Triple Monitor Advice - Overclock.net - An Overclocking Community
post #1 of 25 (permalink) Old 12-03-2019, 07:23 AM - Thread Starter
bobsacamano86's Avatar
Rep: 1 (Unique: 1)
I'm looking to upgrade to a triple monitor setup. However I will only game across all 3 games while sim racing. I will play some other games on the middle monitor only. I was thinking of going with a 27" 1440p 144hz monitor for the middle monitor so I can play games at 144hz. My dilemma is what to do with the side monitors.
Option 1: Buy 3 of the 1440p 144hz. This would look good and easy to set up with all monitors being the same but I can't run at 144hz on all 3 monitors at the same time so it also seems like a waste.
Option 2: Buy 1440p 75/60hz monitors for the sides. Drop the middle one down to 75/60 when sim racing since otherwise I'm just using these 2 side monitors for youtube and general internet activities. I don't know how well these will match up with the middle one though since they will be different monitors. I'd like them to match up nicely so I'm not distracted by the bezels while racing.
Option 3: Go with 3 24" 1080p 144hz monitors. A lot cheaper than option 1 but smaller screens and only 1080p.
I've never used a 1440p monitor or a 144hz monitor before. So I'm not really sure how much better a 1440p will look compared to 1080p. I did look at best buy and liked the size of the 27's more than the 24's.
I've also read that IPS is best for triple monitors due to TN's having bad viewing angles. Does anyone have any experience with triple monitors and which panels you used? I have a 24" 1080p TN now and I don't really notice any viewing angle trouble but I also always am looking at it straight on. When I setup my triples I will have the sides angled in so I won't be looking at them on too great of an angle.
I was thinking of buying 2 monitors from Amazon. Maybe the LG 83b or whatever it is and then maybe a cheaper 1440p 144hz and seeing what differences I can see between them. If there isn't too much difference I'd probably get 3 of the cheaper ones.
Thanks for the help.
bobsacamano86 is offline
post #2 of 25 (permalink) Old 12-03-2019, 07:30 AM
speed_demon's Avatar
Rep: 95 (Unique: 74)
Why can't you run 144Hz on all three monitors in game?
Quis custodiet ipsos custodes?
speed_demon is offline
post #3 of 25 (permalink) Old 12-03-2019, 07:33 AM
Aquineas's Avatar
Rep: 3 (Unique: 3)
I guess this is possible at lower resolution, but at 1440p and above, is that possible with today's graphics cards?
Aquineas is offline
post #4 of 25 (permalink) Old 12-03-2019, 07:39 AM
skupples's Avatar
Rep: 630 (Unique: 342)
i'd recommend using identical panels, while not a requirement, it always makes things easier.
you can then set custom resolutions to tune it perfectly(this includes refresh rate). I used to run this identical setup, 100% recommend all three be high hz & identical.
skupples is offline
post #5 of 25 (permalink) Old 12-03-2019, 07:43 AM
Yeah I don't see why something high end like a 2080 Super/ 2080 Ti couldn't handle that. Or there's always the RTX Titan option if you are really serious.
I'd also like to chime in that going with identical monitors is important. I did with my triple 27" LG IPS displays and was glad I did (dat screen real estate tho). Trying to get different monitors to play nicely together always had minor little issues that would bug me to no end.
post #6 of 25 (permalink) Old 12-03-2019, 07:54 AM
xxicrimsonixx's Avatar
Rep: 476 (Unique: 422)
In terms of 1440p vs 1080p, it really depends on the monitor size. A bigger monitor (25-27"+) will really benefit from 1440p, whereas <=24" will be fine with 1080p. You'll end up with similar pixel density on each of the relative screens.
3x 1440p screens will also be much more difficult to run at full resolution.
Triple 1440p = 7680*1440 = 11059200 pixels.
4k = 3840*2160 = 8294400 pixels.
Therefore triple 1440p = 25% harder to drive than a standard 4k panel.
Triple 1080p = 5760*1080 = 6220800 pixels.
Therefore triple 1080p = 25% easier to drive than a standard 4k panel.
Getting triple monitors to run @ 1080p 144hz will be much easier than 1440p @ 144hz. The latter will be nigh impossible with today's technology on AAA titles, whereas the former (1080p) will be easy.
The real question is, are you willing to lower the resolution you play at in order to use the 1440p monitors, and then hold onto them for future graphics technology which will be better able to take advantage of the screens?
Or would you prefer to just max out the resolution of the 1080p monitors today?
One thing I would note is that resolution is useful in more than just games. With a 1440p monitor, you can have 2 full size web browsers open side by side, whereas with 1080p, you can only have a single web browser open (most likely at fullscreen). This affects your productivity, and is an important thing to consider if you use your computer for more than just gaming.
Steam/Origin ID: xxicrimsonixx
i7 4930K
ASRock Fatal1ty X79 Professional
Gigabyte Aorus 1080ti SLI
16GB G. Skill Ripjaws Z
2x 250GB Samsung 840 Series SSD RAID 1
2x 3TB Seagate Barracuda 7200.14 RAID 1
Optical Drive
Samsung Burner w/ Lightscribe
Cooler Master Silent Pro 1200W Gold
Custom Watercooling
Cooler Master HAF 922 w/ Dust Filters
Operating System
Windows 10 Professional 64-bit
55" 4K Samsung Curved TV
Keyboard
Roccat Sova Mechanical
Mouse
Roccat Kone XTD
Audio
Glow Amp One > HD650
Audio
Yamaha Receiver + 5.1
Other
Xbox One Wireless Controller
xxicrimsonixx is offline
post #7 of 25 (permalink) Old 12-03-2019, 07:55 AM
skupples's Avatar
yeaaah. I always ran multiple GPUs back in the Nvidia Surround days, however its still completely viable. I had to step down to a single screen due to space issues.
skupples is offline
post #8 of 25 (permalink) Old 12-03-2019, 07:57 AM - Thread Starter
Rep: 1 (Unique: 1)
Thanks for the suggestions so far. I thought people were saying online that 1440p at 144hz wasn't possible across all 3 screens so I just assumed I couldn't do it. It's not really necessary for me to do sim racing at 144hz so I don't mind dropping down to 60 or 70 hz if necessary.
post #9 of 25 (permalink) Old 12-03-2019, 08:00 AM
skupples's Avatar
"not possible" is relative to what you're doing and playing. I'm sure plenty of 2-3+ year old titles would span and push 120FPS easily. brand new stuff? Not so much, but that's how its always been. CRU is your friend in this side fo the hobby.
also look up Flawless Widescreen. I believe he's returned from the dead.
skupples is offline
post #10 of 25 (permalink) Old 12-03-2019, 08:04 AM - Thread Starter
Rep: 1 (Unique: 1)
I don't play too many new titles so I don't mind dropping down the refresh rate to make them more playable. I wasn't planning on playing on all 3 at once besides racing but I guess I can try it out and maybe I'll like it more than I thought I would.
Maybe it's a stupid question but what is CRU? Thanks
