ASUS ProArt Display PA32UCG - 32-inch, 4K HDR, Mini LED Backlight, 1,152 zones local dimming, 120Hz VRR, Dolby Vision, HDR-10, HLG, - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 11-12-2019, 06:21 AM - Thread Starter
animeowns's Avatar
Rep: 9 (Unique: 8)
ASUS ProArt Display PA32UCG - 32-inch, 4K HDR, Mini LED Backlight, 1,152 zones local dimming, 120Hz VRR, Dolby Vision, HDR-10, HLG, ΔE < 1, DCI-P3, ProArt Hardware Calibration, Thunderbolt™ 3, VESA DisplayHDR 1400 pre-certified
releasing in early Q1 2020 it has a ZBD pixel warranty as well this might seem like the monitor to get if not going the oled route.
https://www.asus.com/us/Monitors/Pro...splay-PA32UCG/
Specs
Display
Panel Size : Wide Screen 32” (81.28cm) 16:9
Panel Backlight / Type : Mini LED / IPS
True Resolution : 3840x2160
Display Viewing Area(HxV) : 708.48 x 308.52 mm
Display Surface : Non-glare
Pixel Pitch : 0.1845 mm
Brightness : 1600 cd/㎡ (Peak)
Contrast Ratio : 1000 :1 (Typical)/1000000 :1 (HDR)
Viewing Angle (CR≧10) : 178°(H)/178°(V)
Response Time : 5ms (Gray to Gray)
Display Colors : 1073.7M (10bit)
Flicker free : Yes
LCD ZBD Warranty : Yes
HDR (High Dynamic Range) Support : Yes (HDR-10 /HLG (Hybrid Log Gamma)/Dolby Vision)
Dynamically Local Dimming : Yes, 1152 Zones
Refresh Rate(max) : 120Hz
Video Feature
ProArt Preset : 13 Modes(Adobe RGB Mode/Rec. 2020/DCI-P3/DICOM/HDR_PQ DCI /HDR_PQ Rec2020/HLG/Dolby Vision/sRGB Mode/Rec. 709 Mode/User Mode 1/User Mode 2)
Color Temperature Selection : 4 Modes
Color Accuracy : △E < 1
Gamma adjustment : Yes (Support Gamma 1.8/2.0/2.2/2.4/2.6 )
Color Adjustment : 6-axis adjustment(R,G,B,C,M,Y)
QuickFit (modes) : Yes (Alignment Grid/Paper/Ruler/Customization Modes)
Picture-in-Picture : Yes
Picture-by-Picture : Yes (support up to 4 UHD windows)
Low Blue Light : Yes
HDCP support : Yes
Adaptive-Sync supported :Yes
Multiple HDR Mode : Yes
Audio Features
Stereo Speakers : 3W x 2 Stereo RMS
I/O Ports
Signal Input : Thunderbolt™ 3 USB-C™ x2 (In x1, Out x1), HDMI x3, DisplayPort
Earphone jack : 3.5mm Mini-Jack
USB Port(s) : 1 x upstream, 3 x Type A port
Mechanical Design
Chassis Colors : Black
Tilt : -5°~+23°
Swivel : -60°~+60°
Pivot : -90°~+90°
Height Adjustment : 0~130 mm
VESA Wall Mounting : 100x100mm
Frameless Design : Yes
Quick Release Stand Design : Yes
Security
Kensington lock
Note
*measuring a screen brightness of 200 nits without audio/ USB/ Card reader connection
Note1. HDR performance requires compatible monitors, streaming devices, video graphic cards, OS and playback software for PC devices or media players which all support HDR function.
Note2. The peak brightness 1600cd/㎡ can only be triggered displaying HDR content that expresses the luminance value of greater than 1000 in a particular scene.
animeowns is offline
post #2 of 11 (permalink) Old 11-12-2019, 03:52 PM
Shardnax's Avatar
Rep: 45 (Unique: 25)
The typical contrast ratio looks disappointing. I thought mini-led was supposed to bring improved black levels. Any word on the insane price tag it surely has? I'm guessing $2k at least since it's in the ProArt line and all the features it's packing.
