monitor carefully.
While I didn't come up with a source for you, that doesn't mean there isn't one out there. You might try querying this seller on Amazon, as the cable you'll see in that link is used in the same monitor per the service guide.
iamjanco is offline
post #8 of 8 (permalink) Old 10-14-2019, 02:39 AM - Thread Starter
RyuKobs's Avatar
Rep: 0
Yes they are very cheap on ebay.
Attachment 300660
Oh my gosh thanks! The service manual is very helpful!
Dude you gave me something more useful than source for the cable, a free site to search for service manuals. Thank you!
RyuKobs is offline
