Doubts and advice on buying a gaming monitor - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 04-09-2020, 07:15 AM - Thread Starter
RoboX's Avatar
Rep: 1 (Unique: 1)
I have a doubt about the characteristics of the monitor to buy and use for gaming.
I currently have a 24" 1080p TN.
My need is to upgrade the monitor, with the aim of:
a) switch to a 27-28 "
b) increase the resolution to 2k or 4k
c) improve the stuttering that can occurs even in conditions of 50-60 fps, always playing with activated vsync, hating tearing
d) in any case improve the gaming experience from all points of view)
e) Freesync or g.sync
I use last fps game or action rpg, always with details to the maximum (as far as possible of course and the playable ... 40-60 fps) and with medium level VGA, not from 500-800 euros.
My questions, for which I ask you for advice, are the following:
1) in my situation, having a frequency higher than 60Hz, while never playing higher than 60-70 fps, in itself already improves the fluidity of the image? Or is it useless to use a 144Hz monitor?
2) in my case, the purchase of a 2k or 4k maybe it is better to orient it on a 60 or 90Hz?
3) does a game from 60 to 100 fps have a much higher fluidity and, above all, more pleasant in the gaming experience or do you notice much?
4) do you notice a better image quality going from a TN to an IPS or VA? ... if yes, maybe it is better to direct the choice to a better panel than the TN?
RoboX is offline
post #2 of 6 (permalink) Old 04-09-2020, 07:23 AM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
From my experience TN and VA sucks and i would never buy either TN has too crappy color reproduction even on the best panels and VA is just too damm slow even on the best panels
The LG Gl850 is pretty much what you are asking for and IPS is just light years better than VA and TN so yes it improves the image quality a lot
Edit: also you did not say what GPU you have but if it can just barely keep up at 1080P its not very good and you need a GPU upgrade before you start to move to 1440P
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 6 (permalink) Old 04-09-2020, 07:35 AM
Cakewalk_S's Avatar
Rep: 276 (Unique: 256)
https://www.amazon.com/LG-27UK650-W-...&tag=coa_us-20
I believe B&H has it for $400 but its on backorder. Basically all technology at this point is almost on backorder...
I'll be upgrading to that monitor once all this covid stuff is over. According to Rtings its one of the best monitors.
Cakewalk_S is offline
post #4 of 6 (permalink) Old 04-09-2020, 08:14 AM
mfw
ToTheSun!'s Avatar
Rep: 503 (Unique: 234)
It's pretty pointless to go after 144Hz while you play at 60-70 FPS with VRR on. There is, in general, an improvement in response times when playing at 60-70 FPS on a 144Hz monitor, though.
Disregarding the starting assumptions you made us make, I'd say, for gaming, it's overall better to stick to 1440p144 than 4K60. The benefits of which, though, only you can weigh against what you REALLY want in a monitor.
The difference is absurd. 100 FPS is SO MUCH BETTER (in fluidity) than 60 FPS when accompanied by proper display frequency. Resolution increases are nice, but I'd say the baseline motion fluidity (and also clarity, which is affected in part) HAS to be met satisfactorily before one should consider the pixel count.
It depends on what you're personally more or less sensitive to. People are all different. Color and gamma shift annoy me terribly, so I'm partial to IPS. To some people, other things rank more highly, so they might consider TN and/or VA more favorably. It's really up to you. Best of all worlds is OLED, but since everything else is a compromise, plan carefully.
If I were you, IPS all the way, especially considering response times have improved greatly since 5+ years ago.
With all that said, I recommend either the LG 27LG83A or the LG 27GL850. The former is better value, I'd say.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Odin
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is offline
post #5 of 6 (permalink) Old 04-09-2020, 08:56 AM
skline00's Avatar
Rep: 16 (Unique: 14)
RoboX, What gpu do you presently have?
9900k-5.0-Kraken X72|Asrock Z390 Taichi|32g-DDR4-3200 FlareX|EVGA GTX 2080TI XC | Corsair MP500-480g|EVGA 1000W|Thermaltake V51|Acer ET430k|Win10-64 home
3900x stock Custom WC Optimus WB 360 +240 rads EK D5|MSI X570 Unify|32g-DDR4-3600 TridentZ Neo|Asrock Radeon VII-EK block |Sbrent Rocket 1tb NVME4|Corsair RX850|Phantek Ethoo Pro|BenQ EX3501R+Oculus Rift
skline00 is offline
post #6 of 6 (permalink) Old 04-09-2020, 01:58 PM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
Get a 1440p144+ IPS if you can. 2160p60 is not that great for gaming and you're better off with an OLED 2160p120 TV for this resolution.
JackCY is offline