Shardnax is offline
post #3 of 11 (permalink) Old 11-12-2019, 07:50 PM - Thread Starter
animeowns's Avatar
Rep: 9 (Unique: 8)
well the 60hz version that is similar to this display is going for about $3999 on B&H https://www.bhphotovideo.com/c/produ...a32ucx_4k.html
so if this version will be priced the same it will be a hard pass for me I was looking for something to go alongside my LG C9 tele I might just pickup the HP 1440p 240hz monitor at this point. its $599 on hp right now
post #4 of 11 (permalink) Old 11-13-2019, 01:41 AM
mfw
ToTheSun!'s Avatar
Rep: 427 (Unique: 215)
It does with the 1152 zones. If they're off, it's just a typical IPS display.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Ducky One 2 Mini
Mouse
Glorious Odin
Mousepad
Cooler Master MP510 L
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #5 of 11 (permalink) Old 11-13-2019, 05:42 PM
Shardnax's Avatar
Probably going to be priced higher if they don't discontinue the other model. If an IPS monitor with the same specs comes out I might be tempted; otherwise I think I'll continue waiting until DisplayPort 2 options are out.
Good to know, thanks.
Shardnax is offline
post #6 of 11 (permalink) Old 11-13-2019, 08:43 PM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
I guarantee you this thing will cost 2500 dollars. Also its 5ms latency Also 32" is way small for a 4k now a days. 40" or higher preferred for 4k and not go blind. The only thing that jumps up at me is not the IPS with its issues but the 1400nits ,,,, There is even 4000nits doesn't mean its gonna light up your entire house lol. HDR 1000 is enough heck my TV isn't 1000nits. Ill be shocked if its under 2000k.
INTEL 10980XE @ NO STOCK
GIGABYTE X299X AORUS MASTER
GIGABYTE WF RTX 2080
CORSAIR DOMINATOR PLATINUM RGB @ 64GB 3200 CL16 QUAD CHANNEL B-DIE
CORSAIR MP510 960GB M.2 GEN 3 SAMSUNG 950 PRO M.2 500GB 850 PRO 500GB CRUCIAL M4 500GB LaCie EXTERNAL 2TB PORSCHE DESIGN & 500GB eSATA
CORSAIR AX1600i TITANIUM @ CORSAIR 330r BLACKOUT EDITION CASE
CORSAIR H115i PRO RGB @ NOCTUA NF-14's INTAKE NF-14 EXHAUST NF-P12
AOC 40" CURVED 4k LG 55" C9 OLED G-SYNC 120HZ
Keyboard
LOGITECH 915 LINEAR WIRELESS
Mouse
LOGITECH G PRO WIRELESS
Mousepad
STEELSERIES SMALL
Audio
LOGITECH G935 WIRELESS SCARLETT 2i2 AUDIO INTERFACE KRK ROKITS 10" & SENNHEISER HD 650 & 4.5.0 BTNC SL GRAND 88 Sonar Producer
Turtle Rig is offline
post #7 of 11 (permalink) Old 11-13-2019, 09:01 PM
skupples's Avatar
Rep: 624 (Unique: 342)
all you monitor aficionados.
why can't I find a straight answer on HDMI2.0 10bit support in 4K?
I'm asking here cuz I have the PA329Q, and my DP port flickers.
skupples is offline
post #8 of 11 (permalink) Old 11-14-2019, 11:41 AM
Turtle Rig's Avatar
Rep: 4 (Unique: 4)
Sorry to hear your display port is botched. Have you tried a different DP cable or a different input on the video card ? HDMI 2.1 can do 10-bit with 4k if Im not mistaken.
Keyboard
Mouse
Mousepad
STEELSERIES SMALL
Audio
post #9 of 11 (permalink) Old 11-15-2019, 09:03 PM
subtec's Avatar
Rep: 58 (Unique: 53)
You guarantee it? Based on what? Why would it be $1500 less than the 60hz version (which otherwise has the same specs)?
subtec is offline
post #10 of 11 (permalink) Old 11-15-2019, 09:07 PM
m4fox90's Avatar
Rep: 13 (Unique: 11)
Maybe they forgot a zero on the end
Silence in the Snow
(12 items)
Ryzen 3900X
ASRock X370 Taichi
RTX 2080Ti Black Edition/Hydro Copper
G.Skill RipJaws V 16 GB
Samsung 960 EVO 500GB
2x WD 1 TB SSD
EVGA G3 1000W
EK PE360 + Hardware Labs Black Ice GTS360
EK Supremacy EVO
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Home
Predator XB271HU
m4fox90 is offline
